Question about Proview PL926WBi 19" LCD Monitor
ProView 3200 RX326 manufactured May 2005
Serial #: F0A255049271U Purchased at Costco The TV has a loopy gasket hanging down from the top. This detracts from the picture and is annoying.
  • brutus409 Jul 27, 2008
    I have the same problem. What is causing it and can it be fixed????
Coldcut
  • 1554 Answers
SOURCE: Proview 3200 HD TV
as you are using the ch3 , have you previously scanned and locked in all the channels for cable,
Posted on Apr 25, 2008
My Proview LCD TV Model 3200 - 32Inch is blocking certain screens and the message that shows up - V-Chip Block TV-y7fv - can you tell me how to fix this issue?
Posted on Sep 29, 2008
skotkolr
  • 558 Answers
SOURCE: cost to repair popped ic
Sounds like the vga on the board has gone wanky I would look for a replacement on ebay nothing really you can do with this besides replace the pcb board with the processor on it.
Posted on Feb 17, 2009
praky16
  • 744 Answers
SOURCE: Proview 32' without picture or sound
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Posted on Jul 07, 2009
budmrtn
  • 11361 Answers
SOURCE: tv turns on and i get sound but no picture
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there are some troubleshoot you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
You may have the same cause of the problem (blown fuse on T-CON board):
http://www.fixya.com/support/t626025-proview_rx_326_model_3200_tv_sound_but
Posted on Jul 27, 2010
My proview rx326
It should have inputs for analog AND digital.
http://thebooksout.com/downloads/proview-rx-326-user-manual.pdf
This site seems to have it, but might be a charge.
Sep 26, 2017 | Proview Televison & Video
After 10 years with a Proview not Proscan RX326 TV, went from coax to HDMI from new Comcast digital adapter. Comcast & Proview remotes turn on TV but the screen often stays dark with no sound.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 06, 2016 | Proview Televison & Video
Proview 3200 LCD TV won't turn on
Possibly a printed circuit board gone in it,recommend a TV repair man have a look.
Jul 21, 2014 | Proview 3200 Repair Kit
Sound no picture. When turn on quick flash blue light then nothing. Product#RX326 model 3200 made July 2005 bought used
Backlight inverter is bad. You will need a direct replacement.
Search shop jimmy.com and encompass parts.
The backlight inverter is the part that allows for the illumination of the tv itself.
Thank you
Jul 07, 2011 | Proview Televison & Video
Cant find the on manual botton
front panel of TV...........center (ch... up/down.......vol up/down power)
Apr 17, 2011 | Proview PA-32JK1A 32 in. LCD Television
I live in Canada and subscribe to Shaw cable system. I need a 4 didgit code for my Proview RX326 LCD TV so I can program it into the Shaw remote control
There may not be a code set compatible with your Proview TV since this brand is not that widely distributed. The code sets available in any remote reflect the brand names and feature sets of TVs (and other entertainment electronics) that prevailed when the remote was designed. Even the so-called 'learning' remotes will not program to every InfraRed remote.
Your best chance is to check Shaw's website for the most recent codes:
Shaw User Guides
Aug 01, 2010 | Televison & Video
Proview 3200
Pat I do not know if you have a warranty you were required to retain the receipt from the store for the length of the warranty period to prove you have one ,also it is a good idea to register with the company on their website so they have a record of your tv and model, with your name and therefore the warranty they have included if any.LCD tv's are one of the most unsupported mass marketing consumer items that are being dumped on the US market. I think you have Blown capacitors, or more likely a problem with the power board, typically this requires soldering new capacitors onto the power board after unsoldering the blow ones and if this is all the problem is the issue will disappear, if there is an issue with a transformer, or some diode or computer chip then you might as well replace the whole power board. the capacitor issue is no big deal if you can get an electronics service center to look at the problem.
May 22, 2008 | Proview PA-32JK1A 32 in. LCD Television
Proview PL926WBi 19" LCD Monitor Logo
48 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pawan Ambastha
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
