Question about Intermec CN3
Remington hc-353 How do I open the case to change the batteries? I found one screw under the plastic button........
I have the above hair trimmer and batteries no longer hold charge. Take off the trimmer mechanism, that is the two large screws. Then unscrew the screw under plastic button, get flat bladed screwdriver and prise apart the two sections, they just clip together with plastic lugs at ai sides of the case. battery replacement, ehen you open you will see three batteries that have been soldered together. Have not found any easy way of replacing batteries at moment, still working on that one. Good luck Tony B
Posted on Aug 23, 2008
  • shirlz1975 Dec 30, 2010
    found the batteries at :http://www.batteriesdirect.com.au/shop/p...
    hope this helps took me a while but got them ....
How do I disassemble it to replace the battery?
usually starts with screws on bottom of shaver where power cord is plugged in. most shavers have soldered in batteries, not an easy replacement.
Jul 20, 2015 | Remington MicroScreen DA-307 Electric...
My Remington HC5550 will not hold its charge
Open the device by first taking off the power button. Now you can slide off the plastic part that goes from the power button down to (and around) the charger connector. Remove the screw. Now take a flat screw driver and open the two plastic parts that form the main housing. Remove another two screws that hold the charger connector board. Un-solder the red and black wires that lead to the motor, then you can slide out the charger connector board with the batteries. Replace them by two eneloop (size AA) batteries.
Please have a close look: The batteries are soldered both to the board and between each other. Just solder the new batteries in the same way and orientation.
Apr 26, 2014 | Remington Hair Trimmer Accelerator Hc5550
Remington hc 5550, how to open it without destroying plastic cover. i.e. to replace battery. (Especially how to put off plastic part at the end of handler which hold together both top and bottom halves of...
Most of these types of units are sealed and cannot be opened without damage to the case. Even if you could open it, the battery is most likely using connections that are spot welded to it. You will have trouble getting another battery for it that has the same connections.
Oct 28, 2013 | Remington Hair Trimmer Accelerator Hc5550
Battery will not charge on remington hair trimmer hc5550.
You can, but you need some experience with soldering.
Look for the other answers here in this forum, there are some descriptions on how to open the device.
In short: you have to remove the power button (be careful not to destroy it), then slide off the middle plastic part, remove a screw, then take off the upper main plastic housing, remove another two screws and take out the inner device which holds the motor and batteries.
The old batteries can be replaced by 2 AA-size eneloops.
Aug 21, 2012 | Remington Hair Trimmer Accelerator Hc5550
Hello, How do I change the battery on the Remington TF300 shaver? and I don't know how to open the case to remove the old battery.
Remove the foil assembly and cutters. You will find 2 screws on the back near the top. Remove screws and you can then pry the front half of case off. You will then be able to access the batteries. There are two batteries connected end to end. You will find replacements at shaveroutlet.com. See link below. You will need to order 2 batteries
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
Sep 25, 2010 | Remington Health & Beauty
I need Guidance on opening the case up to check/replace battery. This is a Remington WPG-250 and doesn't have any screws on the outside.
There are no screws holding this together only 8 locking plastic clipbs (4 on each side). To open I started near the battery charger end and used a flat tip screwdriver to gently pry open the case. Repeat on the other side. Unit has 2 Sanyo NIMH AAA batteries (welded tabs in series). I can't determine if these are regular NIMHs or enloops.
Aug 22, 2010 | Remington WPG-250 Hair Trimmer
Replace battery
Depends on waht kind of shaver do you have. I just changed battery in my remington R650. There are 6 screws to hold the shaver together and they are all hinden. Step 1 to take off the shaver blade assembly on top. It is very easy because it is linked by a wire spring. Two scews will revealed and took them out using a philips screw driver. Then take top black part off then threw shafts to drive the blades will come off together. Then took the trim off. It will take some time. I have to take a piece by piece. Then take two red plastic covers pieces off which will reveal 4 screws under it. I use thin knife to pry them off. After you take off 4 screws, the shaver will be open. You will see the two NiCd 600amh batteres connected serial inside the shaver. They are soldered through wires to the PCB.
May 14, 2010 | Health & Beauty
The clipper blade adjustment on my Remington Hair Clipper, model HC-8017 (a black plastic adjustment arm) broke. Is it possible to get a replacement part?
The part that you require is not available for budget models like the HC-8017. You will need to purchase a new clipper or find an old one (ebay?) that you can buy cheaply for parts.
If you decide to replace your HC-8017 clipper, you will find them for sale at shaveroutlet.com
Jan 25, 2010 | Remington Precision HC-8017 Hair Trimmer
I need to replace batteries in Remington wdf 3500
Have just opened the same model -
First prise off the front and back "rubber" inserts - they should come unstuck quite easily. Then pull the bottom half of the case off the top half - it is held by 2 internal clips, one on either side of the inside black plastic casing - pull and wriggle and pull some more, and suddenly it will pop off.
Dec 22, 2008 | Remington Smooth and Silky WDF-3500 Hair...
Remington Precision hair trimmer HC -353 cannot find anyone that supplies replacement ceramic blade .Trimmer working well , be a shame to have to dispose of it just because it needs a new blade .
Advantage Shaver Spares 0800 0086716 do a replacement ceramic blade set including the meetal plate & screws for £10.00 plus £2.00 p&p.
Apr 21, 2008 | LG KU990 Viewty
Computers & Internet Logo
905 people viewed this question
Top Intermec Computers & Internet Experts
Computer Repairing
Computer Repairing
Raghavendra Nagaraj
Raghavendra Nagaraj
Are you an Intermec Computer and Internet Expert? Answer questions, earn points and help others
