I have a gmpn-80 janitrol 90% eff gas furnace,it is only 15 months old,my condisation tray is melting and cracked do to heat in which case leaks water all over....why would this be happening?
  • ride017 Jun 28, 2008
    I had a tech from the company who istalled the unit check the gas pressure and fan speed,he said they checked out properly.My warranty ended three months ago so they are trying to avoid fixing it.....I say it was an improper install or manufacture default.In your opinion ,do you think a problem in the existing duct could cause this problem as far as air draw?thx for the help
    Scholar:
  • 104 Answers
Most likely the cause is that the furnace is firing too hot. When a furnace is installed and set up, the manifold gas pressure and fan speed has to be set by the technician so that the temperature rise through the furnace is a maximum of 50 deg F (i.e. if air enters the furnace at 68 deg F it come out no hotter than 118). The target temperature rise on any gas furnace is anywhere between 30 and 50 deg F. If the furnace runs too hot, either the manifold gas pressure must be turned down or the fan speed must be turned up to keep in this range.
Posted on Jun 28, 2008
  • Chris Lyon
    Chris Lyon Jun 29, 2008
    That is a possability. The big key is to measure the temperature difference through the furnace. Take a temp reading at the return vent and then take a reading at the closest vent to the furnace. Turn the furnace on and allow it to run for about 10min before checking temps so that the heat exchangers and duct work can get completely up to temp. If you are in the 30-50 range, then you are looking at install problem, mfr defect, or improperly paired equipment. Gas pressure doesn't really mean much if you are over temp. Natural gas normally runs at 3.5" water column in the manifold. I have a propane furnace. Propane runs at 10.5"wc in the manifold, but I fire my furnace at 8.5" to achieve the proper temperature rise.
Have Gibson furnace runs cycle but seems don't get hot enough out of vents check all 115 degrees at vents use to lot hotter old furnace you couldn't stand on vents now you can easily
Is this a gas furnace ? Newer high eff. gas furnaces do have cooler outlet temperatures. The installer should have checked the temperature rise and gas pressure. By adjusting the gas pressure and blower speed you can obtain a higher outlet temp, but you don't want the gas pressure to be higher than the manufacture specs and you don't want the furnace to run outside of the manufactures temp rise specs.
Mar 02, 2017 | Gibson Heating & Cooling
New goodman 80% gas furnace leaking condesation down exhaust vent
it could be condensation. or poor seal at roof. probably the seal at roof. also check the larger copper line is it sealed good? if any spot is not this will cause leaking when in cooling mode. maybe dripping from line onto vent.
Jan 28, 2014 | Goodman Manufacturing Goodman 60,000 btu...
What is the CO2 % of an 80% efficiency gas furnace and the CO2 % of a 90% gas furnace
Hello,You get between 10%-12% out of each.The efficiency rating difference is the flue gas(exaust) temperature! 90% furnace is much lower temp than any 80%.
Oct 13, 2010 | Heating & Cooling
Goodman furnace updraft with A/C on top. Drain tray on A/C (plastic) cracked causing water to leak to floor. On inspection, furnace heat tubes on back show hot spot immediately under the crack in A/C...
You would need to look at the warrenty of the product from the manufacturer of this whole unit. If they were purchased as individual parts then each manufacturer is responsible for their compinents.
However, you must have a warrenty on the product to be able to bear any responsibilty to the manufacturer.
If you do have a warrenty then they should up hold it, and they should also have a solution to the fault. It will be pointless to replace the tray only to have it reoccur again. It seems as though they have missed out putting a insulation of some sort between the heat source which evaporates the water in the tray.
Hope this helps, let me know how you get on.
