Question about Apple iMac G5 Desktop
Replacing the hard drive on a imac G5 first generation
I bought a used imac G5 first generation. After a few months it was unable to recognize the hard drive. through some research I've conclude that the hard drive was fried. I thought I had the right drive and some online instructions. I purchased a 300GB Maxtor DiamondMax EIDE Internal Hard Drive. I was clearly wrong and out $100. The connecting pins are completely different and after opening the machine I discovered the previous drive attached to the computer some other, mysterious to me, way other that the three screws I found in my online instructions. Following is all I know about this machine:
Serial number: QP4470ATPP7
Name: iMac G5 (First model)
Model: M9249 iMac G5 1.8GHz
Bus speed: 600MHz
Family name: A1058
Screen size: 17 inch
Does anyone know the correct drive that would fit and know where I might find the proper instructions to change out the hard drive. I believe the previous drive was 80GB. I would like to go bigger if possible but I don't want to but the wrong drive again.
Thanks to anyone with the solutions.
  • 1 more comment
  • fogfocus Jun 28, 2008
    photo of my imac attached
  • fogfocus Jun 30, 2008
    The last response didn't clear up anything. The page he sent me to dose not dig down deep enough to specify the drives for different generation machines. Also these different machines have different instructions for removing the old drives than the one I have as I mentioned in the original question. I hope there is more to this service that I paid for than directing me to a to another web site.
  • martingeorg Jan 29, 2009
    I have the same problem. Did you ever find a solution.
    Master:
  • 638 Answers
Http://www.dtgeeks.com/index.php/features/tutorialview/imac_g5_hard_drive_replacement/
the above link wont let u keep on searching for u information but will directly get u the information on how to replace ur hard drive n wat type of hard drive will support ur machine.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
Posted on Jun 30, 2008
  • 4,889 Answers
If you want a 300GB drive..Its works great and has got great reviews except 1 or 2 bad ones. You will get the instruction manual along with the drive. Click on the link below to get it.
http://reviews.pricegrabber.com/hard-drives/m/22955782/
Let me know if there is something else you want to ask.
Regards,
Sai.
    Genius:
  • 1,847 Answers
  • Apple Master
  • 13,433 Answers
See here for imac g5 hard drive upgrade instructions
http://manuals.info.apple.com/en/imacG5_17inch_harddrive.pdf
Posted on Jun 29, 2008
  • 3 more comments
  • Ekse Jun 29, 2008
    If you look at the original disk and tell me the brand and model details.
  • Ekse Jun 29, 2008
    The original iMac G5 17" with a 40GB or 60GB took a regular ATA drive. The special drive carrier that is enclosed in the iMac holds the hard drive. Do throw this away, you will need it to put the new drive in.
    Any iMac G5 with a 80GB or higher takes the new SATA drives.
    20" iMac G5 all take the new SATA drives.
  • Ekse Jun 29, 2008
    heres what the connectors should look like if it uses sata
  • Ekse Jun 29, 2008
    looking at the manual I can see its sata - you need a sata type drive.
  • Ekse Jun 30, 2008
    If you have any questions let me know, if everything is clear please accept my solution.
    Thank you,
    Ekse
  • 75 Answers
  • speed matters, too, and the quickest way to get a handle on speed is by asking how fast the drive spins. After all, a 7200 rpm drive has to move data faster than a 5400 rpm drive - or does it?
It's Not That Simple If you've been following the story over on Macworld about different benchmark performance between the 2.0 GHz white MacBook and the 2.0 GHz black one, you might be scratching your head. Except for the hard drive, the two 'Books were configured identically, yet some Speedmark results were quite different.
The MacBooks, like most computers made today, can ship with drives from any of a number of vendors, and Apple has made it easy to swap the hard drive in the MacBook. By slipping a 7200 rpm drive into the black MacBook, it came very close to matching the 5400 rpm drive in the white MacBook.
What's up with that?
My first thought was that perhaps one of the drives had a bigger cache than the other one. I've seen a big difference between 7200 rpm drives with 2 MB and 8 MB caches with my eMacs.
But as I read further, I saw that both drives had 8 MB caches, yet the 5400 rpm Seagate was edging out the 7200 rpm Fujitsu in several tests.
Digging Deeper In the world of notebook computers, 4200 rpm drives used to be the norm, and the first 5400 rpm drives provided a huge speed boost (they spin 28.5% faster). Jumping to 7200 rpm spun drives 1/3 faster than that, but that's not the whole story.
Another way to make drives more responsive is to add a buffer. In the ancient days of personal computing, drives simply read their data and dumped it over a bus to the computer as fast as they read it. Old timers may recall setting the interleave for drives used with the Mac Plus, SE, and II - and wonder why we no longer do that.
