Question about Sony Ericsson W710i Cellular Phone
Camera not working
When i open the camera application, i receive this error message.
" Another application is running.Close it,and then start the camera. "
i tried restarting the phone and open the application, still same error.
  • 2 more comments
  • Sylvester Duplessis Sep 23, 2008
    SONYERICSON K800I
  • rooq_usman18 Dec 05, 2008
    camera not working
  • rishantster9 Apr 10, 2009
    whenever i open my camera it shows a message " another application is running......................."plz close and try again
  • k couture Apr 18, 2009
    same!
    Problem Solver:
  • 4 Answers
I have the same problem but when i push on the plastic above the keys it works but when i stop pushing it the camera stops working, im 75% sure its the flat cable inside or the flat cable isnt connect correctly.
Posted on Jun 24, 2009
    Sergeant:
  • 260 Answers
Usually in order to reset the phone you have to unplug the battery, not just turn it off and back on. I recommend unplugging the battery for at least 60 seconds and then plug it back in.
Posted on Jul 14, 2008
Cannot open camera, keep shown another application is running. close it, and then start the camera. but no other application is running.
Remove the battery, memory card. replace the battery after 15 minutes.. Now check your media files and clear off unwanted files. clear any MMS received.
If the camera now reponds well insert memory card after getting it scanned in your PC for errors.
If not the camera software must be reloaded.
Sep 14, 2010 | Sony Ericsson W380i Cellular Phone
This message displays any time i try to access the camera. "could not start the camera. close other applications and try opening the camera again". please help.
This is what you should do, press and hold the menu key.. you'll get a display in a rectangular form with all programs that are currently running on your blackberry.
You can scroll through the open applications and for you to close all running applications, you'll have to click on your trick ball to get you to that open application and then you close it.
Go over the process of holding the menu key for about 10 seconds again until the rectangular window opens with applications that are currently open.
Click on another program and close it.... do this for all the applications until your have about 4 applications running. Once it's reduced to this you would be able run your camera.
Regards
Apr 08, 2010 | RIM BlackBerry Bold 9000 Smartphone
Camera ERROR MESSAGE Blackberry Curve (Sprint)
Your OS maybe corrupted so you will need to reinstall the OS, you can do this by connecting the phone to your pc/laptop using the USb cable then open the Blackberry Desktop Manager and click on the apploader then install the applications and install the OS as well as the features for the phone....
Thks
Bajan Guru
Barbados4life
Dec 06, 2009 | AT&T Blackberry Curve 8300 Smartphone
''Another application is running. Close it, and then start the camera.''
This seem to occur on sveral Sony-Ericsson models.
You want to use the camera and get the message "Another application is running. Close it, and then start the camera".
This is a hardware issue.
I have a K530i.
This is what I do:  I gently knock the phone upper corner on something hard. Then the camera works.
Nov 20, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Camera cannt open
if some application is running u cant use the camera ...only if u close it u can use de camera
Jul 15, 2009 | Sony Ericsson W850i Cellular Phone
Sony Ericsson W350i camera not working
sony ericsson camare problem...when i will start camare ,,display message 0 hold ,,another application running ,,close to start
Jun 27, 2009 | Sony Ericsson W350i Cell Phone
Close the other video streaming application to start video
Your camera is already online. Double click the camera icon in the lower right task bar and it will work. That is the problem, the program is trying to run twice. Again, the camera is online and working and the access to it is in the task bar at the bottom. You, of course, can change these setting if you like.
Jun 21, 2009 | Dell Studio 1737 Laptop
It showing message while i open the camera"Another application is running.close it and then start the camera".
yea i have this phone it usually only does that if you are talking but some spplications and the camera cant run at the same time like when your listening to music.. it stops when picture is taken so ya...
May 31, 2009 | Sony Ericsson w580i Cellular Phone
"Another application is running. Close it, then open the camera."
If any problem first check by software.Bcoz more problem salve by software.
Jan 28, 2009 | Sony Ericsson w580i Cellular Phone
Camera won't start "Another Application is running"
Dear Friends,
I have the same problem (Application is still running close it and start the camera) from last Week onwards, i went to the sony ericson service station, they told some Part(board) to be replaced and It will take 15days hardly,I dint accepted his comments, Then i worked full fledged on this and i got the solutions,
Solution:1(model:W580i)
*Remove the memory stick and push the air (from mouth)into the Inner camera.After that it will work Fine.
Reason: If Dust in your camera lens, the error will appear, so it is a matter of sensor.
Solution :2
* Observe the problem little closer, and fix it, b'coz you know your mobile very well than the 3rd Person.
Solution:3
Throughout all the mails regarding that error messages using Googles Search
Don't go Mobile service stations without knowing a nature error, because they ready to cheating us. Becareful.......... Freinds
Any queries,
Call me on my hand phone:
My Number: 9940097172
Rgds.,
Nagoor
Jan 20, 2008 | Sony Ericsson W850i Cellular Phone
Sony Ericsson W710i Cellular Phone Logo
145 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
