Question about Intel Frontier Design Dakota 24-Bit PCI Soundcard Sound Card
No sound on my computer
I wanted to watch something on my laptop but there was no sound. i clicked on the volume control but it said 'no mixer devices are installed'. i haven't found them in the control panel though...
  • 3 more comments
  • magdamagda Jul 01, 2008
    thank you!
  • Anonymous Jul 29, 2008
    need plug and play software for this sound card
  • Anonymous Jul 30, 2008
    No sound on my computer problem, and notify you when a new solution is offered.
  • Anonymous Aug 19, 2008
    No Sound
    intel
Please i need it
Posted on Aug 19, 2008
  • 5,568 Answers
Go back to the Control Panel, click on Add or Remove Programs, look for 'Add/Remove Windows Components' and check if the media player is checked.
Most sound cards and on-board sound chips have their own software but the Media Player will suffice.
If it is checked, go to 'System' (in the Control Panel), then click on the Hardware tab, then Device Manager.
Go down the list to see if Sound, video and game controllers has a red 'X' showing.
If it does, then either the driver is damaged or the hardware itself has failed.
If it is only the driver, you can delete the exed item and try rebooting to see if Windows restores it.
If that doesn't work, the you may have a system board problem (expensive).
Let me know how you do-
Posted on Jun 28, 2008
How do i increase sound for you tube
If it's general sound on your laptop that is soft, you can try checking Control Panel > Sound > Playback > (Right-click your sound device you are using) > Properties, check if the volume is at 100, and try using the Equalizer enhancement and putting all the freqeuncies on max, and you can check your volume mixer.
If it is just youtube, try watching the videos in VLC, by doing this: http://www.thesofthelp.com/2009/08/how-to-solve-low-volume-problem-of.html
Feb 25, 2013 | Acer Computers & Internet
My sound is not working, it says i need a mixer device?
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
hope this helps
Jun 19, 2012 | Dell White Slimed Inspiron Mini...
I'm using my mixer with my computer and just tried it for the first time yesterday and can't get any sound. I have a mic plugged into the mixer and the mixer connected by USB cord to the computer. ...
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it hope this helps
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Jun 24, 2011 | Peavey Computers & Internet
M I VOLUME IT IS BLOKT END AI DONT NOU TOW GO INSAID TOW VOLUME MIXER HAW AI DOW DIS
Look for the Volume Mixer icon on the bottom right of your screen in the toolbar near the time. It may be hidden so click the "
If the Volume Mixer icon is not there, go to the Start Menu then click the icon for Control Panel. In the Control Panel window, select Sounds and Audio devices. Once in the settings for Sounds and Audio devices, there should be a checkbox for the option to "Place Volume Icon in the Taskbar." If no checkmark is there, click the box and then click on "OK". Now the Volume Mixer icon should appear in the taskbar.
Proceed by clicking this icon to launch the control panel for Volume Mixer. From here, you can change the volume settings for your computer and specific programs. Be sure to adjust the Master Volume setting.
Feb 28, 2011 | Dell Inspiron 6000 Notebook
My microphone on my computer wont work
Go to control panel > sounds and audio device and have a look in there or click on the advanced button for the audio mixer in the mixer, go to options > properties and select mic click ok then turn up the volume on the mixer.
Nov 26, 2009 | HP Pavilion dv1000 Notebook
The mute wont turn on,on the dell inspiron
Have you tried going into the speaker settings? We'll assume with a new PC you have Vista installed, click the speaker icon on the right side of the tray, and selecting "Mixer" will enable access to volume control for the output devices and for applications.
If no speaker icon is visible To check the volume controls in Windows Vista, click Start and then click Control Panel. Choose Hardware And Sound and then click Adjust System Volume under the Sound section. The Volume Mixer window will open, and you should see volume sliders for Device and Applications. Click and drag the sliders to view the volume level percentages. If the speaker icons show a circle with a red slash, click the icon so the speakers are no longer muted.
Furthermore, you’ll want to double-check all of your master volume and mute settings.
Dec 29, 2008 | Dell Inspiron 4000 Notebook
Then go to control panel,system ,hardware ,device manager option
There if u find any question mark or exclamation mark in yellow Color that means sound drivers are not installed properly
please reinstall sound drivers properly
or else
If no question mark or exclamation mark then check the cable connections of the speaker to the machine
or else
In control panel , select sound audio devices open it there u have
volume,sounds,audio,voice,hardware options
1)See whether it is mute
2)In audio option select default audio device and recording device
should be same
this should solve u r problem .if it is not solved please let me know u r problem briefly
or else put the model number and brand name followed by drivers search in ww.google.com
Aug 19, 2008 | Dell Inspiron 2200 PC Notebook
Sound
is dere is ny sound driver installed in ur laptop...??
if not then pls install it first....
if ny other problem occurs ask me.....???
Jun 17, 2008 | Acer Aspire 9300 Notebook
There is no sound
Try re-installing the Sound Device Driver, you can download the driver here.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=
en&cc=us&dlc=en&product=366264&lang=en
If my solution works, please spare a little time to accept my solution.
-mrsolution
Jun 12, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Open Questions:
Toshiba Support USA - Toshiba Online Customer Care Support USA Toshiba as a brand has continued living up to the expectations of its customer for nearly three decades now, by maintaining the high quality of its products with the help of delivering a combination of useful software and attractive hardware in a package, which is required for providing the needed technological expertise. With laptops becoming an indispensable and integral parts of our lives, it is important that companies today equip their laptops with all the advanced technologies along with a sleek and stylish design for that attractive feature that would add to its plus point. Our Toshiba technical support team members are available all the time on our Toshiba Support number +1 888 784-9316 and are highly adequate in resolving issues related to Toshiba printers. The fact that everyone today knows about Toshiba Support brand and most people who have tried Toshiba products like them, makes them one of the most reliable in case of printers especially. Toshiba makes business portable laptops, with highly durable features of being sturdy and long- lasting for use in all walks of life. Most laptop owners would agree to the fact that Toshiba products are designed to provide quality portable solutions and highly acclaimed for their bullet-proof build value. But with time, users might face issues with Toshiba Virus like any other laptop band and these issues can be prevented from causing any severe damage to the laptop by accessing resolution from our technically specialized team members, who are available on our +1 888 784-9316. Issues faced by Toshiba customers: Toshiba Backup BIOS update issues Slow Performance Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Windows 10 upgrade issues Computer Tune-up Issues Virus Removal Issues Data Backup, Transfer and retention issues All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact- +1 888 784-9316.
Apr 23, 2018 | Toshiba Computers & Internet
See all Intel Frontier Design Dakota 24-Bit PCI Soundcard Questions
Intel Frontier Design Dakota 24-Bit PCI Soundcard Sound Card Logo
83 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