Setting interleave slowed down data transfer to a speed these old computers could handle, and then someone came up with the clever idea of building a data buffer (or cache) into the hard drive. Now the drive could read the data at full speed, store it in cache memory, and feed it to the computer at the top speed it could receive data.
And that's why one of my favorite Mac SE speedups is putting in an hard drive with a buffer to replace the ancient bufferless drives Apple used back in 1987.
And the bigger the buffer, the more data in the cache, the more efficient the process.
On top of this, there are different schemes for storing data in the buffer. A drive may look ahead a few sectors, or it may buffer the directory, or it may buffer writes, all of which can make things more efficient.
Physics That's drive electronics, and every brand has their own way of doing things. So you can see why a Seagate, Hitachi, or Fujitsu mechanism might offer different performance despite having identical spin rates and buffer sizes.
But there's a third factor beyond RPM and cache size - data density. Looking at the manufacturer's specs for 5400 and 7200 rpm 2.5" Seagate Momentus and Hitachi Travelstar drives, you'll see that the transfer rate of the 7200 rpm drives is less than 1/3 faster than the 5400 rpm drives - just 9% faster for the Seagate, and a more impressive 28% faster for the Hitachi.
The big breakthrough over the past year or so is perpendicular recording, which can easily store 50% more data per track. Just how much data is there per track? That's hard to know, in part because the manufacturers don't promote the number and also because the amount of data stored per track varies between the inner and outer tracks of a drive platter.
Still, if Drive A spins at 5400 rpm and stores 40% more data per track then 7200 rpm Drive B, it will be able to read more date per second. That might help explain how a 5400 rpm drive can sometimes outperform a 7200 rpm one.
Conclusions Tech Report has an extensive article comparing these four drives. It looks at peak transfer rate, how well each drive handles multiple data streams, and typical read and write speeds. And just as Macworld discovered with the MacBook and both brands of drives, Tech Report says, "At times, those performance differences were surprising, as we certainly didn't expect to see Seagate's Momentus 5400.2 beating Hitachi's Travelstar 7K100 in so many tests."
Various drive parameters can be tweaked, optimizing a drive for use by a single user or in a server, even optimizing for the way an operating system works and how many data streams it may work with at any given time.
In the end, there's more to picking a hard drive than capacity, rotation speed, and buffer size. Seagate, Toshiba, Hitachi, and Fujitsu each have their own buffering algorithms and optimization schemes, so you'll want to look for benchmark results using the hardware and operating system you'll be using. (OS X on Intel Macs may produce very different results than OS X on a G4 or G5 system.)
Price is the final factor (after all, Low End Mac is primarily about value). If ultimate performance isn't crucial and the 5400 rpm drive is a lot less costly, it may well be a better choice for you. But in the end you have to come up with your own value equation - how important is capacity vs. performance vs. price? Replacing the hard drive on a imac G5 first genera - bullet.gif
Imac wont recognize my new internal hard drive
Yes, rem it is iMac, it has to be formatted for iMac, sorry there is a way, if you have alternative access, search box and type in formatting new had for iMac. Good luck.
Feb 08, 2013 | Apple iMac G5 Desktop
I would like to know if an older hard drive from imac model A1076 could be installed in a slightly newer imac, model A1145 and have it be compatible and working with no problems?
Hard drives are universal, and based on physical connection / type. So your older HD should work even if you have newer SATA connection. The connection is backwards compatible.
Dec 08, 2012 | Apple Imac G5 20" Als G5 2.0ghz 2gb-ram...
I Have a Hitachi Lifestudio hard drive attached to my Apple G5 for 7 months now, and suddenly just dessapear of my desktop or menu the Computer it won't recognize it anymore HELP!!!!!!
ry connecting the external hard drive to another computer to recover/backup your data.
When you have such a large capacity hard drive, it pays to have a second large capacity hard drive to backup your data in the event of the other hard drive dying.Hard drives do fail especially if you accidently drop it.
Jun 07, 2012 | Hitachi Lifestudio Desk Hlsdbub5001bbb 500...
Connecting external microphone to imac g5
Get yourself a great little gadget called iMic. It's a usb connector that adapts to let you used your headset mic and the mac system os will recognize it very well. Works good .
Costs about 24 bucks or so..
K
Jun 19, 2009 | Apple iMac G5 Power Supply 661-3351
Imac g5 is not turning on. LED1 stays on. I tried resetting the SMU and it didn't work. LED2 flashes on and off making a chirping noise. What could this be
Hello, Sorry to hear you are having troubles,
Is this a 17” iMac G5, if it is, and I think it is, unfortunately, this iMac model was generation 1 of the all in one flat screen design and it's a bit of a Lemon... The hard Drive overheats the video card and the power supply. With time, these 2 elements burn out.
