Question about Tripp Lite Lite Internet Office 500 UPS System
UPS shuts off
Several times my Tripp Lite UPS has turned off altogether. No home power problems. It simply turns off everything, causing the very problem it was meant to solve. I've looked at the log it keeps, and it shows nothing unusual. Says it was on Utility Power just before the problem occurred.
  • Anonymous Jan 15, 2009
    I'm having the same problem with a brand new Tripp-Lite HT850 UPS which I'm using as a power conditioner/UPS for my home theater components.
    With only my HDTV and cable box plugged into the battery outlets, the HT850 has, on several occasions, shut off its battery side suddenly without warning. This has happened with the plugged in components both powered on and powered off.
    Repeated self-tests alway succeed and never indicate an overload condition (besides, this has happened with my TV and cable box powered off, a total load of less than 30 VA).
    I called Tripp-Lite and they concluded that the unit is defective. They're sending me a new unit under warranty.
5 Suggested Answers
jvpacoin
  • 91 Answers
SOURCE: Tripp Lite SU2200 UPS has faults
For Tripplite UPS basically if the fault indicator is on you already have to check the power mosfets/IGBT on the circuit board. if you know the basic of UPS you dont need all those schematic diagram to check the thing. by the way, try to check your battery first if its still working. and if the battery is ok, go and check your inverter
Posted on Jun 04, 2009
gripfitter
  • 557 Answers
SOURCE: I had my UPS from Tripplite at least 4 years or
Battery is very easy to remove. Take it out and test it. If you dont have a meter to test it take it to an interstate battery store they will test it for you. They sell new ones should you need to purchace one.
Posted on Dec 13, 2009
SOURCE: unable to open the enclosure, how, no screws visible?
There are 2 (very deep) screw holes at the back of the UPS, but you'll need a long (8"+) philips screwdriver to access them.
Posted on May 13, 2010
SOURCE: have several Tripp Lite Omniplus
A little research on the internet will answer your questions about battery replacements and cost. There are numerous sites selling batteries for your particular unit. Do a Google search on the battery type and see what you get. EBay is another possible source for batteries once you determine which size and what ratings you need for your replacements. The best way of determining how to replace the batteries is to open the UPS's case and carefully record how you remove the old batteries and then install the new ones in reverse order. You will have to open the UPS up to get at the batteries to determine type and specs so removal and re-installation should be easy from there.
Posted on May 01, 2011
I have a Tripp Lite G1010USB uninterruptible power supply that only powers the surge surge-suppressor outlets and not the battery-backup outlets. Unless the UPS is unplugged from the wall, and then i
You know they have a TWO YEAR Warranty ?
Sounds to me that it is faulty (one of the relays or switches is not providing 'through' power to the supposed 'backup' socket when the AC power is on.).
Have you followed the manual ?
available here http://www.tripplite.com/support/model/mid/G1010USB
Have you done a 'self test' ?
'To Run a Self-Test: With your UPS plugged in and turned on, press and hold the MUTE/TEST button for two seconds. Continue holding the button until the alarm beeps several times and the UPS performs a self-test. See "Results of a Self-Test" below.
Note: You can leave connected equipment on during a self-test.' see manual
If the LCD does not give you the answer then it is faulty. Seems like something went faulty on restarting your UPS in the morning.
Seems like plenty of help available from this companys' website.
Sep 13, 2014 | Tripp Lite Ups Battery Backup G1010usb
Keeps going out
Glenn,
When was the last time you replaced the battery? That may be the cause.
If you need any UPS help contact Daniel @ Power & Systems Innovations 800.260.2259 or go to our website
www.psihq.com
Sep 17, 2013 | Tripp Lite Internet Office INTERNET550U...
I need a manual for Tripp lite omniplus 1000 lcd
Changing the battery
If your Tripp LIte Omni 1000 LCD display a fault icon and beeps after changing the battery, try the advice given by the buzzerman which worked perfect in this case:
1. Turn the UPS on. Press and hold the ON/OFF button for one second.
2. Run a Self-Test: Press and hold the MUTE/TEST button for two seconds (until beeps several times). The test will last 10 seconds. All LCD Display icons will be illuminated and the alarm will sound. At the end of this process the fault icon and the beeping turned off.
