Question about Microsoft Windows Vista Ultimate Edition
If i download the windows vista xp pack will my system data remain on my desktop and in my c and d (drive)
I don't want to loose my system data
    Sniper:
  • 65 Answers
No if u replace vista in placeof xp u didnt loose ur data......
the drive in which vista is to be installed only data of dat drive will be lost..
note:- save ur important data to ny other drive before installing vista......
ask if u havin problem related to that....
thanks....
Posted on Jun 28, 2008
Will not start, windows says it starting but never do . don't have recovery disk
Run the Check Disk Utility with your Vista Ultimate disk.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Apr 21, 2012 | Gateway LX6810-01 PC Desktop
Tip
What Does It Mean When Support for My Operating System Ends?
Microsoft Support for Windows Vista (with no service packs installed) ended on April 13, 2010, while support for Windows XP (without Service Pack 3 installed) ended on July 13, 2010. Windows 2000 support ended on July 13, 2010 as well.
There is no Service Pack 3 for the 64-bit version of Windows XP. If you're running the 64-bit version of Windows XP with SP2, you have the latest service pack and will continue to be eligible for support and receive updates until April 8, 2014.
If you are still running a version of Windows where support has ended, it means that version of Windows will no longer receive any updates from the Windows Update or Microsoft Update site. These updates are generally provided for security reasons to help protect the PC from harmful viruses, spyware, malware, and other malicious software. Windows Update also provides new drivers for your hardware that can improve the reliability of Windows.
Hackers love to take a security vulnerability in Windows and exploit it to their advantage. So, if a vulnerability is found in Windows XP or Windows Vista and you are not running the latest service pack, you will not be protected and will be at risk.
How Can I Tell What Service Pack is Installed?
Follow these steps to discover what Service Pack is installed:
1) Click on the Start Button
2) Right-click on either My Computer or Computer (depending on your Windows version)
3) Click on Properties
On this window, it should tell you which version of Windows along with which service pack is installed). It should also tell you whether you are running a 32 bit or 64 bit version of Windows.
Where can I download the latest Service Pack for Windows?
For Windows XP, click on the following link to download Service Pack 3
For Windows XP Service Pack 3 info, click below :-
http://windows.microsoft.com/en-us/windows/help/learn-how-to-install-windows-xp-service-pack-3-sp3
For Windows XP Service Pack 3 download, click below :-
http://www.microsoft.com/downloads/details.aspx?FamilyId=5B33B5A8-5E76-401F-BE08-1E1555D4F3D4
For Windows Vista, click on the following link to download Service Pack 2
Windows Vista Service Pack 2 info, click below :-
http://windows.microsoft.com/en-us/windows-vista/Learn-how-to-install-Windows-Vista-Service-Pack-2-SP2
Windows Vista Service Pack 2 download, click below :-
http://support.microsoft.com/kb/935791
on Oct 04, 2010 | Computers & Internet
Installing XP on a vista computer
Before beginning please note the following:
All your data will be erased by the end of this process.
Also I recommend to switch to Windows 7 (instead of XP) as they are far better and faster than Vista and XP. If you can switch your XP for Windows 7 then you should do that.
However the decision is yours.
Nothing else should be done except to backup your data.
Then, insert the XP disc in your dvd drive and restart your computer. When the message "Press any key to boot from CD" appears press enter.
When the XP setup loads, select to format your hard drive and install a fresh copy of XP. Follow the on screen instructions and you will have XP on your system in about 30-45 minutes.
Regards,
nicolasiac
Jan 28, 2010 | Microsoft Windows XP Professional With...
Pro tools m-powered problem
You may need to check to see which "service pack" you are currently on.
See below requirements:
System Software — Windows XP & Vista
  • Windows Vista Business or Ultimate Edition
    • 32-bit OS Installation Only
  • Windows XP Professional or Home Edition
    • With Windows XP Service Pack 2 or Service Pack 3
  • Not Supported:
    • Windows Vista 64-bit (any version)
    • Windows XP Professional x64 Edition
    • Windows XP Media Center Edition
    • Windows 98, Me, 2000, NT, 95, 3.1, DOS
  • Not Tested:
    • Windows Vista Home and Home Premium Edition
    • Although Windows Vista Home and Home Premium Edition have not been tested or qualified by Digidesign, there are currently no known issues with Vista Home and Home Premium 32-bit operating systems and Pro Tools M-Powered 7.4 compared to the supported Windows Vista Business or Ultimate Edition operating systems.
Windows Vista SP1
There are currently no known issues with Service Pack 1 for Windows Vista based on our initial limited testing and customer feedback. Although full qualification with all Digidesign products has not been completed, we do not recommend against updating to SP1, given the number of important overall system fixes in SP1. We do recommend that you backup your system and create a restore point before updating to SP1, should you encounter any problems after installing the update.
Sep 21, 2009 | Computers & Internet
Windows Vista Transformation Pack For Windows XP Professional
All of them will slow your system,but here is a link to a pretty nice one.You can also view screen pix here before downloading if you want.
But there are so many out there,you will get a different answer as to what is best from everyone you ask,So it will be something you have to decide for yourself.
