Question about Epson Stylus CX5800F All-In-One InkJet Printer
Clicking nosie from scanner bed on epson cx5800f
Printer does not power up. scanner bed emits a clicking noise and printer display says PLEASE WAIT forever. It is like the scanner bar is stuck and trying to move. How do I remove the scanner bed from the unit spo I can check out the scanner bar and gears.
Unit is out of warranty.
I had a similar problem, the scanner bar was stuck to the far left side. Here's how I fixed it:
1)Unplug the printer, disconnect any cables/phone lines to it.
2)Lift up the entire scanner bed housing(you will see the printer ink cartridges).
3)Locate the access patch (approx 1 cm x 1 cm square) along the left edge of the scanner bed housing(this is the side that closes in, next to the keypad buttons).
4)Using a small knife blade, peel off the patch from the corners and edges(it's sticky. Save it, you can stick it back over the hole when you're done).
5)Stick a pen through the access hole, and push the scanner bar to the right, approximately 2-3 inches.
6)Now, close the scanner housing, plug in the printer, and power it on.
It should reset and re-calibrate the scanner bar. If it doesn't, repeat steps 5) and 6) a couple times, until the printer correctly performs calibration. Then, you can put the sticky patch back over the hole, and you're ready to go. Hope this helps!
Posted on Jul 03, 2008
  • Epson Master
  • 2,794 Answers
Usually scanners have a locking mechanism on them. Make sure it is unlocked.
Posted on Jun 28, 2008
How to scan a picture?
1. were you able to install the printer software correctly? if yes, please check the epson software in the program files if there a scan/imaging applicatoin installed.
2. if you have adobe photoshop. click import then select your scanner device. it will popo out the scanner software..
Jun 13, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Install printer
Hello sir; If your computer with wizard software then follow the step to install; turn on computer,,& printer and hook up together , click on "start "then go to 'setting", select " printer & fax, then go to adding after that the wizard box will display you just follow the instruction to finish your installation.
Feb 02, 2010 | Epson Stylus CX5800F All-In-One InkJet...
How do I turn on scanner function on epson cx5800F series
download epson scan and install it to your computer. go to and choose your site and model to have the sufficient driver you need
Sep 23, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Remove empty print cartridge
Turn the printer on, when time is displayed press the setup button. Press the up/down arrow buttons to get to "5. replace Cartridge" and then press OK. Open the scanner unit and lift the lid off the ink carriage unit. Remove the empty cartridge and fit the new one. Make sure the cartridge and carriage cover click down into place, close scanner unit and press OK. The user guide with pictures can be downloaded fro Epson here:
Please take a moment to rate this solution, thanks.
Apr 01, 2009 | Epson Stylus CX3200 All-In-One InkJet...
How to use scanner on a Epson Stylus CX5800F
follow this link --
Dec 25, 2008 | Epson Stylus CX5800F All-In-One InkJet...
Epson Stylus CS5800F Printer will not power on. Plugged into known working outlet, but no luck.
I had that same problem with my CX5800F. I tried it in several working outlets and shut down/started up many times. Tech support couldn't figure it out so they had me sent it back for a replacement. Several days later, before I packaged it up for shipment, I decided to test it out one more time, and it powered on! I sent for a replacement anyways. Since it's still under the 1-warranty, I'd suggest sending it back for a new one if all else fails. Good luck!
Nov 06, 2008 | Epson Stylus CX5800F All-In-One InkJet...
I need a cd
thats ok tell him to go to website download latest driver anyways ok work better for him thx nick
Feb 10, 2008 | Epson Stylus CX5800F All-In-One InkJet...
Changing ink cartridge/s
The scanner cover is on one set of hinges. Below the scanner bed, you can lift the front edge and the scanner bed will lift up on another set of hinges. Do not attempt to manually position the ink cartridge holder to replace individual cartridges, but follow the instructions from the print dialogue box, under Epson Printer Utility and Epson StatusMonitor.
Dec 11, 2007 | Epson Stylus CX5800F All-In-One InkJet...
HP Officejet 6110 scanner carridge appears stuck
Unplug the power. Plug back in, while simultaneously holding hash (#) and (6) buttons, until S-reset is displayed (sometimes this can take like forever) but it is a documented HP mode.... Then set up machine using 1 key to confirm options and arrow keys to select options.
To enter another maintenance mode (fat lot of good that will do you), press and hold * and #, then press 1 and then 2 and then 3 (or 5) for a variety of different options, which include testing of the scan bed. This of course only works once the scan bed has initialised...
Or: take out all cartridges and close doors. Wait until it complains, or indicates a cartridge jam.
Oct 20, 2007 | HP OfficeJet 6110 All-In-One InkJet...
Epson Stylus CX5800F All-In-One InkJet Printer Logo
544 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