What you have sounds like the power supply. it's a $300 repair, but, it might not be a good investment for you, the new power supply won't last much more than the first one and your video chip won't last much longer....
Best put the money and put it towards a new machine.
Sorry bout that.
Apr 01, 2009 | Apple iMac G5 Desktop
17" iMac quit working
Your Imac may be one of those affected by Apples purchase of inferior capacitators from Taiwan. If you are less than 3 years from the purchase date, apple will repair the problem for you for free. Just take the unit to your nearest local Apple Genius or tech. If you are outside of the repair extension guidelines, I have provided a link here which can show you or someone more skilled how to repair the problem. Ordering a new motherboard and power supply will set you back a lot of money, however the following guide and pdf give you step by step instructions on how to ressurrect your dead imac without speding more than $100.00. I was able to repair my imac using this guide and it was worth it to save a $2k computer that was only 3 1/2 years old. Check it out:
the following information (in italics and bold)  is taken directly from: http://www.jimwarholic.com/2008/07/how-to-repair-apple-imac-g5.php.  (this site is complete with instructions, manual and the full compliment of materials available at an extremely affordable and fair price. I took a chance and repaired my own, it is not as hard as it sounds1)
The iMac G5 Repair Extension Program for Video and Power Issues applies to first generation iMac G5 computers that have video or power-related issues as a result of a specific component failure. If your iMac G5 is exhibiting any of the symptoms listed below and your computer's serial number is within the noted ranges, your computer may be eligible for repair, free of charge. If Apple or an Apple Authorized Service Provider (AASP) determines that your iMac G5 computer is eligible as part of the program, the repair will be covered by Apple for up to three years from the original date of purchase even if your iMac G5 is out of warranty.
This is a worldwide Apple program.
Affected systems will exhibit one of the following video- or power-related symptoms:
Scrambled or distorted video
No video
No power
Note: If your iMac G5 is not experiencing any of these symptoms, you do not have to contact Apple or any Apple Authorized Service Provider.
Which iMac G5 computers are affected by the iMac G5 Repair Extension Program for Video and Power Issues?
The program is available for certain first generation iMac G5 models that were sold between approximately September 2004 and June 2005 featuring 17- and 20-inch displays with 1.6GHz and 1.8GHz G5 processors.
The affected iMac G5 computers have serial numbers where the first 5 digits fall into the ranges noted below.
Serial Number ranges:
W8435xxxxxx - W8522xxxxxx
QP435xxxxxx - QP522xxxxxx
CK435xxxxxx - CK522xxxxxx
YD435xxxxxx - YD522xxxxxx
Some second generation iMac G5 computers have serial numbers that fall within the upper band of the ranges listed below. Only first generation iMac G5 computers are affected by this program.
Where do I find the serial number of my iMac G5?
The 11-digit serial number is located on a label under the foot of the iMac G5. There is a bar code underneath the serial number.
To view the label, hold the sides of the iMac and gently lay the computer face down on a soft, clean towel or cloth.
Is the iMac G5 Repair Extension program available for other Apple computers?
This program applies only to the systems noted in this FAQ. Other versions of the iMac G5 line are not part of this program. Click here for more information on how to identify iMac G5 models
Free guide for how to repair the motherboard capacitors, rescue the hard drive and more.
http://www.jimwarholic.com/docs/Repairing-Apple-iMac-G5-Motherboard.pdf
Feb 22, 2009 | Apple (661-2795) for iMac Motherboard
Changing a hard drive on third generation imac
After a bit of confussion by what you mean by 3rd Gen and Aluminum and glass I've decided to give you two guides and you can choose which one you actually mean.
http://uk.youtube.com/watch?v=0_u4FhDP6-o&feature=related
http://uk.youtube.com/watch?v=1tt8Jky3RQY
One of those should help you out.
All the best
Sean
Dec 18, 2008 | Apple iMac G5 Desktop
Playing PS2 on apple iMac
if the iMac is one of the computers with the slot-load drive (you don't load the disc into a tray before it goes into the computer), then placing a disc smaller than a regular CD/DVD will damage the CD drive and will be very hard to remove.
you could buy an external CD/DVD drive and then use smaller discs with the iMac.
Jun 10, 2008 | Apple iMac G5 Desktop
External Hard Drive won't show up!
i have a 500gb WD external drive and it wont show at all
Mar 09, 2008 | Seagate (ST9100801U2-RK) (9W3638556) 100...
if its usb then i have a feeling its not the hard drive thats bad i think it sounds like the case .
you can try buying another case and transfering the hard drive to it the case is around $20.00
Nov 19, 2007 | Fantom Titanium-II (TFD200U2) 200 GB IDE...
Apple iMac G5 Desktop Logo
4,675 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
