Question about Lands Phones
I dropped my tracphone on my foot and now it wont work.
  • jp535 Jun 28, 2008
    Can it be fixed?
    I figured how to to fix it. It wasn't broken after all.
I discovered that if you hold the button with the red phone on it will come back on.
Posted on Jun 29, 2008
My foot pedal wont work. it beeps but wont run machine
If your machine beeps, it's telling you that you've forgotten to do something...like maybe drop the presser foot? Check the owner's manual instructions.
Jan 02, 2018 | Sewing Machines
NEED TO GET PIC OFF PH ONTO MY COMPUTER I TRYED BEMAILING THEM TO MYSELF IT DIDNT WORK HELPI HAVE A LG440 TRACPHONE NEED PICTURES PUT ON MY LAPTOP COMPUTER
Hi, Janet,
There is no need to shout. Connect your phone to your computer using the supplied USB lead, then just drag and drop the files using Windows Explorer, or its equivalent in your own OS.
Dec 08, 2017 | Cameras
Can I use a tracphone without tracphone?
If both companies use sim cards then "YES" you can!!!
Jan 13, 2016 | Cell Phones
Verizon store where I bought my new iPhone 5c could not port contacts from old Tracfone or from my iPad to new iPhone. iPhone doesn't ring either, going directly to voicemail.
they wont be able to move the contacts from the tracphone unless it was an iphone tracphone because other phones have a different OS. your going to have to delete the current email on the phone then put the one you're trying to use on it. Now the ringing part i would check with them to make sure your provider isnt having your calls forwarded straight to your voicemail. hope this helpped
Jul 27, 2015 | Apple iPhone Cell Phones
Www.tracfone.com/
Please have SOME modicum of patience, Eugene. There are millions of other people trying to do the same thing.
Aug 12, 2014 | Cell Phones
I undid the screw of the foot shaft without a foot on it and the shaft dropped to the plate. I have levered it up and put foot on but the foot wont lift, can you advise me how to fix this please?
there two holes on the side plate where the presser ft bar is located. take off the rubber cover and a screw will be visible. this screw controls the presser ft. height and angle of ft. place ft all the way down and cnter needle in foot slot and them tighten screw. use an long screw driver because u get more leverage. in fact long screwdrivers are the only thing to use on machines. every one should be ground to fit the different screws. anyway raise the foot to see how much clearence u have and adjust accordingly.
Aug 06, 2014 | Juki DDL-5550 Industrial Straight Stitch...
Tracfone customer service
ring the tracphone customer support line and ask them to port your old tracphone number to your new tracphone
https://www.tracfone.com/faqs/phone_upgrade/PHONE_UPGRADE?lang=en
Customer Care Center at 1-800-867-7183
Jan 29, 2018 | Computers & Internet
When adding minutes the phone says system unavailable
I know this is old, but it still is an issue. In my instance, my trouble was that I have a TracPhone, but the Service Provider is Net 10. I thought you could buy a TracPhone OR Net 10 card, but you can't. Even tho you have a TracPhone, you must purchase the particular service providers card or the code won't go through. Bad part is it won't tell you the code is bad; it just says that Service Unavailable. Try Later. Same if you go online.. it doesn't do anything. What I did was call someone on my contact list; it went to the automated system, and I went through the prompts to where it asked for my pin number. It says PIn is not found in thier system. I tried it two more times and then it hooked me up to a live person. (you can just hit 0 to go straight there) The person after I explained it told me I had bought the TracPhone Card and had to get Net 10 card. (My service Provider; yours might very well be different) They told me they would transfer the TracPhone number to an equivalent Net 10 card. Then they transfered me to another person and it was done after about 20 minutes. Phone now has the minutes I thought I had lost. <:o)
Feb 06, 2013 | tracfone.com
Took my foot pedal apart, now it wont work at all, just makes a clicking sound when trying to put my foot down on it..
Hello
Unplug the machine plug and wall plug on the sewing machine.
Check the power cord for cracks, burns, or faulty contacts as this could be a possible reason for the foot control not working.
Open the foot control by using a knife or flat surface tool, such as a flathead screwdriver, to pry open the corner of the foot control.
Check the wires to see if they are disconnected; this can happen if the foot control drops to the ground. To check wires, remove the circuit board using a flat knife. Inspect the wires inside the foot control. You will see some wires that are soldered together. Check to see if there are any broken wires, as this could be the problem. If the wire is broken, clean the area to remove any debris or dirt. Remove a small amount of the insulation before soldering. Solder wires together.
When you are done, reassemble the foot control and make sure it's working again.
Jul 12, 2011 | PfaFF Creative 7570
Do i need to drop the dog teeth when using the walking foot?
If you are quilting and using the walking foot than no. If you want to do stippling or "free motion" work than yes but with a different foot. A walking foot feed the material from the bottom and top at the same time....
Oct 13, 2009 | Brother XR-65t Mechanical Sewing Machine
Lands Phones Logo
20 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
