Question about Konica Minolta DiMAGE Z10 Digital Camera
**** camera yes it is an SD card and yes i tried formatting it. i got an estimate from sony on repairs, parts, labour...180, so i will just buy a new one and give up on this one. thanks for your time.
    Scholar:
  • 39 Answers
Yeah I would suggest not investing that into it.
Sorry:(
Good Luck to ya,
-Caleb
Posted on Jun 29, 2008
My nikon d300 will not format the SD card....
Hi, Dear
Nikon D300 does not use SD card! It use CF card.
But if you have format problem in camera then I recommend format from a computer using memory card reader. And then put the memory card into camera and try to format! Here it does not, then you should show to your local repair shop and it will cost between $120 to $265 usually. In minor problem case it will be replacement of memory card acceptance unit replacement. But the problem come from main pcb then the estimate will be totally different!
Hope You Luck! A Professional Camera Clinic Guy
Apr 05, 2015 | Nikon Cameras
What type sandisk mirco sd cards work?
You didn't buy a microSD card, you bought a microSDXC card.
The Eclipse 180 works with microSD cards (2GB or smaller) and microSDHC cards (32GB or smaller). It does not work with microSDXC cards.
Jul 26, 2014 | Mach Speed Eclipse 180 MP3 Player
Initialisation of SD card for Fujifilm S2950
Insert the SD card, power ont he camera, hit Menu, then left arrow, down arrow, right arrow, down to format.
Dec 05, 2011 | FUJIFILM FinePix S2950 / S2990 Digital...
Hi, my g1 has problem to read the sd card, when i try to use the camera, the phone says it does´nt have, and windows XP do recognize the phone
Need a little clarity on what your saying XP does recognize the SD card when you mount the phone to the computer, or it doesn't?
Well here is what you can try. and just remember ALWAYS ALWAYS ALWAYS do this before removing your SD card from your phone.
Settings>SD card & phone storage>Unmount SD card
Now if your phone has "Unmount SD card" blacked out then don't worry about just go ahead and remove the SD card.
Take the card and put it in a card reader and put it in your computer. Go to: Start>My computer> (and the drive corresponding to the SD card.) and then try to open it. If a window comes up saying something like drive E: is not formatted, Format now? and then Ok or cancel well if this comes up it could be one of three reasons; the SD card is not properly formatted, SD card is damaged, or the SD card reader is not working properly. So before trying to format the SD card try another card reader or try it on a different computer. If that doesn't work try to format the SD card. If formatting the SD card doesn't work, you may need to buy another one. If you do decide to get another one check Amazon.com they have good prices for the SD cards however if you prefer local buying best place to go (that I've found) is Radio Shack. They always have sales on the MicroSD cards. One other thing. For some reason. SanDisk Micro Sd cards seem to work the best for the G1. The transend cards are utter **** and worthless. Avoid buying them anytime your in the market for a new SD card or USB flash drive.
If you need further help feel free to check out xda-developers.com
Aug 07, 2010 | HTC G1 Smartphone
Lumix DMC-LC33 shows memory card error -format this card? Yes or NO..no matter the Sd card , if select yes- no results, if select no - no results.
This normally happens when the memory card gets corrupt. Hope you have pressed OK after selecting YES. Check whether the card is locked. SD card has a small Lock button on the top left. If this fails, buy a new SD card and format it in the camera before taking any image.
Dec 13, 2009 | Panasonic Lumix DMC-LC33 Digital Camera
Can not record to sd card
Hello
Thank you for using
FixYa for your problem
Try a different SD card & a
lways check the batteries first but if is it still giving the same fault, your camera is faulty. It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 30, 2009 | Panasonic AG-HVX205A Camcorder
Trying to install memory card did format and
Although you haven't stated the make, model and capacity of your memory card the information in your question suggests that you have used the wrong memory card.
The CD33 is compatible with SD memory cards but not with the later SDHC models (the HC means High Capacity). They'll fit into the camera just fine as they have the same shape as an SD card, but the CD33 chipset is incompatible at the basic hardware level and cannot format SDHC cards.
To complicate matters further, the original SD specification allowed up to a maximum 2GB, and this was later extended to 4GB but hardly any SD devices can use the 4GB cards without a firmware update. No firmware update was ever released to allow your camera to use 4GB SD cards. Your camera was also designed before 2GB SD cards were available so whilst it may be compatible in theory it was never tested with them.
I'd recommend that you stick to 1GB maximum SD cards unless you use a Kodak branded 2GB version: Kodak's website claims that your camera should work with their own brand card of that capacity, so if it doesn't you can claim on their warranty for a refund or maybe an exchange for two 1GB cards.
If all this is incorrect and you're using a regular SD card of no larger than 1GB then you either have a faulty card or a faulty camera. The only way to find out will be to try a new 1GB SD card from a major brand name. If the camera proves to be faulty then it's beyond economic repair as labour costs for diagnosing the fault alone will exceed the camera value.
I hope this reply has been of assistance and ask in return only that you rate my answer.
Nov 10, 2009 | Kodak EASYSHARE CD33 & Printer Dock Series...
My cam takes the compact flash card. i just bought a new card. after i put it in the cam,the cam wanted to format it, i chose yes then the cam said it couldnt use the card. i bought another card and it did...
Probably a bend, or broken, or 'pushed in' pin in the CF slot. Its a costly Sony Service shop repair
In future get a camera without all those delicate pins! (SD)
Oct 20, 2009 | Sony Alpha DSLR-A100 Digital Camera
Memory Card Error
Is the slide switch in the unlocked position? Have you formatted the cards in the camera before trying to use them?
Sep 17, 2009 | Canon PowerShot S3 IS Digital Camera
Transform Duo Stick into an SD card ~ Possible?
Hi Qwin,
Although you cannot directly use your Duo Stick in a camera which supports SD, you are able to purchase a memory card reader to support both formats. This means that you can transfer data from the Duo Stick or the SD onto your computer, and then put the data onto the other card.
Thank you,
Jason,
Go Ahead. Use Us.
Jul 09, 2008 | Canon PowerShot SD550 / IXUS 750 Digital...
Konica Minolta DiMAGE Z10 Digital Camera Logo
54 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
