Question about ASUS K8S-MX Motherboard
Hanging of the system
My system is hangiging regularly after a 5to 10 minutes working.. regulerly system shows the starting msg "over clocking failed..f1 to set up ,f2 to cotinue, i tried by updating the bios file(1013.rom) , if it s due to c mos batteri's problem?, first of all i think its due to any virus,but i tried by formating the xp..in drive,pls give the details ofstandard working values of CPU Frequncy,AGP/PCI,DDR VOLT,,etc to set over clocking option,,for my board(k8s mx, AMD 64) ,other problm s the continous blinking of grafics,,(as signal cut of tv set) not a monitor problem,,after a restart its okk..what is the actual problem??
  • 2 more comments
  • gopi_navudu Aug 16, 2008
    vgadrivers
  • Anonymous Dec 06, 2008
    SAME ISSUE
  • jareesh Feb 21, 2009
    didnt tried to change the bios settings.becouse system working in its defualt values . then ,can you pls tell the satandard values of bios for my KS8M-X board,..??
    thanks..
  • Wiard Giezen
    Wiard Giezen May 11, 2010
    did you try reset bios to standard values??
The problem may be in RAM
Posted on Feb 17, 2009
Having major trouble setting it after D.S.T. Could you help? The "it" is a Universal TechTronics U.S. Perfect Time clock.
16d25m. \FixYa.com /mm
... I'm not familliar with your particular clock, but, I'm assuming you may have a;
BATTery operated, wall-hanging, 'self-syncronizing' clock with 'hands' on it.
These are often marketed as 'Atomic' Clocks that 'keep perfect time - all the time'.
Generally these work by 'accuratizing' the Minute-hand as it approaches the 'top-of-the-hour' position (e.g. the 60th. or the zero- minute marker at '12'. They often achieve this by either 'double-Clocking' or 'half-clocking' (doublespeed or halfspeeding) the electric pulse that makes the 'SECONDs' hand advance to it's next mark. These 'SynCHRONO-ize' to a low-frequency Amplitude-Modulated (AM) radio-wave signal, (perhaps near 430Khz?) emminating from a source near "The Atomic Clock" out in Colorado (I believe).
One that I used to have hanging had recommended something like the following:
-manually adjust the time (via the small grey wheel near the BATTery, but set it about 7 to 12 minutes 'early' or before the actual correct time, (preferably at about 10 min. before an Hour).
-then remove the one " double A" . . .
... battery (for about 30sec.) and reinstall battery.
-then hang it up, and watch for the second-hand to do its 'Double-clocking' (for part of it's revolutions ) as the Minute-hand apprpaches th '12'. {note; it may take ~2 or 3 hour-cycles for the minute-hand 'to catch-up on all it's "Lost" minutes}.
(then, hopefully, your model will stay 'synchonized' there, for that 'Hour's' setting, and accept It (DST Hour value) with accuratizing Minutes. (and not go crazey over the next few days trying to get back to "Real TIME"). /mm
butifallelsefailsreadthedirectionsand,
basicinstructions'boutlife(on)earth.
Apr 25, 2016 | Home
Tip
REGULATION TIPS FOR THE 400-day and 1000-day clocks
CLOCK REGULATION TIPS FOR THE ROTATING REGULATOR
These Regulations tips are useful for regulating the rotating regulator. This is to include most 400-day and 1000-day clocks.
The following information is copied from SCHATZ (tm) OWNER'S HANDBOOK.
Time Regulation Tip:
On the top of the pendulum is a disk on which numbers are engraved 1 - 16 and two arrows marked F - S. The small indicator hand will be pointing to a number on the disk at which the clock was regulated before leaving the factory. Should you find it necessary to regulate the clock, observe the number to which the indicator hand points. The distance between each number is equivalent to 1/2 minute in 24 hours + or -.
FRROM MY PERSONAL SHOP NOTES:
If your clock loses two minutes per day [24 hours] and the indicator hand points to number 8 on the disk - move the disk in the direction of the arrow marked F until the indicator hand will point to number 1.
NOTE:
Before attempting adjustments to the regulator disk, first lock the pendulums by using the lever located on the front of the base. By so doing, you will avoid damage to the delicate suspension wire while turning the regulating disk.
Keep A Regulation Record:
Keeping a short Record of regulation and maintenance on your clock will make it much easier for you to keep it well with in its optimum time-keeping ability. We have found that using the guideline below helps.
Date: +/- in min: How much adjust in Degrees +/-: Personal Notes:
We recommend logging only the times the clock was wound, and any time the clock is regulated or reset.
Times of regulation will include any time the clock has exceeded a 3 to 5 minute error.
Use only ONE form of time references for this, a QUARTZ clock that is known for keeping good time is recommended.
Over time you may find the clock needs only slight regulation; for example, if it has run for approximately 3 weeks and the error rate is under 3 minutes adjust regulator only slightly or simply RE-set.
TEMPERATURE and SEASONAL CHANGES
Temperature fluctuation can affect the time-keeping abilities of your clock.
