Question about Seagate (ST3160827AS) 160 GB Hard Drive
My external hard disc is not regagnised
Sir,
my new external disc is not regagnised,in my windows x p .pls help me
    President:
  • 1,187 Answers
Seagate ... best hard drive technology...
If it is new, then blow away the partition and format it:
1. Right-click [My Computer]
2. Click on [Manage]
3. Click on [Disk Management]
4. Find your new external hard drive in the list and / or in the graph.
5. If you are sure, then you can either format the disk partition or delete / create a new partition then format it.
6. Try "format" ... answer "yes" to the scary message.
7. Do an NTFS "quick format"
8. You can assign a drive letter if you wish, otherwise it will probably be Drive D
Let us know if this works / doesn't work.... thanks!
Posted on Sep 30, 2009
  • 3,153 Answers
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
Posted on Sep 29, 2009
  • 468 Answers
Go to My computer right click chose manage open Disk management and activate and format hard disc
My laptop did not work while reformat "it says make sure that your hard disk is properly connected";what should I do?give me some help!!!!pls!!
Try using a different USB port to connect the external drive you're trying to format. If you're formatting the internal drive of the laptop, try doing it using a Windows installation disc. If that fails as well, you'll need a new drive.
Sep 24, 2013 | HP Computers & Internet
Toshiba 593400-e external hard drive problems
Hi.
my external hard disk not supported in my laptop after install new os for window 7 professional 32 bit so pls give the solution
Oct 16, 2012 | Toshiba Canvio Plus 320 GB 2.0 Portable...
Sir, may request to your company to provide me a software that can i use for transferring of my files into external hard disc from laptop. Sreen appears "write protected" by when i used...
Theres two likely possibilities to this
1. if you are in a corporate environment, then the restricted machine may have a policy set to stop data being placed on an external device. in which case contact your administrator to allow access.
But most likely the restricted machine may be windows 7 and the unrestricted is not.
there is a policy in windows 7 that stops people from writing to the root of any hard disk.
to confirm that this is your problem, simply use the other machine to create a new directory by right clicking somewhere in the drives explorer folder and select NEW then FOLDER, call it TEST for example then take the portable drive across to the restricted machine, open the folder then try dragging your files into this folder.
should work
Mar 18, 2011 | Computers & Internet
My dell latitude c400 will not boot from external cd rom or the brand new hard drive i need to put windows xp on it but it will not boot from anything can you helpnow i have found i have no drivers...
try other known good windows installer. if it boot, then the problem is in xp installer, if it not. try other external cd-rom drive. also be sure the disc rom drive are dvd rom drive because a cd rom drive cannot read dvd disc but a dvd rom drive can read cd rom disc installer
Feb 15, 2011 | Dell Latitude C400 Notebook
Sir, i have downloaded window xp quick fix plus as instructed by you, but the problem still stands unsolved. My desktop is COMPAQ PRESARIO 1620 INI5370DCX. I have lost the service cd, so i am unable to...
you can format it by inserting the Windows XP CD and install a new XP OS on the machine and you can also format it externally. I am not sure what it is that you want to achieve ...is the Hard Disk damaged?
Apr 18, 2010 | Computers & Internet
WD my book essential not working on windows
pls i really appreciated if you help me to find a free driver for my wester digital external hard drive 500 gb pls send it to my email how do i get a free drive .... my email: deejhay17@yahoo.com
Jan 22, 2010 | Western Digital My Book Essential 1TB...
External Hard disc isnot recognized by PC
Dear Sir,
Here is the Procedure for Connecting External Drives to Computer.Several brands of computer does not recognise external drives when connected to USB expansion slots,and Slots of front panel,So connect your Ext HDD to back side onboard Slots.Because there is a lack off USB power surge voltage to detect a large capacity exteral drives.Some time it is does not recognise by many computers,when USB power surge voltage is low.
I think it helps,
If you find any difficulty post a feed back we were happy to assist you
have a nice day.
Good luck
Sep 17, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Missing instillation disc
SIR,
l LOSS MY INSTALLATION CD PLS HELP ME
Nov 24, 2008 | LG GSA-2166D DVD RW Dual Layer Burner
External Hard disk problem
Check that your usb connector is ok i think problem will be there.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FIXYA.
Mar 20, 2008 | Computers & Internet
Seagate (ST3160827AS) 160 GB Hard Drive Logo
69 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
