The tracks keep skipping from one to another. What can I do?
Apparently - return it to the manufacturer!
Posted on Jun 29, 2008
Denon dcd 425 cd player:the tracking mechanism keeps SKIPPING but it SKIPS BACK like the counter will read @ 20 and the next thing you know it has skipped to 14 ??
Hopefully it's just a bit of dust on the lens. Or something inside the unit that is obstructing the mechanism, such as dirt.
Oct 01, 2017 | Denon Audio Players & Recorders
My stereo system keeps skipping tracks whilst playing can you help?
The lazer is going on it. End not reading the info on the disc properly,
Oct 29, 2012 | Audio Players & Recorders
Cd's keep skipping
The laser pickup assembly is the problem, the stepper rail that the laser is mounted on is driven by a worm gear that often cracks or developes a flat spot causing the pickup skip and jump, also what must be taken into account is the laser has become weaker over a period of time. If repairs are going to be performed replace the whole assembly everything is new and comes pre-aligned when installed.
Jun 04, 2012 | Cambridge Audio Audio Players & Recorders
Hi Skipping problem with a NAD C545BEE, plays OK for 1 minute, then skips randomly wthin the track, then will skip to different tracks on the CD, like fast forwarding. No problems with the disc themselves
hi
There is a diode in the power supply which gives dc supply to the laser focusing coil driver ic . if the diode get faulty this problem can occur. Just replace all the rectifier diodes in the power supply stage. Its better than searching for the exact one. then check the cd player is it skips the tracks. if then also its skips the tracks then you have to change the laser pickup unit.
ok
May 19, 2011 | NAD C545BEE
The driver's side power window is skipping or
Most likely the rail has come loose inside the track you can drill a hole and put a #20 nut and screw in it to hold it tight so it won't move the track is the most common thing to wear out on the window. once you repair it it should be fine check all four corners the most common break is in the lower right side looking at the door with it open. Also the track will come loose as well and that can cause you the same problem, with the cover off the door operate it so you can determine which area it is jumping from and then fix it. also lube the tracks with synthetic grease to keep it from being hard to roll up also lube the rollers in the bottom of the track.
Jul 17, 2009 | 1999 Chevrolet Blazer
My itouch keeps skipping songs. with each restore different tracks skip. as soon as I fix on track a different one stops working.
when you go to your music file and play a selected song. you will see two arrows in a circular formation and antoher set of arrows intersecting one another (shuffle). change the colour so both sets of arrows are grey by touching them.
May 09, 2009 | Apple iPod touch
Bad track appears
Do yourselves a favor. Convert all of the affected tracks to mp3 format (or redownload them in mp3 format), and you will no longer experience these problems.
-Tha Mp3 Doctor
Dec 28, 2008 | SanDisk Sansa e250 MP3 Player
Song skipping
Have you registered you plaey with Creative. There is a good knowledge base on the Creative web -site Support where I got some good asnwers.
Jun 15, 2008 | Creative Labs ZEN Vision:M Digital Media...
My SA6025 damaging mp3 files!
Make a note of skipping tracks & check these tracks play ok on the PC - this will rule out corrupted tracks.
Skipping of entire tracks can be due to DRM copy protected tracks (purchased on-line). Some players will not play DRM tracks.
You can check for protected tracks.
  • In Windows Explorer, go to the folder where the tracks are stored on your PC.
  • Click on View -----> Details
  • Right click on the header bar in the right hand window and select protected. (If protected is not listed click on More)
  • Tracks will be listed with No or Yes under protected. Check your skipping tracks are listed as No, under protected.
If none of this helps, install and run the Philips Device Manager. Select the repair / restore option and follow the on-screen prompts. This will format the player, ruling out a corrupt file system on the player, and re-load the firmware.
Mar 02, 2008 | Philips SA6025 Digital Media Player
HELP!!! My cd player just skips through all song never playing....
Sorry but this unit has a problem with the tracking servo. The problem could be an alighnment, or a bad componet such as the laser assembly, tracking motor or tracking driver IC, with all of these problems the unit will need to come out of the vehicle. Good Luck
Apr 03, 2007 | Blaupunkt Chicago IVDM-7002 Car DVD Player
29 people viewed this question
 Grubhead
Grubhead
