Bought a Kriesler Multi sonic tv theatre the units year 6/8/1963 model 121-78/79 label part no 69-5094 they said the radio worked record player worked but tv not after buying this classic unit got it home went to plug it in the power. Did not see that from plug to lead the wires had touched shorted out there and behind tv unit with a spark and small bang regardless its in mint condition want to fix it was is the best way to do this thanking you kindly
SOURCE: Panasonic home Theatre
You need to obtain audio leads and connect from home theatre directly to audio input in back of tv - be careful as there are normally 2 in back of tv
Posted on Dec 24, 2007
Slinteriors
  • 8617 Answers
SOURCE: RCA Home Theatre TV
Have you checked the fuse? If the fuse is good you have a problem with the power supply which can be repaired. You would need a service manual for the power supply. But that would be a lot cheaper than having it repaired by a shop. Power supply problems usually run about 400 to 600 in a repair shop. When often it is a 20.00 part. If I can assist you further please let me know.
Posted on Jan 24, 2008
Benimur
  • 6966 Answers
SOURCE: DVD PLAYER MODEL, SD-K740SU
For a Toshiba SDK740SU, to remove a stuck disc:
1. Remove the top and front cabinet cover;
2. once exposed, slide/move the Rack Loading (white) towards the right with a sturdy instrument such as a common screwdriver;
3. draw the tray out
Please refer to image below:
The only possible easy user workable reset is to unplug the unit for quite some time.
Should the above be not corrective, pls post back whether you have the 740SU or the 740SUA version.
Hope this be of some help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kindest regards.
Posted on Feb 11, 2008
wyoed1
  • 211 Answers
SOURCE: RCA Rear Projection TV P46770CK spark beneath chassis when power applied
It sounds to me that you may have a cold solder joint ( loose connection on the board ). I suggest you remove the board ( or seek professional assistance ) and solder any loose connections that you may find. That may correct the problem. Good Luck.
Ed
NC Electronics
Mills, Wyoming
Have a Great Presidents Day
Posted on Feb 18, 2008
Slinteriors
  • 8617 Answers
SOURCE: power supply regulator for rca 52" home theatre twin tuner pip
no parts from a pioneer wont work. There are roughly 4 regulators for the power supply maybe 5. The sad thing is they cost between 7 and 20.00 , he didnt happen to mention which power supply was affected did he? You would have to check the various regulators out of circuit to determine which one is bad. If its a F.E.T they are hard to check without the proper equipment.
Posted on Apr 05, 2008
How do you convert a Sony dav-sb100 Home theatre system to be multi-regional so can play region 1dvds?
bought a Sony home theatre DAV-DZ270 region 4, can you please help me to make it multi-region.
Feb 15, 2013 | Televison & Video
Connecting JVC television set model AV29LX2 / JVC home theatre system/satellite decoder / Sony DVD recorder
You need to buy a splitter in order to put one to the DVD recorder and one to the tv from the decoder. You should be able to get one at the Local Radio Shack or other electronics store.
If you need help locating a store, please let me know
Otherwise Thank you for using Fixya and Have a Good Day!
and Good Luck...
Apr 19, 2008 | Televison & Video
Apparently they are locked to region 4 and I have bought region 1 DVDs so they won't play
In most models the unit cannot converted to multi-regions.So it will play only in the specified region in which it is applicable to.But in some unit models there is a procedure to turn the unit to multi region so it can play all region dvd.On all models the procedure to convert the unit to multi region is different.As you have not mentioned the exact model number of your unit.t will not be easy to give exact details.If in case there is a procedure to convert your unit to multi region.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Sep 14, 2010 | LG Audio Players & Recorders
Is third time a charm. Again several years ago I
Here is the owner's manual for your DVD machine. This is a VHS recorder but not a DVD recorder. To record VHS tapes to DVDs, you will need a DVD recorder.
You will plug the yellow video out connector on the VHS to the yellow 'Video in' connector on the DVD Recorder. Do the same for the red and white audio connections, out on the VHS, IN on the DVD Recorder. Connect your TV to the DVD recorder so you can see the picture you are recording.
Mar 31, 2010 | Televison & Video
LG dvd player connected to 5.1 home theatre
Dont now your sytem but check Home theatre sytem must be switch to 5.1 display and not dvd display. if stil no sound check in setup off dvd for soundsetting like PCM, RAW , 5.1etc and select each one till you get desired sound.
Presume your conections from dvd to hometheater is conected 5.1 cables or 1 digital cable and not stereo(2cables)
Jan 05, 2009 | LG RH177 DVD Recorder/HDD Recorder
SONY DAV DZ260, home theatre. Trouble reading the disc.
There is some intermittent connection that is causing the issue. Finding it might prove to be a bear - I would recommend sending it back for another working.unit.
Jun 25, 2017 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
T.Sonic 610 2 GB not recognize in OS.
I have a T.Sonic 610 2GB, purchased year and a half ago, so when i found the new firmware update available in transcend official website for my product, i trued updating it and since after that its not able to recognize in my OS, Plz help, but it does power on radio works fine, recording works fine.
Thanks and regards.
Oct 18, 2008 | Transcend T.sonic 610 MP3 Player
Region Codes for Sony DAV-DZ270
I bought a Sony home theatre DAV-DZ270 region 4, can you please help me to make it multi-region.
Kind regards,
DILIP
Aug 24, 2008 | Televison & Video
SPEAKERS TO DMR E55 DVD RECORDER
Using a receiver to operate speakers?...accordianman
Nov 08, 2007 | Panasonic DMR-E55 DVD Recorder
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Electro Med Services...
