Question about Sharp SF 2020 Copier
I need help with my SF-2030 copier
The copier is not printing any copies. I am receiving and error message Flashing H4. I have not found any direction in the operator's guide to assist me with this problem, please advise.
Thanks Diana
e-mail me at avery703@bellsouth.net
A little rusty on this machine, but try this.
This code means the copier has not warmed up in a specific amount of time.
Make sure all is clear in the fuser and exit sections.
Then on the control panel you will press a series of buttons as follows.
Press the Clear, Press interrupt, Press Zero, Press interrupt, Enter # 14, Press start, That should reset the machine...
If it does not reset, you may need to have a tech look at this.
Hope that helps...
Lbcoaster
Posted on Jul 02, 2008
Clearing service man on 5320 sharp copier
Hello, NICOLAS
Let me give you, a url when you can find sharp error codes and fix by youself, if you have any other cuestion, please write a comment, im here for help you.
How to solve the h4 subcode 00 error message on sharp AL-2030 copiers
http://www.en.rellenadodecartuchos.com/2014/05/how-to-solve-h4-subcode-00-error-message-on-sharp-al-2030-copiers.html
thanks for comment if need more help
Nov 16, 2015 | Sharp Office Equipment & Supplies
Sharp al-2030 h4-00 code
H is a heater problem H4 is more specific, not sure but it could be the lamp, thermistor or triac. It will be one of these or even a bad connector on the heater section
Aug 28, 2014 | Sharp AL-2030 All-In-One Laser Printer
I have sharp sf 2030 make black copy
A broken charging unit causes a totally black page print. Try removing and reinstalling the print cartridge or photoconductor unit.
Black Copy
Dec 17, 2012 | Sharp Office Equipment & Supplies
TENGO UN ERROR 4 l EN UNA FOTOCOPIADORA AL 2030
H4 mean heat roller low temperature detection
08bbjn9rbri+xdkjoq0fkqpdkucvv87lg66brrj5rzvk2vgkrs9uaz1auaie3rmbc17pbhis8ry2etxu+pffwlcypo2vmp+hmnkpzqro3omzqzp3yebq5d34amdixrh6r1b2aaaaaelftksuqmccpress 14 press start then ready to make copy
Mar 25, 2011 | Sharp AL2030CS Black and White Copier
I have sharp AR-163 it indicate f5 error. And Sf 2030 error code f2
Ar163 F5 = Copy lamp problem.
Possible causes are:
Blown Copy Lamp
Inverter trouble (copy lamp driver module)
MCU Board failure
This is most likely to be a blown copy lamp.
Ar2030 F2 is a process control error - depending on the sub-code it could be a number of different things. Please repost with the full code.
Hope this helps.
Feb 09, 2011 | Sharp SF 2540 Copier
Cannot print, scan or copy. Continue to receive
Solution
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts. Click here to see how.
  3. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
  4. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty.5. Replace Cartridge.Please rate my response!!!Thanks,SF
Jan 28, 2010 | HP PSC 2410 All-In-One InkJet Printer
Sharp copier SF-2025 displays an error code H4
H4, not heating up, replace fuser unit complete or work with hivolts and replace an expensive and tricky lamp/thermister . wont be cheap.
. Here use the reset for it first, sometimes power surges can just flip them out but most times will just reappear shortly after reset, indicating the want of a working fuser assembly
Fuser (not fuse) is the hot bit with rollers at paper exit if code fails it needs to be replaced, wont come cheap no matter how you approach it
C-Exposure key-C-Exposure key-14-copy key to clear ... but it will come back I bet...
Nov 03, 2009 | Sharp SF 2020 Copier
Error Message H4
It is a fuser problem, sometimes it can be reset by technician or you should replace the fuser lamp
Apr 02, 2009 | Sharp AL-1530CS All-In-One Laser Printer
Diagnostic codes for Sharp SF-2014 copier
Sharp SF 2030 On power need enter operator key code, need reset.Please help.
Jan 06, 2009 | Sharp Office Equipment & Supplies
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
