Question about Kenmore 46462 Front Load Washer
46462 Washer is full of water and willnot drain. In fact it won't do anything.
  • 57 Answers
Hi I would advise you to check the door inter lock if is full of water you can drain it from the outlet hose into a basin then open the door and check the interlock
Posted on Jul 18, 2008
Washer stopped. F6 code, didn't drain.
that is called an eco ball it is part off the machine
its job is to save money by not heating the water below it in the drain pipe
Dec 29, 2013 | Kenmore 46462 Front Load Washer
I have a whirlpool ultimate care II washer. It stopped in the middle of a load, full of water, and now it won't do anything. It won't drain, fill, move, or make any noises.
You will need to check the capacitor on the machine. It can be tested with a capacitance meter the easiest. It can be tested with a resistance meter, but this will tell you if the capacitor is shorted or open. It will not tell you the capacitive value if the component has drifted out of tolerance. You put the meter across the terminals and watch the display for counting up to infinity. This will occur quickly and disappear very quickly. Now reverse the leads on the terminals, (reverse the polarity). The same thing should happen, but a bit more pronounced. It will once again rise very quickly and go to an infinite reading. This tells you that the capacitor isn't shorted or open internally. Here is the capacitor to order if you should find it bad.
Nov 28, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool top loading washer won't fill completely
did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
Nov 18, 2017 | Whirlpool Washing Machines
Item lodged under drum Kenmore HE2 46462
Take the back off the washer lay the drain hose down into a bucket so that the water drains out
Check to see where the main drain hose comes out of the bottom of the outer container
Lay the machine down onto some cushions so that the hose opening is nearest to the floor
Take off the clip securing the hose , place a cloth under the pipe and pull it off
You should then be able to go fishing for the item
Good Luck
Sep 24, 2009 | Kenmore 46462 Front Load Washer
Water coming out from detergent dispensor drawer
Is this an HE2 washer? if it is, open door gently tug at bellows top left hand corner you should see a small piece of clothing stuck between tub and dispenser inlet to the tub.
Dec 31, 2008 | Kenmore 46462 Front Load Washer
Water drains underneath washer
the load could be to small and all the water whats been left after the wash might be because you only need small pressure on a small wash and the pressure wont make the water evaporate. or you might just need a new drainage pipe i would put less water in next time and see if its better if not get a local self employed plumber.
Dec 01, 2008 | Kenmore 46462 Front Load Washer
Kenmore Elite HE3t model 42922
After the complete wash cycle is finished, the clothes are still soaking wet sometimes. This is not an every load problem.
Aug 12, 2008 | Kenmore 46462 Front Load Washer
Washer drain back flow to sink
No you do not want to restrict the machines pump out feature, FIX the house drain! call Roto Rooter if necessary.
Jul 12, 2008 | Kenmore 46462 Front Load Washer
F21 Drain Problem with empty washer
Please see what I (royale) have done with my problem.
May 06, 2007 | Kenmore 46462 Front Load Washer
Kenmore 46462 Front Load Washer Logo
62 people viewed this question
Sal De
fordexpert
Robert Rankin