Never allow direct sun light to come in contact with your clock. This will over heat the clock and it will not only affect the time-keeping qualities, but also dry out the oil and cause premature servicing requirements.
SPECIAL NOTES: REGULATION TENDENCIES
It is very difficult to look at the hands of an analog clock and still determine if the clock is running correctly, therefore I recommend allowing the time error rate on the clock to remain UN-touched until the error rate has exceeded + or - 3 to 5 minutes. This is because 1 minute is very difficult to observe and calculate effectively.
One little known fact about the Rotating Regulator: After the clock is restarted it can take up to 3 or 4 hours for the pendulum to settle down into regular beat rate. Example: If the pendulum is under rotated the clock will run fast and will take some time to bring it up to speed. If over rotated it will run slow. RECOMMENDATIONS ARE: Look at the actual clock time and reset it as closely as possible to real time after the clock has run for about 3 to 4 hours but don't disturb the pendulum. ONLY RESET THE CLOCK IF the actual clock time is off by 1 or 3 minutes.
If you must reset the clock every 3 to 4 weeks, and it is FOR EXAMPLE always slow, Slightly RE-Regulate the clock to compensate for this rate of error. Simply reset the clock several times just to make sure that no mistakes are made.
How to Calculate the Adjustment:
Calculating how much to turn the regulating nut on the rotating pendulum by using the following calculations.
Link to data base located at http://antiqueclock.clockstop.com/Regulate.html
Hope this tip helps.
r/David
on Feb 17, 2010 | Watches
Why does my ac on 2004 Volvo quit cooling after 5to 10 minutes running
posible low in freon electrical problem or low side get frozen
Sep 11, 2014 | Cars & Trucks
Starts but wont rev up
did you replace the fuel regulator located on top of the fuel pump?
Feb 12, 2013 | 1996 Jeep Grand Cherokee
Switches off after 5to 10 minutes but is stiil new
overheating / thermal cutout connected ti ignition switch wiring
Mar 27, 2010 | Electrical Supplies
Flashing alarm light after battery change. Car wont start,
System operation
System arms 5 seconds after switching ignition OFF. Switch ignition ON. Ensure clock LED illuminates for 3-5 seconds. If LED flashes rapidly at regular intervals for approximately 1 minute, then flashes at irregular intervals: Key code not recognised. Remove key and try again.
Programming
When
System malfunction: LED illuminates for 1 minute, then flashes at irregular intervals. Key(s) added or replaced.
NOTE: Replacement keys MUST have blue mark. Keys with red mark are NOT compatible with this system.
How
NOTE: Programming method using vehicle keys can be deactivated using diagnostic equipment.
Obtain 2 programmed keys (A and B). Insert key A into ignition switch. Turn ignition switch to position II. Wait 1 second. Switch ignition OFF. Remove key A. Insert key B into ignition switch within 5 seconds. Turn ignition switch to position II. Wait 1 second. Switch ignition OFF. Remove key B. Within 10 seconds: Insert key to be programmed into ignition switch. Turn ignition switch to position II. Wait 4 seconds. Switch ignition OFF. Wait 5 seconds. Start engine. If engine does not start and clock LED flashes: Switch ignition ON. Wait at least 20 seconds. Switch ignition OFF. Repeat programming procedure. Repeat above procedure to program remaining keys. Keys can also be programmed using diagnostic equipment
Mar 08, 2010 | 2000 Ford Focus
WHEN I CONNECT TO PC MY APPLE IPOD HANG UP
Reconnect ipod to pc..After ipod says connected in computer remove hardware click on ipod..wen says safe to remove hard ware look on ipod to it saying disconnecting..Afetr full disconnecting push and hold pause/play button down for more than 5to 10 seconds..Should work properly..
Apr 04, 2009 | Apple iPod MA446LL/A MP3 Player
Wrong time on Emerson Smart Set clock
This is a problem with the clocks tuning crystal. Digital clocks have a crystal that is tuned to run at a certain frequency to keep the clock working correctly. These clocks have a problem with that crystal keeping the frequency locked at the correct working frequency. This problem will sometimes cause the clocks to run fast due to a running frequency higher than the regulated frequency and sometime slow due to a running frequency running lower than the regulated frequency. The only way to fix this problem is to either adjust the crystals frequency to the correct frequency and lock it. Or change the crystal. Both these types of service require tools and test equipment to fix the problem. This is usually best handled by a service center. The Emerson customer support telephone number is 1-800-898-9020. Give them the make and model number of your clock radio and ask them for assistance. I hope this information helps you with your problem.
Nov 18, 2008 | Emerson Smartset Clock Radio
Display clock on phone
I found the answer at www.digcom.com.
CLOCK/CALENDAR SETTING
Note: The date must be set in system programming (10-01).
To set the system Time:
1. Press the Speaker key.
2. Dial 728.
3. Dial two digits for the hour (24 hour clock, 13 = 1:00 PM).
4. Dial two digits for the minutes (00~59).
5. Press Speaker to hang up.
Aug 05, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
ASUS K8S-MX Motherboard Logo
79 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
