Question about HP Deskjet 5440 InkJet Photo Printer
HP 5440 TOP MARGIN ERROR
I've repair the post of one gear because its broken, now when it print the top margin is to high.
  • olhe Jul 02, 2008
    MORE POWER FIX YA TEAM.
    GOD BLESS
    THANK YOU VERY MUCH
    SEE YOU AGAIN
    HAVE A NICE DAY
Printer not picking up glossy and thicker parchment paper
Posted on Aug 27, 2008
  • HP Master
  • 2,794 Answers
When you fixed the gear it probably adjusted the timing. You will have to move the gears around until you can find the home position.
Posted on Jun 28, 2008
Tip
GM OBD1 Codes
DTC - 12 No distributor reference pulse (diagnostic test active)
DTC - 13 Oxygen sensor circuit open or no activity
DTC - 13 Left bank O2 sensor circuit open or no activity
DTC - 14 Engine coolant temp sensor error (high temp indicated)
DTC - 15 Engine coolant temp sensor error (low temp indicated)
DTC - 16 System voltage too low
DTC - 17 Camshaft position sensor error
DTC - 21 Throttle Position sensor error (signal high)
DTC - 22 Throttle position sensor error (signal low)
DTC - 23 Intake air temp sensor error (low temp indicated)
DTC - 24 Vehicle speed sensor error (open circuit or no activity)
DTC - 25 Intake air temp sensor error (high temp indicated)
DTC - 26 Quad Driver Module (QDM A) error
DTC - 28 Auto transmission range pressure switch error
DTC - 31 Wastegate solenoid circuit error
DTC - 31 Gear Position Switch (PRNDL) error
DTC - 32 EGR system failure
DTC - 33 MAP sensor circuit error (signal high indicating low vacuum)
DTC - 34 MAP sensor circuit error (signal low indicating high vacuum)
DTC - 35 IAC problem or idle error
DTC - 36 MAF sensor error
DTC - 36 24x Crankshaft position sensor circuit error
DTC - 36 4T60-E Shifting Error
DTC - 37 TCC brake switch circuit error
DTC - 38 TCC brake switch circuit error
DTC - 39 Clutch switch circuit error
DTC - 39 TCC error
on Sep 10, 2011 | 1991 GMC Sonoma
My HP Deskjet 5440 won't print. The "ON" Button is
hi there!
just push the power button to restart its print job, if that dont work, ive posted the link for that printer here, check out the manuals and troubleshooting steps too, they're all for free. you can also contact 800-HP invent or 800-474-6836.
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=445441
Apr 07, 2011 | HP Deskjet 5440 InkJet Photo Printer
Our printer is not printing any attachements or documents. It is printing Greek gogleeegoop. Some error messages in the text including vertical align, margin, border etc.
Cancel all the queued printer-jobs.
Cancel the current printer-job.
Turn the printer off.
Disconnect the AC power from the printer.
Reconnect the AC power.
Turn the printer on.
Try a "test" print -- it should be OK.
Jul 20, 2010 | HP Deskjet 5440 InkJet Photo Printer
Print en enveolppe with hp color laser jet 2600n
Envelopes can be printed from tray 1 or 2. Select the type of envelope you are using from the PRINT dialog box or the driver. In your program, set the margins. Typical margins for a commercial #10 or DL envelope would be: Return Address Top margin 15mm(0.6 Inch) Left margin 15mm(0.6 Inch), Delivery Address Top margin 51mm(2 Inches) Left margin 89mm(3.5 Inches). For the best print quality, position margins no closer than 15mm (0.6 Inch) from the edges of the envelope. Avoid printing on the seams of the envelope. Envelopes with a peel-off adhesive strip or more than one flap that folds over to seal must use adhesives that are compatible with the heat and pressure of the printer fuser. the extra flaps and seals can cause wrinkling, creasing and feed jams, could even damage the fuser.
Apr 15, 2009 | HP Color LaserJet 2600n Printer
Loading 4x6 photo paper
it's in the actual print settings. under file go to page settings, you can change it ther for as long as you need to print. Or you can apply it to keep those settings permenant. But if you choose to print a full sheet you will have to change the settings back to letter
Jul 19, 2008 | HP Deskjet 5440 InkJet Photo Printer
CLX-3160 image offset or margin shift
Dear
Please contact samsung Call center in your region. fothis type of support.
Apr 20, 2008 | Samsung CLX 3160fn All-In-One Printer
HP Deskjet 5440 InkJet Photo Printer Logo
144 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
