Question about Mr. Coffee FTX24 12-Cup Coffee Maker
Our Mr. Coffee Model FTX41 will not brew coffee on the normal cycle. It sounds as if it is working, but water is not pumped up. It will work with vinegar on the cleaning cycle. It is 7 months old. Please help.
  • Marybel Sanders
    Marybel Sanders Apr 30, 2009
    its a known problem that they are Not doing a thing about. Oh yea Buy AMERICAN!
SOURCE: Mr. Coffee FTX41
Buy a new and different coffee maker.
Posted on Feb 22, 2008
  • 1214 Answers
SOURCE: Mr Coffee stopped brewing
Sounds like there are a couple of problems -
First, are you certain that the coffee basket is clean? If the coffee basket has a valve on the bottom that allows you to remove the carafe to pour a cup of coffee, make sure the valve is clean. Being dirty would cause it to trickle coffee slowly into the carafe, and will hold coffee in the basket too long.
2nd, you may need to flush the water heating system as they can become corroded with precipitated solids from the water.
To do this, mix 1 part vinegar to 2 parts water in the carafe. Pour into the coffee maker and tell it to make coffee. Do this a couple of times, using a fresh mix of vinegar and water each time. Pour the used mixture down the drain.
When you feel it is clean, follow it up with a fresh pot of water. Then wash and rinse the carafe.
The coffee maker is now ready for it's next use.
Posted on Jan 30, 2009
SOURCE: Coffee not brewing
This machine depends on heat to move the water to the top. The heating element, or thermal fuse, or burned contacts are the usual suspects. The warmer under the coffee pot is not part of the coffee making process. It is repairable.
Posted on May 05, 2009
  • 25 Answers
SOURCE: Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
Posted on May 14, 2009
buffalonyman
  • 1865 Answers
SOURCE: Mr. Coffee FTX23 quit brewing
The heating element burned out, its a common problem. Mr. Coffee tend to leak, I've had several of them.
Posted on Jun 10, 2009
Repair mr. Coffee pump
Rare for a Mr. Coffee, but it sounds to me like your disc thermostat is stuck open, or a wire has dropped off. They usually stick closed and burn out the thermal cutouts.
Feb 19, 2013 | Mr. Coffee Coffee Makers & Espresso...
My Pot wont brew
mcdevito75 here, Your Mr. Coffee may need cleaning, here"s how, Fill the resovoir with white vinegar, cycle thru the machine 3 times, half way thru the 3rd time stop 1/2 way thru and turn off machine for 30 minutes, then recycle. After that rinse your Mr, Coffeee by cycleing thru fresh water each cycle takes another resovoir of fresh water to get rid of the vinegar. If this is not the problem, maybe the pump is shot. Contact Mr. Coffee by phone or online at Mr. Coffee.com or replace the machine.
Jul 09, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
We have an FTX41 12 cup mr coffee maker. Suddenly all the water we pour in comes out the bottom all over the counter. What do we do?
Ours (FTX41) did this, made a pot of coffee in the morning just fine then a few hours later we went to make another and the water just poured out the bottom. I took out the 6 screws (4 philips and 2 torx under the rubber feet). When I took off the bottom one of the hoses to the heating element had come off. I put it back on and everything worked fine. It took about 15 min. to fix and put back together. Poor design on the hose connection, no clamps of any kind.
Jun 28, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
Mr Coffee doesn't brew
Usually when that happens you need to clean it out w/ white vinegar and water because it's developed a blockage of some kind. I'd recommend 6 cups vinegar and 6 cups water, and brew it through like a normal brew cycle. If you haven't done this at all in the year that you've owned it then it probably won't work completely the first time. You might have to do it quite a few times, and I suggest doing it at least once a month from here to keep the problem from happening again. And remember to always use a fresh solutution each cycle, don't want anything you take out to go back in, you may not get any coffee then! :)
If you like, there's another way you can do it. Put in the solution of vingear and water, start to brew it, and just when you start seeing it drip into your pot, turn off the unit and let it sit for an hour. Soaking it or running it through several cycles can both help, it's up to you how you go about it.
Aug 28, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Clean light won't go out, can't use delay brew feature.
Try unplugging it for several minuets & see if it clears it..
Jul 08, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffee not brewing
May 05, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Jan 30, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Mr. Coffee won't brew - Mod. #ECX30118
IF YOUR HAVING ISSUES WITH THE ACTUAL BREW OR CLEANING CYCLE AND IT WILL NOT WORK, THERE IS NO TROUBLE SHOOTING THAT CAN BE DONE. MR COFFEE CARRIES A YEAR WARRANTY SO YOU SHOULD CALL THEM TO HAVE THEM REPLACE THE UNIT.
Jan 14, 2009 | Mr. Coffee FTX24 12-Cup Coffee Maker
Mr. Coffee FTX41
Dec 10, 2007 | Mr. Coffee CBTU45
Mr. Coffee FTX24 12-Cup Coffee Maker Logo
143 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Henry  Thomas
Henry Thomas
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
