Question about Car Audio & Video
Car radio/cd player replacement, wiring problem
Hi, i am replacing the stereo in my fiat Ducato camper van as it has stopped working. Problem. It has standard ISO sockets for power and speaker fitting into the back of the new jvc unit but on the "power" supply lead it is only showing me 12volts on the permanent supply on the lead marked on the plug as "ignition 12v" it is not showing anything even with the ignition switched on. Question? Do both of the leads need to be supplying 12v? can i make a bypass lead to the battery so i can find out if this is the fault? without blowing up my new stereo!!
I would be grateful for your help.
Thanks Dave.
  • 1,498 Answers
Yes. Both leads need to have +12v for the device to function.
Yes. You can run a bypass to the battery to make it work.
Mike
Posted on Jul 21, 2008
Fiat 2.8 ducato camper i have 8volts at the terminals with motor disconnected and 0 volts with motor connected have tried a new motor
Check for corrosion on your wiring. Assuming that your other peripherals are working properly.
Nov 09, 2015 | Fiat Cars & Trucks
How do you adjust a clutch on a Fiat Ducato 2.8 2001 model?
http://www.roadtestreports.co.uk/vans/fiat/ducato/qanda/
Feb 23, 2015 | Fiat Cars & Trucks
Van cd radio code
1555 but i dont think this is right as my antivirus thingy seems to have locked everything up again ,the only radio decoder that still seems to work is the ford M series
Dec 20, 2013 | Volkswagen Cars & Trucks
No power to fuses on Fiat 14 ducato van (1987) alternator charging, headlights, horn, hazard all ok, no power to indicators, wipers, heater fan, fuel gauge, temp gauge. all fuses are ok, engine starts
Sounds like the relay is bad, look in the fuse panel or under the dash for a lil black box, they are usually appx 1"' x 1" and there should be several of them. You may want to check owners manual or a repair manual to find the location. They should be listed in the schematic of the fuse box as well.
Jun 07, 2012 | Fiat Regata Cars & Trucks
Free radio unlock code
hi im tryin to unlock my honda accord 2001 radio code can u help me out?
Nov 26, 2009 | Car Audio & Video
Hi,i have just brought a 1989 bedford camper and wanted to fit my sony cd player to it but have no idea how to start...old radio seems to only have two wires going to it (and ariel)but cd player seems to...
Usually a car stereo will have at least 11 wires and sometimes more, the basics are Power (red) Ground (usually black/sometimes brown), constant/memory (usually yellow) and the speaker pairs, gray pair, white pair, purple pair, and green pair. There may be a blue wire for the amplifier trigger, but you don't need to concern yourself with it unless you are installing an amp.
Let us know what your configuration is as for speakers and such and we may be able to be of more assistance.
Sep 11, 2009 | Buck Chevy Express Van Fullsize 01 Radio...
Help, need the security code for renault kangoo van
Hi Guys and Gals
I have a Radio Blaupunkt FIAT Ducato CD NS 815BP331857235560 part number 7 643 318 316
Can anyone help with the code
Thanks
Mar 17, 2009 | 2006 Renault 181
Fiat ducato timingbelt problem
on the front engine pulley/harmonic balancer or in a hole on the bellhousing.
Mar 10, 2009 | Fiat Pininfarina Cars & Trucks
Fiat ducato van, the hand brake light is always on
Hi! U should check the hand brake switck it could be stock in the close position.
Jan 29, 2009 | 1995 Toyota Land Cruiser
Car Audio & Video Logo
201 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
