Child lock I set the child lock on a akio 34cm tv and now I can't turn it off . It won't let me back into the menu, can you help!
  • 3 Answers
Try F and mute on your remote. Otherwise put in AKIO TV LOCKED on search on the internet and it might give you a solution page.
Posted on Jul 13, 2008
I have an AKAI TV CT-2877A (M) and the "child
As long as you remember the "CODE" The child lock on a TV is a wonderful thing.
The lock sometimes causes unwanted trouble--if it gets accidentally turned on and you don't know the code, you can find yourself unable to fully enjoy the full range of available television stations. Please apply the following possible 5 different solutions taht verified by different users and than hopefully you'll be back to watching regular TV ....
  1. Bring Up TV Menu ; Power on the television with the activated child lock on. Push the "Menu" button on the remote control. A series of features appears on the screen, ranging from the overall TV functions to the video display and the audio setup features ,Choose "Options" and a new menu appears on the screen. From the new menu select "Child Lock." The exact setup selection is going to vary slightly, although the child protection is always referred to as either "Child Lock" or "V-Chip." The V-chip is the actual chip built into the television that blocks out certain television programming.
  2. Try a "factory reset" action... This should be somewhere in the TV menu system. However Please note that will clear everything, so you may need to re-program every things..the channels etc.
  3. Hold the lock key in the remote for few seconds . you will get the lock tool bar . you can unlock it there
  4. Hold the display button on the remote for 10 seconds.
  5. As a The last solution which is common for all TV sets..
    • Try to find the User manual for your television. The section In the manual about how to set the child lock feature will also explain how to unlock it.
    • Try a few "universal methods" for unlocking the child lock. Some televisions have a universal code built in for disabling the child lock --no matter what your code is. A commonly used code is "0000."
    • Unplug your television for at least 1 hour . The internal memory battery of the TV is what helps remember what your code. When TV is unplugged for an extended period of time, it clears the internal memory, which in turn will reset your child lock code back to "0000 " again...
if the problem still continues you have to email to :
Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :) Thanks
Jun 26, 2011 | Televison & Video
How can i turn on locked tv?
If it's locked, that means it has a child lock feature on it. MENU settings have be adjusted to unlock it. AND yes you can access the MENU without being on a channel. Turn ON, then go to your menu. Adjust your lock settings accordingly and VOILA you should have it back on in no time. You should be able to do it from either your remote or buttons on your TV. Let us know if this works.
Mar 09, 2011 | RCA L32HD41 LCD TV
Child lock
From the main menu choose "Parental Controls;" it's option six.
  • Step 2 Choose the first option, V-Chip TV Rating Limit, and using the arrow keys and the OK button on the remote, scroll through until the TV-MA rating appears. Press the right arrow button to move the highlight over to the "Status" field and toggle to "View." Press the OK button. This will set the age-based ratings to Mature.
  • Step 3 From the Parental Controls menu, select the second option, V-Chip Movie Ratings Limit and change the rating to TV_MA and the "Status" to "View."
  • Step 4 From the Parental Controls menu select the third option, V-Chip Unrated Program Block and select item one, which will be "View."
  • Step 5 Select the fourth option, which is "Channel Block." Highlight the Channel field and using the channel up and down buttons, go through and check they are all set to 'View." Any set to "Block" will need to be toggled back to View.
  • Step 6 Lock the controls to activate the changes using item six on the "Parental Controls" menu.
  • Nov 30, 2009 | RCA Mikomi 5290925 15 in. LCD TV
    Help unlock child lock on tv.
    The solution is so simple!
    Press the POWER (RED) button and the TV/AV button simultaneously - hey presto! the child lock will switch off and you will have your TV back working properly.
    May 29, 2009 | Philips Magnavox 27MS343S 27" TV
    How to turn off child lock without remote on LG tv.
    hi..To do a Child Lock, follow these steps:
    1. Turn on your TV.
    2. On the remote, press the Menu button. The Set-Up Menu appears.
    3. Scroll to the Key Lock function and set function to Off.
    4. Press the Exit button to exit....
    ur problem will be solved.. rate me!!!!
    thank u
    Apr 10, 2009 | Televison & Video
    Child lock on ..and no remote
    If the front buttons don't work, it is usually caused by
    the TV being set in CHILD LOCK.. Try this;
    so got into menu and turn child lock to OFF.If you dont have a remote,then unplug at electrical outlet for 5 hours then plug back in and turn back on; box will then reset... Hope this may help you; Regards, VOTIT DON'T FORGET TO RATE
    Sep 01, 2008 | Televison & Video
    1 Press MENU to show the on-screen
    2 Press VOL+ or VOL- repeatedly until
    SET is highlighted.
    3 Press CH+ or CH- to highlight CHILD
    4 Press VOL+ or VOL-
    to choose ON or
    Choose ON to disable all the buttons on
    the front of the TV. CHILD LOCK ON
    will appear briefly on the TV screen each
    time you press a button on the front of
    the TV.
    You can still operate the TV with the
    remote control.You can still use the
    POWER button on the front of the TV,
    but only to turn off the TV (not on).
    Set CHILD LOCK to OFF to cancel this
    feature so you can use the buttons on
    the front of the TV again.
    5 Press TV/AV/EXIT to remove the
    menu from the screen.
    Jun 06, 2008 | Philips Magnavox 27MS343S 27" TV
    Help me please................................
    Usually, once child lock is on, the set will not respond to the front panel buttons and you need the power button on the remote control to turn the TV on. Then go into the menu and turn child lock off.
    Mar 31, 2008 | Sansui H TV2600 TV
    Child lock in a Koryo TV 21inch.
    Go to the channel where Child Lock is ON
    Press " --- " Key ( below channel 9 button) for few seconds,
    Child Lock will be OFF
    Press again Tune Lock will be OFF.
    Mar 28, 2008 | Televison & Video
    Turn off child lock
    To unlock the Panel Lock, Parent Lock, or Child Lock, follow these steps:
    1. Turn on your TV.
    Note: If you don't have a remote, you may be able to do the same thing by pressing the Menu button on the front or side panel of your TV and using the volume or channel up and down buttons on the TV to scroll to the Key Lock function and set it to Off.
    Oct 02, 2007 | Televison & Video
    Televison & Video Logo
    151 people viewed this question
    Top Televison & Video Experts
