Question about HP Office Equipment & Supplies
I have a hp officejet pro L7680 all-in-one printer.2007. I got new ink hp 88 combo pack & hp88xl black, but everything prints in pink color where the color part should be what ever the color is on the paper.HELP Carolyn Duncan
  • carolynkd3 Jun 28, 2008
    I ran all 3 test, nothing has changed.
    No the black is black but the color thats suppost to be red is pink
  • HP Master
  • 1,879 Answers
Greetings,
Re-seat all toners.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jun 28, 2008
    Guru:
  • 1,894 Answers
Do you mean that the whole print is printing in PINK color..
is that correct?
  • HP Master
  • 2,794 Answers
Go into the control panel in windows, select printer and select the properties for your printer.
Push the printing preferences button
Select services
Select service this device.
Press the device service tab.
Run all three tests.
Alignmet, Clean and print a test page.
  • Tim Babcock
    Tim Babcock Jun 28, 2008
    I know this isn't toner because 88 is an inkjet.
    Were these cartridges refilled?
  • Tim Babcock
    Tim Babcock Jun 29, 2008
    The tricolor cartridge could be defective. It could be that the inks got mixed up in the compartments (like the magenta and yellow). A lot of times they are returnable if you purchased them right away.
Hi. I replaced the black cartridge (yellow almost empty) but if I print a page (only black, the printer skip some lines. Can you please assist me? Surene Whiteman
Printer contain 4 cartridges and 2 printeads. Because the black color skip some lines as you mentioned you need to replace a new printead(not the cartridge) No:88 Black/Yellow color one. For more information visit the following link: http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=&cc=us&docname=c00841890&product=2512009
Jan 24, 2013 | HP Officejet Pro L7680 All-In-One Printer
My HP OfficeJet L7680 just stopped printing ANYTHING black. I change the black cartridge twice.I cleaned the printer heads, aligned it and still it will no longer print anyhting in black. When I do a test...
It sounds like your printer setup has changed to generating black by MIXING the color inks... if you run out of the cyan and yellow it will do red in spite of how many changes you make of the black cartridge.
Investigate the setup for the printer to make sure it is set for black from the black cartridge.
Apr 15, 2010 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7650 Print head problem
The reason why the printer refuses to print if you get low on one or more colors is that the system runs off negative pressure through the ink lines to the print head. If you were able to continue printing with an empty cartridge you could get air in the respective ink line, disrupt the negative pressure, make it so that that color will no longer print, and require you to get the printer serviced to fix the problem. I own a Cartridge World ink refilling store and I feel this is a good machine (compared to some of the others out there). The only down side with this type of machine is the print heads expiring or getting clogged as you are experiencing. The reason the black is clogged and not the other colors is that the black ink is pigment based and the colors are dye based. The pigment based inks do tend to clog print heads over time. You can try to rehydrate the print head with warm distilled water. if you can't get it working to your satisfaction you can buy a new black/yellow print head for $72. With this type of printer you should print at least one black and white and one color document per week to keep the print heads fresh. If they sit too long without ink flowing through them then they can get clogged and print poorly. I hope this helps belay some of the resentment you hold towards your printer.
Nov 22, 2009 | HP Officejet Pro L7680 All-In-One Printer
Prints only from color cartridges, black ink not working
The problem is in the print head.It's clogged or damaged.You need to replace it.It's part number is C9381A - HP #88 Printhead - Black and Yellow
Nov 01, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
L7680 printer was working fine. It stopped printing black but will print all other colors. I just replaced the black ink cartridge and it still won't print black. Do you know the fix for this?
If you print primarily black, your black/yellow printhead may have worn out and needs to be replaced. Go to start, printers and faxes, select the L7680 and then select properties. Print a test page and run the troubleshooter to clean the nozzles and lines. If it's not the nozzles or lines, search for C9381A on google and purchase a new printhead it should be about $70.
Oct 30, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP K5400 will not print black
Check the black/yellow print head.If necessary replace it.It's part number is C9381A, #88
Oct 13, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
HP Problem Printing Black
Try to reinstall your printer.
Check your black cartridge if they are installed properly.
Replace your black cartridge with a new one.
Aug 17, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP officeJet Pro L7680 will print in color but without any black.
I have the same problem with my Officejet Pro L7780, so you are not alone. Have you found any solutions?
Jun 03, 2009 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet L7680
i say change the print head an the cartrige an that should be find
couse i did an my printer is perfect
by andrew
Feb 05, 2008 | HP Officejet Pro L7680 All-In-One Printer
94 people viewed this question
Ben Johnson
