Question about Electrolux EOD6330 Ultrafan Electric Double Oven
Oven door how do i tighten the oven door on the electrolux eod6330x
2 Suggested Answers
SOURCE: Electrolux Oven EOG9330
Hope this helps (technique used on EOG9330XN):
1) With the door open, on each hinge, there is a top cover which lies flush with the hinge. Simply swing this cover up and back towards you. This unlocks the hinge. Undo both and carefully close the door, holding it at the bottom. The door should be able to be pulled away from the frame now. Lay the door on a flat surface.
2) The oven will normally be attached to the surrounding built-in cupbpard. If so, unscrew all attachment screws (mine had at least three per side) and pull the whole oven out about seven inches, supporting if neccessary. Each side panel has a locating screw in bottom front corner, so remove the screw. Peel back the side panel (only thin alloy, but watch for sharp edges) sufficiently to see.....
3) The two side securing screws for the door hinge receiver should be visible. After pulling receiver forward, if loose, tighten securing screws (use lock washers if available, as Electrolux don't provide them).
4) Reverse the procedure to finish job, fitting the door in the near vertical position to engage hinges in the receivers. Support the door, lower to open position and flip the locking hinge covers back.
[This technique works if the hinges aren't worn and if the door doesn't close properly, it usually means that the receivers are loose and have been pushed back into the oven frame].
Posted on Apr 01, 2010
Eletrolux wall oven modelE30ew7cgps2 change door hinges
The hinges mount inside the oven door, open the door all the way, then move the small clips that are riveted to the hinge to the position opposite of where they sit now... this will hold the hinge springs open. Lift up the door as if to close it, then the hinges will lift out of their slots and you can remove the door... Electrolux Range Stove Oven Door Hinge 318244305
Jun 24, 2016 | Electrolux 30" Built-In Single Electric...
Please tell me if Electrolux EKG5547XN Cooker Main Oven Glass Door would fit my EOB6632U
Glass oven door is not compatible.
First of all, the oven door EKG5547XN has only two glasses, inner and outer, while the oven door EOB6632U has three glasses; inner, middle and outer.
EKG5547XN
Inner glass oven door, part number: 349 00 30-01/6, silkscreened; dimension: 456 x 323 mm, tempered glass.
Front glass oven door, part number: 349 10 45-14 / 6, stainless.
EOB6632U
Inner glass oven door, part number: 899661 92 68-78 / 3,
silkscreened; dimension: 479 x 391 mm, tempered glass.
Middle glass oven door: dimension: 447 x 380 mm.
Front glass oven door: dimension: 589,5 x 466 mm.
Dado
Mar 28, 2015 | Electrolux Ovens
Hi, I have a double oven electrolux icon model number e30ew8cgps6. I would like to tighten the handle but only see one screw on the right side and the are three plastic covers remaining and its but the...
Thank you for your post, Karen!
Typically the door of your Electrolux Icon wall oven has a lot of layers. Regrettably, this is not a simple DIY job. I would highly recommend reaching out to an expert technician to ensure the replacement part is installed correctly to prevent future issues. I hope this information helps to some degree. -Matt
Oct 19, 2014 | Electrolux ICON 30 in. Double Wall Oven
Electrolux oven racks how do they go in oven?
Hi Friend, that's a great question!
I see that your post is listed under Electrolux Wall-Oven. May I have your model number please? You can normally find the serial tag (which lists your model number) on the front of the oven, on the left side, as you open the door. With this material I can provide you the correct instructions on how to place the racks in your Electrolux wall-oven. Thank you! - Z
Jul 20, 2014 | Electrolux 30" Built-In Double Electric...
How do I remove the oven door from my electrolux icon oven
Good Morning Friend,
I understand you are trying to remove the door on your Electrolux Icon oven, model# E30SO75ESS. Being, that this particular model is a microwave as well as an oven, I suggest contacting your local authorized technician. They have been trained on this particular model and will be able to assist the best. Hope this is helpful.
-Best Regards-
WP
May 29, 2014 | Electrolux ICON Designer E30SO75ESS Oven
Electrolux oven wont work after cleaning
Hi ja1078063,
I understand you having trouble getting your oven to work after using the self-cleaning mode. Does any part of the oven work? Confirm a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc.
Does "Loc" appear in the display if any button is pushed?
The Oven Lockout feature automatically locks the oven door, prevents most oven controls from being turned ON. Press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked.
Best Regards,
Jan 22, 2014 | Electrolux EW30EW65SS Stainless Steel...
Can I get a replacement for the lower oven door of an Electrolux EDC6935 wall oven?
Hi Mike - I am happy to assist you. First, according to my research, the model number that you have provided me is appearing invalid according to the Electrolux database within the US. Are you located outside of the US? Generally speaking, for some units the complete door set would need to be replaced. However, may I please have the correct model number, to better address the issue at hand? Typically the serial tag is located in the storage drawer on the right side. Thank you and I look forward to your response.
Jun 18, 2013 | Electrolux Ovens
How do I clean my Electrolux Icon Oven?
Which Electrolux Icon Oven do you have?
For most ovens, with a use a cloth and hot soapy water (do not use an abrasive cleanser or an oven cleaner), clean the door and the frame of the oven outside of the gasket. Similarly, remove the heavy amounts of spilled food (get rid of sugary or highly acidic food spills particularly) in the oven. Take the oven racks and oven rack support, broiler pan and insert, utensils and any foil out of the oven. Then close the door. If you have a single oven, press Clean. If you have a double oven, select the oven to clean and then press Clean. Select the duration of the cleaning cycle (either by hours (2,3, or 4) or cleaning level (Lite, Medium or Heavy)). Some Electrolux ovens have buttons for the cleaning level otherwise use the up/down arrows. Then press Start. The door will lock and remain locked until the oven cools after the cleaning process. For a delayed cleaning cycle, make sure the time is correct on the clock and press End Time and enter the time you want the cycle to end and then Start.
Make sure the kitchen is well ventilated.
The manuals are available for most from the Electrolux site. Start at http://www.electroluxicon.com/ and search for your model. (Either search on the model at the top right or under Kitchen Appliances) If you find a page for that model, it will have a Specifications and Guides tab. The manual is in that tab as a pdf.
I hope this helps.
Feb 06, 2011 | Electrolux Ovens
The glass has shattered in my electrolux eou6330x door
i live in az here i use aplace called appalince depot . check phone book or net for something similar
Feb 22, 2010 | Electrolux EOU6330 Electric Double Oven
Apr 11, 2006 | Electrolux EOG9330 Gas Double Oven
Electrolux EOD6330 Ultrafan Electric Double Oven Logo
51 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
