posted by scott mellor on Jun 28, 2008
hi ive just been useing my tascam x9 mixer when it just suddenly went of and will not come back on again. when i now switch it on the cooling fan comes on but nothing else, lights ect.
please can you help???
cheers
scott
Comment by scott mellor, posted on Jun 28, 2008
hi thanks for your quick reply.
ive took the back of and looked at the fuses i can see and they all seem fine???
they may be more under the curcit boards i didnt realy wana go under there though just incase i did something wrong.
scott
scott
hi again it was a fuse aghhh.
but ive changed it and its done it again, same fuse.
i changed it again and used a different plug soccet and its done it again???????
Best Solution
Since nothing else is working, the cooling fan is probably powered by AC at line voltage.
The power supply that feeds the electronics has failed but it may not be catastrophic; it might just be an internal fuse that has given up from metal fatigue.
Each time current flows when powered up, the delicate element expands and then contracts when the power is turned off.
Some fuses have a zig-zag crimp in the element that helps delay the eventual death.
With the unit unplugged, remove whatever screws you find on the back or bottom of the mixer so you can peer inside.
If you are lucky, you may find the fuse in a clip or otherwise plugged in.
There will definitely be one in the incoming AC line although if the fan is running, this one may be OK.
There could be one (or more) fuses on the DC side that directly services the circuitry.
Fuses come in a variety of cases; they can be cylindrical of glass or ceramic bodies with metal caps on the ends and of varying lengths.
Others may be vertically mounted smaller cylinders plugged into or soldered (bad) to the board.
Some are nearly indistinguishable in size and mounting from several other types of parts; these though, will not have other than simple text on the part while the others will have more complex markings.
If you find and replace fuses, buy two so that an eventual tech doesn't have to grub around to find one.
If you replace any fuses and they fail again, DON'T proceed. You may damage the unit further and not help anything.
At that point, you need to turn it over to a tech.
Comment by freetek, posted on Jun 28, 2008
Fuses can be tricky; it is best to either measure them with a cheap digital meter (in the US they can be had for $3 and up) or simply replacing them.
They can appear to be whole but have a minute break where the eye can't see.
I would highly recommend owning a simple meter, you don't need degree to use them and they aid in answering questions of the kind you have.
If you have Radio Shack where you reside, they will have them also for under $20 US and auto parts stores are carrying them too but generally at higher prices.
I don't recommend doing any further work on it yourself.
There is a problem causing the repeated blowing of the fuses, I'm afraid you will need technical help.
In your case, I would search DJ forums for a tip on whom you can trust to do the repair and stand behind it.
Good luck-
Good luck-
Rating Locked! (?) scott mellor has rated this solution as Helpful
Suggest a new solution for this problem
Post a New problem for Tascam X9 DJ Mixer System
Email this problem
Email this problem
Can you Help with these Home Theater Systems problems?
yamaha rxv-992 receiver wont...
Hi, my yamaha receiver power on... Answer This...
Tascam x-9 channel fader
hi one of my channels has broke... Answer This...
Repair Service
Find Home Theater Sys. Repairman Near You:
