Question about Dishwashers
Kenmore dishwasher making whistling noise - Dishwashers
  • Anonymous Jul 13, 2008
    kenmore dishwasher making whistling noise
Could be a clogged spray arm... take it out and give it a good cleaning. That might help.
Posted on Feb 05, 2010
Brand new Kenmore mini fridge is making an annoying whistling noise
If Sears did suggest a solution for the symptom you describe it would probably be to replace the fan.
Nov 21, 2013 | Kenmore Refrigerators
Kenmore dishwasher whinning noise
seems your motor is making that sound try first lubricating it
Mar 15, 2008 | Dishwashers
Makes a whistling noise when in use
I had a problem with my LG dishwasher and there was a small stainless steel impeller that they had to replace to stop the high pitch noise. I think this impeller grinds up any food particles. The tech said if one of the veins bend it causes this issue.
Feb 10, 2013 | LG 24 in. LDF 7811 Built-in Dishwasher
Whistling noise when cooling on Kenmore built in oven model #790.48783900
These types of ovens are complex to troubleshoot and repair. I would contact an appliance tech.
May 23, 2012 | Ovens
My 1yr old dishwasher is makes a whistle noise
Hi jgonsalves,
Please check my following tip for the full solution to your problem.
Click here -> L.G E1 Error / Whistling Sound
Kind Regards :-)
* If you found this solution helpful, please rate it.
Jul 06, 2011 | LG LDF6810ST Stainless Steel Built-in...
Intermittent loud noise
more than likely is the pump the noise your hearing is most likely the bearings or the coling bladed on the motor
Jul 26, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Why does my Kenmore QuietGuard Dishwasher Whistle?
Is it during the wash cycle? That is air getting past the drain flapper. If you install a trap in the drain line it should go away.
eric
Jun 29, 2009 | Kenmore Dishwashers
Our LG LDF7920st dishwasher (6 months old)makes a whistling noise
Hey, consider the float assembly!
We bought this dishwasher and ran it for the last 1 1/2 months and it made a grinding and whistling sound from day one (it's supposed to be nearly silent in its operation). Turns out the drain pump was cutting in while the machine was still filling, thereby emptying the wash tub of any water. Then, when the cycle proceeded to wash, the dumb thing had no water and made a horrible noise. So I had to pitch in at least 2-3 litres of hot water, and then it worked quietly! Had to do this every time there was new water intake.
After working with the repairmen - four visits later, we isolated the float assembly as the problem and they set about replacing the part. Turns out the two parts were markedly different. LG HAD INSTALLED an older model float assembly at the factory and it was the problem. The replacement part was the correct float assembly and things worked perfectly after that - thank goodness. No more babysitting the dishwasher.
Don't let anyone tell you the motor assembly needs replacement. I have seen that cop-out 'fix' all over the web. But use deductive reasoning to find out where the problem is in the cycle, and explore this option first - it's a quicker and cheaper fix than replacing the whole motor assembly.
'Mr. Float' as he is now called works like this:
-expels any residual water in the tub from the last wash
-intakes water for the wash or rinse
-whirs 2-3 times prepping for the cycle
-begins to wash, quietly
-expels at the end of the wash or rinse.
He used to:
-expel residual water
-intake new water for wash or rinse
---drain pump would cut in WHILE still filling
-machine would whir once, realize it didn't have enough water
-perform a brief top-up intake shot
-begin to wash and whistle and GRIND (this is where I would have to add the water)
-expels water from wash or rinse, and start all over again.
It's a good dishwasher and it will work, but the right model parts have to be in place!
Jun 27, 2009 | LG Dishwashers
Kenmore Quick Clean loud whistling noise from air exchange
Sounds like you may have a clog or restriction somewhere in the vacuum.
Oct 08, 2017 | Kenmore 34720 Upright Vacuum
Dishwashers Logo
1,153 people viewed this question
Top Dishwashers Experts
