Question about Sanyo Microwave Ovens
To buy the microwave turntable - Sanyo Microwave Ovens
  • Sanyo Master
  • 9,086 Answers
Please reply back with your brand and model number so we can help you.
Posted on Jun 29, 2008
JennAir JMC7000ADW Microwave Oven Turntable not turning
Check the turntable guide to make sure it is lined up properly and that there is no debris caught in it. You may need to re-align or clean your turntable guide.
Cleaning and realigning a turntable guide;
Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable.
With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing.
Test your microwave after this thorough cleaning and realigning in order to determine whether this has solved your problem. DO NOT run your microwave with nothing in it.
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
Also, Examine the plastic drive bushing the turntable tray sits on. It may have become worn, or even may have split in two;
Drive bushing replacement
Inspect the plastic drive bushing located below your microwave oven's turntable tray. There may be some debris blocking the tray's range of motion. Clean away any blockage you find, and then test your microwave to see if this has cleared up the problem. DO NOT run your microwave with nothing in it.
However, if upon your inspection, you notice that the plastic drive bushing below the turntable tray is worn and/or broken, you will need to have the bushing replaced. Consult with a certified and experienced appliance repair technician. Replacing a drive bushing is a lengthy and involved process that the average layman should not perform.
Good luck.
Dec 17, 2011 | Jenn-Air JMC7000 Microwave Oven
I need a turntable plate for a Sylvania microwave Model # P70D20AL-D5.
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Aug 25, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I need to buy a new glass turntable for my Kenmore Elite Model #721.66463 microwave. How do I find the part number. There are several turntables available
The correct part # is 3390W1G006.
You can contact Martin Microwave Inc. @ 1-877-894-0035. They carry the tray in stock, but it's not listed on their website (www.microwaveglasstrays.com) .
Nov 09, 2010 | Kenmore 64683 Microwave Oven
I have a GE Spacemaker II microwave: JEM25GY that died. It seems less expensive to replace rather than fix. Power works; it doesn't heat. New models all apparently have turntables; mine didn't and I...
YOU CAN TRY REMOVING THE GLASS TRAY AND TURNTABLE AND REPLACING IT WITH YOUR OLD GLASS TRAY (IF YOU HAD ONE) OR JUST ANY GLASS MICROWAVE TRAY. WITHOUT THE TURNTABLE, I CAN'T SEE HOW IT CAN ROTATE.
Nov 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Where can I buy a turntable motor for a Delonghi AC925EQK microwave. The motor is a Hengxing TYJ50-8A7 220-240v 4W 4RPM
Don't know if you got your motor or not, but I've just ordered an identical part number from ebay - search for "microwave turnable motor".
It is advertised as a Panasonic part but has the exact part number you want.
Jun 21, 2009 | DeLonghi Microwave Ovens
Turntable 'ring' has little wheels are all worn flat on one side and it will not turn.
MicrowaveSvc - Thank you so very much for coming back to me re the worn down wheels on the turntable ring. Fortunately however, I managed to buy three of these rings, all different sizes and tied together, in a junk shop for 10cents!! My husband then cunningly removed the wheels from the one that were most like ours and placed them onto our ring. Hope this makes sense. The microwave is now working perfectly, necessity being the mother of invention! I will take note of this site however!! Thanks once again for your interest in a microwave turntable ring in a motorhome in New Zealand!
Sandre Bowe.
Nov 02, 2008 | LG LRM1250 Microwave Oven
My turntable stopped running
If you didn't buy the turntable motor then I assume you purchased the coupler ( white plastic/nylon piece that fits into the turntable motor collar and rotates the platen? Is that what you purchased?
Sep 13, 2008 | GE JES1384SF Microwave Oven
Emerson Microwave
Shalene Naig
snaig@rvtc.net
2873 410 Avenue
Graettinger, IA 51342
7128593720
I'd love to buy your glass turntable/
May 11, 2008 | Emerson MW8168B Microwave Oven
Microwave Ovens Logo
27 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
robert landry
Greg Cann
Greg Cann
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