Thanks
Jason
Jun 04, 2010 | Goodman GMS90703BXA Heater
Hi, I have a Carrier Weathermaster XS. I don't
If I am correct, that is a gas furnace, right? I believe it may be between 15 and 20 years. Pro-active with and older gas furnace is never a bad thing. First of all it can become a safety issue, as concerns of heat exchangers cracking and leaking carbon monoxide into the home become increasing. Second, it sure only be 80% efficient, whereas a new condensing furnace today can be up to 95% efficient. That means that you currently only use 80% of the gas you are burning as actual heat transferred into the house via airflow, and the other 20% is literally leaving the house through the flue. So you can increase efficiency dramatically and be safe at the same time by replacing pro-actively
Mar 09, 2010 | Heating & Cooling
Janitrol furnace-circuit board code giving 3 blinks vent pressure switch or vent blockage where do i check on system / furnace was running fine up to this point /turned it off for about 1hr. and when i...
f this is a metal vent 80% furnace,Turn Furnace off
and remove the vent that connects to furnace and see if it is plugged.
If this is a High Eff furnace witrh pvc vents for
exhaust and intake air make sure they are not plugged on the outside.
Turn thermostat all the way up,turn furnace off and
wait a few minutes.This should reset any control
board fualt.
Turn the furnace back on, if you have a glow coil
ignitor it should glow red and then the burners should
ignite. If this doesnt happen then:
On High Eff Furnace if the glow coil does not glow red, remove the combustion door to the burners,
turn furnace back on, if the glow coil glows and
burner ignites, you have an obstruction in the intake
air side. If it still does nothing then:
Use caution and remove the exhaust vent from furnace, start furnace, if furnace runs then you
have a problem with the vent system
Feb 13, 2010 | Heating & Cooling
My heat won't blow through the vents. The furnace ignites itself but it cuts off after a minute. I've sanded the flame sensor but it still won't work. What can I do now? I just want heat in this blizzard!
If the ignitor glows and the burners lite and then shut off, the flame sensor was the best place you could
start at.
If this is a reg gas furnace or a High EFF. furnace make sure your gas meter is not covered up with
snow.
Turn your thermostat all the way up, if the furnace
does this 3 times in a row-then it should go into
a lock-out mode. Has it done that?
On reg. gas furnace make sure your chimney is
not obstructed where it connects to the furnace.
If it is a High EFF furnace make sure the pvc exhaust
vent is actually venting. It should also have a pvc intake air vent make sure that is not clogged.
If it is a high eff furnace, turn unit off and remove
the door that covers the ignitor and burners. This is
usually a interior door with a sight glass in it. Turn
furnace on, if it lights and stays operating, then you have a problem with the intake vent
Feb 11, 2010 | Heating & Cooling
I have JANITROL GAS FURNACE that the MAIN LIMIT
First, replace the limit. What causes a furnace to cycle frequently would be either a malfunctioning thermostat, a shorted thermostat wire, a bad control or the thermostats heat anticipator is not set right.
Jan 30, 2010 | Heating & Cooling
Broken heat exchanger
Yes. DO NOT USE IT UNTIL IT IS FIXED! Carbon monoxide can kill you! Most manufactures will warrant their heat exchangers on 80% furnaces for twenty years. Some models only ten years.
Tubular heat exchangers are known to be very durable. If this went bad this fast the most common cause would be a faulty installation. The installer should have adjusted the gas pressure to assure proper firing of the burners. The air flow should have been adjusted according to that models rated temperature rise. And the flue pipe needed to have the proper rise, length, diameter and height to properly discharge the moist flue gases.
Get a new heating guy. Even though you have a heat exchanger warranty that will cover only parts, not labor. Unless your installer sold you a ten year parts and labor warranty. A contractor will probably charge you a flat fee of $300 -$400. or an hourly rate with trip charge and 1 1/2 - 4 hours labor. A good tech should be in and out of your home in 1 1/2 - 2 hours.
Good luck
Mar 28, 2009 | Heating & Cooling
GMPN goodman furnace: Water leaks from the base.
Check the drain tubes inside the furnace. There may be a loose connection or a split tube.
The unit could also leak from the gasket between the secondary heat exchanger and the vent fan housing. The secondary heat exchanger ould also be leaking or cracked.
Hope this helps.
Matt
Jan 08, 2009 | Heating & Cooling
Heating & Cooling Logo
215 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
