Question about Cell Phones
To open back side of k530i
Sir,
I want to replace my existing SIM to new One. So, I tried to open the back cover to replace the SIM card. But I can't. Please display me the proedure to open the back cover.
  • Anonymous May 01, 2009
    I cannot get the back off my new RAZR2 v9 phone, there doesnt seem to be a catch at the top.
    Sergeant:
  • 234 Answers
Go through the user manuals it is available in net also.... or otherwise goto service centre and insert the new sim
Posted on Jun 30, 2008
How do i recover k530i no network coverage problem solution
Instructions
    • 1 Turn off your phone and turn it over. Remove the battery cover. Take out the battery and SIM card. The SIM card looks similar to a computer microchip and is in either the right or left top corner.
    • 2 Wipe the SIM card off with a cloth. Look at the SIM card for damages. If it is scratched or warped, have it replaced by your mobile provider.
    • Sponsored Links
    • 3 Insert the SIM card back into place, if not damaged. Make sure that you hear a clicking sound, which ensures it is in place.
    • 4 Turn on your Sony Ericsson phone. Press the "Menu" button. Use the navigational buttons to go to the "Settings" option.
    • 5 Click the "Connectivity" option. Navigate to "Mobile Networks." Select "Networks" and your phone will search for nearby networks.
    • 6 Click on your network. Press the "OK" button. Look at your phone to see if the error is gone.
    • 7 Reset your phone. This could help remove the error. Press "Menu," "Settings" and "General." Select "Master Reset." Follow the instructions to reset your phone.
Read more :
Aug 18, 2014 | Sony Ericsson K530i Cellular Phone
How to open the back cover of Sony Ericsson K530I?
You need to push the back cover towards the lower side of your phone (the side where the recharge connector is located at). This can be quite hard for this phone as it provides almost no friction with your fingers. Try holding it with your palm while facing the underside of the phone and then push the back cover with your thumb. Put some force on it because most of the times it won't go off easily. You can try to dry your fingers and the cover of the phone with some paper towel to increase friction.
Mar 16, 2011 | Sony Ericsson K530i Cellular Phone
Emergency mode show in k530i
sir it is not the tower problem its the motherboad problem service your cell phone to the sonyericsson service center...............
Nov 19, 2010 | Cell Phones
Always show the message 'insert sim card', When I refitted the SIM and turned back on, I had no network coverage. it always again n again n again..
Hi,when a phone does that, it means that the memmory of the phone is malfunction and it needs to be restored..
To be able to restore back the phone memory, you will need to flash the phone memory.
The links below will give you a guide line on how to flash the phone memory .
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
May 25, 2010 | Sony Ericsson K530i Cellular Phone
I forgot my cell(k530i sony ericsson) phone lock password
if you bought it legaly find the plastic card (the card when your sim card was attached) there is a pin, pin 2, puk, puk 2 and your num
Apr 05, 2010 | Sony Ericsson K530i Cellular Phone
Sir, My mobile is Nokia 6500 model. In contact settings,at first it was set as contacts>>settings>>"memory in use"-PHONE AND SIM. By mistake I have changed the option of "memory in use" to...
usually the phone memory security code for nokia mobiles will be 12345, until it is changed manually. try this code... else, u have to consult the service provider i guess.
memory card not detecting....
First you open gallery on screen. If the memory card ok the first item will be the name of your Card. If it is not found that means the card not detecting. You may do this.:
Open Gallery, then press the back ( battery cover ) of the phone and hold for one second, now see the screen, you can see the card name on first line. But when you take your hand back form the battery cover the display revert to the same as before.
The point of pressing:- near to the lense ( Just right side of the lense) . You know why ?. The memory card is located inside of that place.
This means there is a switch (Battery cover open / close) located just left side of the memory card, and there is a TIP projected in the same place at the Battery cover. When we close the back cover the switch become ON. Here is the problem.....!. The switch will not contact even you close the cover. When you press the cover hardly the switch become contact. when you remove the hand again it become open.
More clarification:-
In a new phone if you open the battery cover the memory card will not work at all. It will detect only after closing the cover.
this may help you.
Jan 08, 2010 | Nokia 6500 Slide Cellular Phone
How do I replace a SIM card in a Nokia 2115i?
firstly turn off your phone then open the battery back cover which easy just slide then take out the battery and you will see the sim card holder take out old sim card and put new sim card then put battery back and put back cover.
Dec 30, 2009 | Nokia 2115i
Sony erricson k530i shows a garbled screen
Hai,
This kind of troubles shown in k530i is rare,why i'm saying this i'm also using this very set, i got changed about more than 6 times my sim card and doesn't shown any troubles! That's why its so rare....its better to take to your sony-erricson service station...than trying it by yourself!
From Truly, Jestin Zachariah India.
Aug 08, 2009 | Sony Cell Phones
K530i mobile wont read new sim card (boost -optus) but will read other sim cards. Boost sim card is ok in other mobiles
you go to setting menu then security and change the sim setting . u r salected dual mode in ur handset .
Mar 14, 2009 | Sony Ericsson K530i Cellular Phone
How can I open the back so I can insert my Sim card? Please help. Thank you
hi
sir your mobile is not open by sliding down there is botton on the top if you press that and try to pull the cover to your side then it will open
thanks
your friend from fixya!
Oct 25, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Cell Phones Logo
1,202 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
