Question about Lands Phones
I Have an amstrad e-mailer telephone and need a new hand set
Ive got 3 e mailers get in touch, bob
Posted on Mar 05, 2009
  • ckn_winter
    ckn_winter Dec 22, 2012
    hi bob i'am trying to work out how to transfer my no. from emailer plus to e3 can you help? regards ckn.winter@virgin.net charlie
Hi. My At&t Cordless 2 Hand set Telephone (EL52213) Answering machine (ON) doesn't record incoming messages. The Message window shows 0. The Telephone base is connected with my FAX machine (Teleph
If your Phone service is recording messages, that disconnects your line. You need to have them turn that feature off, OR set the answering machine to answer is less rings, say two or three. If the FAX machine listens to the line, it can still be set at a higher amount of rings, say four, and should still answer any FAX signal as it's sent to the answering machine.
Jan 25, 2015 | AT&T Lands Phones
Tip
Audio skip and lag errors on your recorded programs on an Amstrad DRX180 PVR2...
This is a great tip if you have a PVR2 Amstrad DRX180 Sky + Box if you are experiencing audio problems on some of the channels.Cartoon Network, Virgin 1 and Channel 4 are the worst effected.
It is not an LNB problem nor is it a cable or Satellite dish location problem as some may lead you to believe. The REAL problem is that there is a known fault with these boxes on this make (AMSTRAD) model only (PVR2) that doesn't appear to manifest itself on the PACE or THOMPSON Models PVR2 or PVR3.
You need to email James.Murdoch@BSkyB.com explaining your problem and presenting the following arguments (if the statements are true for you):
1. That there is mounting evidence that a whole batch of Amstrad's are suffering from this this common problem. More importantly however it was Sky themselves that supplied these units to enable their Sky+ service (for which they charge you monthly) but the units they supplied have been rendered unfit for purpose to fully enable that service.
2. That there is mounting evidence that the problem started directly as a result of Sky changing the operating software during the summer 2006.
ie. Sky caused the problem to occur in equipment they supplied, for a service they charge you monthly for.
3. That your expectations are that the unit will be replaced for freeby a brand new Sky+ PVR, as Sky have done for other customers that are in exactly the same situation. There is evidence that replacement refurbished units start to suffer from the same problem in due course and you do not want to risk that. You pay a lot of money for the Sky services so you expect to be given the best possible customer service and have your expectations met.
4. That you will have to consider canceling the whole Sky service if your expectations are not met, because with a failing unit the monthly cost does not represent value for money.
Don't forget to include you System Details in the email, the email you receive will hopefully offer a free call out, and a brand new PVR3 (although they can't guarantee the make). You may also receive a courtesy telephone call. If you only receive the call but not an email,then email back requesting details of their intentions in writing byway of a return email.
You are not owed a PVR3, nor do you have any rights to one. It just that by asking for one you are providing yourself a degree of protection against the fault continuing.
Hopefully you will get a PVR3 to solve the problem.
on Dec 02, 2009 | Audio Players & Recorders
Want to be clear about the handset and telephone base set because base set is not responding to handset.
The base needs to be plugged into the wall for power and have a working phone line.
Oct 16, 2014 | Lands Phones
What i was after was a manual for amstrad emailer plus phone em 2001
Dear Brian Clarke,
Here is the link for the user manual that you require.
http://www.amstrad.com/emailer_faq/emp_auk/index.html
Or you can try
http://www.amstrad.com/emailer_faq/user_guides/index.html
I hope that this is the fixya for you and I look forward to hearing how you get on with this query.
Yours sincerely
Ouszen
Feb 07, 2012 | Cell Phones
One cordless telephones is not working
Then that phone either needs a new battery or the charger is defective or the hand set is defective. These are not repaired just replaced.
Mar 28, 2011 | Uniden Cordless Telephone
A 220 volt Amstrad monitor that i want to convert to use 110 volt
engagetek, This would be a very easy thing to do if and only if the label on the rear of the unit has printing similar to my GATEWAY LCD. It states as follows: "100 - 240VAC input 50/60hz." If your Amstrad unit's label reads "220-240VAC 50/60hz only, then you will need to reverse engineer the "ac to dc" power supply, be it an old "linear" or a modern "switch-mode-power-supply" type. You did not state what type of monitor technology your Amstrad is. CRT, LCD, Plasma,???? I would guess that it is a CRT type. Well anyway, I hope the info was of some use. Bye for now, I'm louie12fix on fixya
Oct 11, 2009 | Computers & Internet
I have a dual handset GE 2.4 GHZ telephone set. The main hand set works but the second hand set will not work, it just beeps and shuts off.
