1995 Triumph Triumph Thunderbird Logo
Posted on Dec 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi i have a triumph thunderbird 1996 900cc. when i travel over dips in the road the rebound on the front folks tops out creating a load knock. How do i adjust rebound on the front forks? I have turned the bolt on the bottom of the forks several times in both directions and i have experienced no change in rebound. cheers carl
Eric Cross
Level 2:
  • Expert 294 Answers
  • Posted on Dec 08, 2010
Eric Cross
Expert
Level 2:
Answers
294
Questions
Helped
98482
Points
671
Fork oil replacement and seals fixed mine when it did that. Like you, I also tried to adjust the settings to no avail, then replaced oil to proper level for both sides, and presto, fixed.
1995 triumph thunderbird rear shock seems to bottom out on some bad dips in road .is it easy to replace shock and what best shock to use .
Yes it is easy to replace shocks. 1st can you adjust preload at bottom w/ spanner.thereis a bolt top & bottom of each. there is a tq speck & use blue locktite on threads,, If you liked the stock shocks check for used or new on ebay . aftermarket a whole aray of makers..is out there ..progressive I have used ..
1helpful
1995 triumph thunderbird.front disc caliper mount bolts. is a washer needed?
http://www.bikebandit.com/1995-triumph-motorcycle-thunderbird-front-brake-caliper-discs/om17558sch562797/
Yes there is a washer on each bolt, size M8 stainless steel
1helpful
My 2002 triumph Thunderbird stalled and wont start
Check fuel filter and air filter, then spark plugs, not necessarily in that order.
2helpful
Would like to know standard suspension settings for daytona t 595
(solo median settings - all are # turns from fully 'in')
Front:
Preload  6  Rebound   1.25  Compression 1.5
Rear:
Rebound   1.5  Compression 1.5
Top Triumph Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Mike Cairns
Mike Cairns
Are you a Triumph Expert? Answer questions, earn points and help others