Please rate this a fixya
May 18, 2009 | Dell Dimension 2400 PC Desktop
Microsoft Money 2007 shuts down after opening
Hi Drdata889,
If you haven't already been to Microsoft support, then follow the instructions below:
This issue may occur if any of the following conditions is true:
  • The installation of the System Pack was canceled.
  • You did not let Microsoft Internet Explorer to install.
  • If third-party software un-registers a very important Microsoft Money component. Currently, SnapStream Personal Video Station (PVS) software and Cellar! software may cause this issue.
To resolve:
Click Start, click Run, type regsvr32 "c:\windows\system32\msxml3.dll" in the Open box, and then press ENTER.
Note On Microsoft Windows 2000-based computers, type regsvr32 "c:\winnt\system32\msxml3.dll" in the Open box.
Note If you receive the "LoadLibrary(msxml3.dll) failed - The specified module could not be found" error message, follow these steps:
  1. Visit the following Microsoft Web site: http://download.microsoft.com/download/xml/SP/3.20/w9x2kmexp/en-us/msxml3sp2cab.exe (http://download.microsoft.com/download/xml/sp/3.20/w9x2kmexp/en-us/msxml3sp2cab.exe)
  2. Click Open, and then click Yes to accept the License Agreement.
  3. Click Browse, click Desktop, and then click OK two times.
  4. On the desktop, double-click the msxml3.cab file, right-click the msxml3.dll file, and then click Extract.
  5. In the Select a Destination dialog box, click the C:\WINDOWS\System32 folder, and then click Extract.
    Note On a Windows 2000-based computer, click the C:\Winnt\System32 folder.
  6. Click Start, click Run, type regsvr32 msxml3.dll in the Open box, and then press ENTER.
Note In the unlikely event that these steps do not resolve the issue, repeat step 6 three times. Every time, substitute Msxml3.dll in step 6 with the following files:
  • Msxml3a.dll
  • Msxml3r.dll
  • Msxmlr.dll
Download and install the latest version of MDAC loadTOCNode(2, 'resolution'); To upgrade to latest version of the Microsoft Data Access Components, follow these steps:
  1. Download and install the latest version of MDAC. To do this, visit the following MSDN Web site: http://msdn.microsoft.com/data/Default.aspx (http://msdn.microsoft.com/data/Default.aspx)
  2. Install Money.
If you still experience this issue, and you are running Microsoft Money 2002, Money 2003, or Money 2004 use the following additional methods.
Reinstall the Microsoft Money System Pack loadTOCNode(2, 'resolution');
  1. Insert the Microsoft Money installation CD into the CD drive or the DVD drive. Hold down SHIFT to prevent the installation screen from appearing.
  2. Open the installation file. To do this in Windows Vista, click Start
    , type D:\syspack.msi in the Start Search box, and then press ENTER.
    To open the installation file in Microsoft Windows XP and earlier versions, click Start, click Run, and then type D:\syspack.msi in the Open box. In this example, D:\ is the drive letter of the CD drive.
  3. Click OK.
  4. Follow the prompts for the installation process.
If the previous steps do not help, see the "Remove and reinstall the Money System Pack" section.
Remove and reinstall the Money System Pack loadTOCNode(2, 'resolution'); Note Because there are several versions of Microsoft Windows, the following steps may be different on your computer. If they are, see your product documentation to complete these steps.
  1. Locate Microsoft Money System Pack in the list of installed programs. To locate Microsoft Money System Pack in the list of installed programs in Windows Vista, open the Programs and Features item in Control Panel. To do this, click Start
    , type appwiz.cpl in the Start Search box, and then press ENTER.
    To locate Microsoft Money System Pack in the list of installed programs in Windows XP, click Start, click Run, type appwiz.cpl, and then click OK.
  2. In Windows Vista, click Microsoft Money System Pack, and then click Uninstall.
    In Windows XP and earlier versions, click Microsoft Money System Pack, and then click Remove.
  3. Follow the steps for the removal process.
  4. Repeat the steps in the "Reinstall the Microsoft Money System Pack" section.
Hope this is of some use :)
Season's Greetings!
Chris (ziraffa)
Dec 24, 2008 | Microsoft Money 2007 Home & Business for...
Problem regarding vista trnsformation pack
First thing i would like to share with you is :- Vista transformation pack is a collection of some Desktop Enhancement Tools.
So when you install the Transformation pack on your XP machine it will change your default themes/looks + On Boot screen you will see change + Some extra Gadgets on Desktop which will improve productivity / speed of your working. (Simply customisation of Shortcuts)
But dont forget that the underlying operating system is WINDOWS XP only and NOT VISTA.
It is just a change in the Appearance in windows Xp environment.
It feels / Look good but i will prefer to go for following download i feel it will more worth to try out rather than Vista
http://www.engadget.com/2004/06/09/turn-your-pc-into-a-mac/
May 30, 2008 | Microsoft Windows Vista Ultimate Edition
I purchased a Memorex Mini Travel drive, but there is no info on attaching to a PC and also how to download files to the mini drive. Also, can you load data from a XP system to a VISTA system without...
just plug the memorex drive to the usb port in your pc or laptop, just copy the files in your pc or laptop and paste it to your memorex drive. yes you can copy or download files in your old xp to the new windows vista.
Apr 07, 2008 | Computers & Internet
Microsoft Windows Vista Ultimate Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