Swap batteries and see if second hand set will work. Can get new battery or a different hand set on eBay.
Sep 03, 2009 | GE Lands Phones
Manual. need to know what the connections are for
User guide or Manual for Amstrad Sky+ ...YYY
2 posts - 2 authors - Last post: 27 Jun 2007
I need to add a second sat lead from the LNB to the Box. None the less I need a book of words that tells me about the Amstrad 180 sky+ box. ...
forums.vnunet.com/message.jspa?message... - 29k - Cached - Similar pages -
Sky Digibox remote control codes for your television
This User Manual is the ideal solution if you've bought a Sky Digibox without one. .... it ALSO operated ALL of the functions on my Amstrad Sky+ receiver (not .... in the Digital Installation Manual or via the Sky Customer Service option in ... This actually selects Sky+ mode, but a Sky+ remote works a sky HD box. ...
www.satcure.co.uk/tech/digicode.htm - 49k - Cached - Similar pages -
User manual AMSTRAD SKY PLUS - User guide AMSTRAD SKY PLUS ...
User guide AMSTRAD SKY PLUS. USING YOUR SKY+ WELCOME TO YOUR SKY+ BOX GUIDE .... to repair your Sky+ box. For repairs, please contact Sky Customer Service. ...
safemanuals.com/user-guide-instruction... - 98k - Cached - Similar pages -
For Sale : Amstrad Sky+ Box and QED 1.5m Squart Cable - AVForums.com
Due to an upgrade to Sky HD I have for sale my old Amstrad Sky+ box (model no. DRX180). ... Will try to find the manual for it as well. ...
www.avforums.com/forums/home-cinema-hi... - 102k - Cached - Similar pages -
Amstrad Sky+ Box - HELP PLEASE! - Sky+ - Digital Spy Forums
6 posts - 5 authors
Amstrad Sky+ Box - HELP PLEASE! Sky+. ... The Specifications in the manual state: Hard Drive: 160 Gb (with 80 Gb for personal use); the packaging also has ...
www.digitalspy.co.uk/forums/showthread... - 55k - Cached - Similar pages -
amstrad sky plus on standby
Following the instructions at the top of page 66 in the Manual fixed it. .... Go back and wait by your sky+ box and you should see the red recording light come on, ... Sky & DLM, Sky Broadband Service Status, SkyUser Bandwidth Meter ...
www.skyuser.co.uk/forum/sky/17069-amst... - 117k - Cached - Similar pages -
sky+ box keeps making beeping noise. - Cable Forum
15 posts - 3 authors
can anyone tell me how to stop sky+ box from making a beeping noise, ... thanks paul ill read manual & see if that helps. my sky+ is an amstrad pvr3. ...
www.cableforum.co.uk/board/64/33616556... - 87k - Cached - Similar pages -
Sky+ box amstrad dx280 - FixYa
Technical Support, Instructions & Repair Service. Home | My Expertise | Sign In ... Related Searches: sky remote, sky box, amstrad, skybox, sky manual ...
www.fixya.com/support/t1223689-sky_box... - 49k - Cached - Similar pages -
MobilePhoneMadness.com - GUIDE: Upgrading Your Sky+ Box
Amstrad Sky+: Equal in size as the Pace Sky+ V2 and looks identical, ... We hope Sky will fix the V1 firmware at a later date, as there no manual fix we can ...
www.mobilephonemadness.com/forums/arch... - 13k - Cached - Similar pages -
Amstrad DRX 180 - Review - How did we live without it???
The problem with the cable service, however, is that when you look at the ... No matter which Sky+ box you end up with, the instruction manual is the same ...
www.ciao.co.uk/Amstrad_DRX_180__Review... - 82k
May 19, 2009 | Televison & Video
''Low Memory'' on Amstrad E-Mailer
E-mails use memory to have you deleted them?
Nov 12, 2008 | Uniden Cordless Phone
Faulty Amstrad dd8904 VCR
It sounds like it needs a belt kit (New drive belts needed).
If this old VCR has not been used for a long time it could also be ceased up.
Apr 07, 2008 | Televison & Video
Lands Phones Logo
43 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