Feb 15, 2012 | Tripp Lite Tripplite Omniplus 1000 LCD UPS...
Only one side of the outlets work...
From the User Manual:
“OVERLOAD/CHECK BATTERY” LED: this red LED lights continuously after a self-test to
indicate the capacity of the battery-supported outlets has been exceeded. To clear the overload, unplug some of your equipment from the battery-supported outlets; then use the ON/OFF/TEST button to run a Self-Test. If the UPS continues to detect an overload, remove more equipment and repeat the self test until successful.
CAUTION! Any overload that is not corrected by the user immediately following a self-test may cause the UPS to shut down and cease supplying output power in the event of a blackout or brownout.
The LED flashes to indicate the battery needs to be recharged or replaced. If the LED flashes (and a continuous alarm sounds) during a prolonged blackout or brownout, the UPS’s batteries are nearly out of power; you should save files and shut down your equipment immediately.
If the LED flashes following a UPS self-test (after the UPS is turned ON), it may indicate that the battery needs to be replaced. Allow the UPS to recharge continuously for 12 hours; then use the ON/OFF/TEST button to run a Self Test.
If the LED continues to flash, contact Tripp Lite for service. Should your UPS require battery replacement, visit Tripp Lite on the web at www.tripplite.com/support/battery/index.cfm to locate the specific replacement battery for your UPS.
Hope this helps!
Jul 25, 2010 | Tripp Lite Internet Office INTERNET550U...
How do I set up my Ups? When I try to test it, it turns everything off. And when the power goes out, it shuts off everything.
You must install the software that came with your UPS on the computer that will be connected to the UPS, either via serial or USB. Within the software you can configure when to shut the computer down in case of a power failure.
Jul 10, 2010 | Tripp Lite AVR550U (AVR550U-EA) UPS System
Hello! I'm from Riyadh Saudi Arabia. I've left on my Tripp Lite UPS 1000 just last night. When I came in my office in the morning, my desktop computer including my computer server was OFF. I supprised that...
Unplug the computer. Then run the UPS self-test and the unit will display whether it finds an overload fault, whether the battery needs to be charged or replaced.
Here are the instructions (copied from the User Manual):
Turn UPS on: Press and hold the ON/OFF button for one second.
Run a Self-Test: Press and hold the MUTE/TEST button for two seconds (until alarm beeps several times).
If the fault icon remains lit, the battery-supplied outlets are overloaded. Unplug powered devices until you remove the overload.
If the "Replace" icon remains lit and alarm continues to sound, the UPS batteries need to be recharged or replaced. Allow UPS to charge for 24 hours and repeat self-test.
Jul 01, 2010 | Tripp Lite (OMNIVSINT1000) UPS System
I have a Tripp Lite Smart 1500 UPS. when I install the power shut down agent on the pc, I cannot open the main console because it asks for a login password. why is that so ?
dsquared911, The software wants to be certain that you and you alone are the person that is authorized to view the displayed information. You will need to visit the Tripp Lite web site if more information is required. The home office for them is located (half mile) due west of where the Chicago White Sox play baseball on 35th Street in Chicago. The phone number is 773-869-1234. Tripp-Lite also has software downloads and video clips at their web site. If this was of some help to you, please rate on fixya. Bye for now. 12fixlouie
Jun 15, 2010 | Tripp Lite Smart-UPS 1500 (smartint1500)...
After a short power outage (resetting breaker) the protected outlets no longer provide power. Is there a way to fix or do I need a new UPS?
The unit may need to recycle itself. Remove the loads and turn the unit off. Plug it back in, wait a bit, then turn it on. Then try your loads on it again.
Feb 18, 2010 | Tripp Lite Tripp-Lite HT1500UPS Home...
Smart pro keeps shutting down
it seems that the internal battery is bad, even if it is new but if it stays in the shopping store for long time it may become bad and not charge.
Dec 09, 2008 | Tripp Lite Smart Pro UPS System
Tripp Lite Lite Internet Office 500 UPS System Logo
325 people viewed this question
Top Tripp Lite Computers & Internet Experts
SHIVAJI YADAV
SHIVAJI YADAV
240cpa
Are you a Tripp Lite Computer and Internet Expert? Answer questions, earn points and help others
