Question about Dell Inspiron 700M Notebook
Dell 700m memory upgrade
I am trying to install a 1gb memory module in slot 2 (bottom access), it does post but shortly after boot desktop display fragments followed by system lock-up will not reboot. I reinstalled the factory 256mb module and after a couple reboots all is well. Do I need to install under the keyboard? System posts 756mb ram so module under keyboard must be a 512?
  • plocke Jun 28, 2008
    I already tried this
  • plocke Jun 29, 2008
    I know I Can but is this required? I need to know if this is required
  • 60 Answers
No, it's not necessary. Verify the memory is compatible with the computer.
Posted on Aug 24, 2009
I have compaq presario V3070TU with 512mb ddr2 RAM. i tried to upgrade to 2 gb RAM into one bottom slot (not 2 numbers of 1GB), but 2gb RAM is not working(display is not UP). only 1gb RAM is working....
I could not figure out the relationship of the hard disk with the memory.
try change the memory dimms put 512 in bottom and 1gb in the other possition and see what amount of ram you get
Aug 02, 2013 | HP Pavilion ze4365us Notebook
Dell dimension 3000 with winxp os.Want to upgrade my ram from the 1 256mb/400mhz to 2 1gb sticks ,dell site says i can use up to 2 gb.So i power down and intall the 2 ddr2700/333 sticks that are required...
Your memory modules may be ECC or Registered (which are mainly used for Servers). They will fit in the slots, but your System will not post with them. I would suggest returning the RAM you purchased, and replace with 2 x 1GB DDR PC3200 400MHz non-ECC Unregistered Memory Modules. A matching pair is preferred.
If you receive a "Memory available limited to 256MB!" message after installing more than 256MB, enter BIOS (F2) and turn OS Install to OFF. Exit saving changes.Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.
You may also wish to update to the latest BIOS for this model from the Dell Support Site: http://support.dell.com/support/downloads/driverslist.aspx?c=ca&cs=cadhs1&l=en&s=dhs&ServiceTag=&SystemID=DIM_CEL_3000&os=WW1&osl=en&catid=&impid=
Jan 12, 2010 | Dell Dimension 3000 PC Desktop
I have a dell optiplex gx270, tried to upgrade my memory with samsung 1gb pc3200 ddr1 but doesnt work, just beeps on start up.
That is the correct memory module (Non-ECC).
Remove all memory modules.
Insert the one Samsung PC3200 module and start up.
If it doesn't boot, then try a different slot.
If it works ok, then add-in your original mamory modules. If they are PC2700, then they may not work together.
Oct 12, 2009 | Dell OptiPlex GX270 PC Desktop
New ram memory on dell dimension celeron trying to
You should check with the folks at Dell since whoever wrote their technical manuals for this machine can't do basic math. There are 2 memory slots and each can handle a maximum capacity of 512MB, yet they claim the maximum capacity for the machine is 2GB instead of 1GB. Using 512MB modules would probably work.
Jul 06, 2009 | Dell Computers & Internet
Upgraded Dell Dimension 3100 memory to 2 Gigs - Windows XP fails
Did you add the two sticks with the 512 or remove the 512 and add the two 1gb sticks? Try booting the machine with ONLY the 1gb sticks in.
Your machine supports 1gb modules but they can't be higher than 533MHz. Check that the memory you purchased was either PC3200 (400MHz) or PC4200 (533MHz) and is 1.8v. If you post the part number off of one of the modules I can look it up for you.
Feb 22, 2009 | Dell Dimension 3100 PC Desktop
Dell PE 1600SC invalid memory configuration detected
You may need to install memory in matching pairs. If the new memory is a single 1Gb module and you didn't already have a similar one they may not work together. Try removing the original module(s) and see if it makes a difference.
Oct 28, 2008 | Dell OptiPlex GX280 PC Desktop
How to install 1GB memory card ??
One slot is under a panel on the bottom of the machine, and the other slot is under the keyboard. Here's a link to the service manual for the 700m, it covers just about everything. If you need any further assistance, just ask.
Aug 19, 2008 | Dell Inspiron 700M Notebook
Installing memory
HI 1008 ,
It is very important to know which branded machine you have ; whether it's Dell , HP etc. I would also require to know the model number and whether you have a Desktop machine or a Notebook.
Anyways , here's a generic guide for your help...
http://www.helpwithpcs.com/upgrading/installing_dimm_memory_ram.htm
Goodluck :-)
Jun 05, 2008 | Acer Aspire™ T180 PC Desktop
Upgrading Memory from 256 to 1GB
You shouldn't have to remove it, but if the system won't boot after try reversing the slot, and if that doesn't work take out the 256.
Feb 03, 2008 | Dell Dimension 2400 PC Desktop
Dell Inspiron 700M Notebook Logo
267 people viewed this question
Alun Cox
