Question about Refrigerators
Self closing door hinges
The door from the house to the garage has 3 self closing door hinges which no longer force the door closed. The door is a metal door, somewhat heavy. The hinges have holes at the top. The top hinge is the only one which seems to still have the pin inserted.
How do I re-tension and fix the hinges?
  • 1 more comment
  • scott644 Dec 10, 2008
    My self closing hinges won't close any longer. If there were pins in them, they are not there now. Other than replacing the hinges, is there a way to solve this?
  • Anonymous Dec 12, 2008
    Pulled pin out and reinserted, now door will not close at all
  • Anonymous Mar 24, 2014
    door not closing, problem with hinge
  • 828 Answers
This is not a refrigerator problem BUT, you must insert a tool like a drift punch into one of the holes on the top of the hinge and rotate it away from the door position then reposition the holding pin to prevent it from recoiling.
Posted on Jun 28, 2008
Why the freezer door opens when the refrigerator is closed?
I have a refrigerator with a top freezer that was constantly popping open, just enough to let the heat in and melt anything inside. This can also cause heavy frost build up from condensing humidity in the air. The frost can build up on the front face of the fridge where it meets the magnetic gasket on the door making it even harder to keep the freezer closed.
The cause in my case was that slamming the refrigerator door sent a puff of air through the ductwork to the freezer above. The sudden pressure increase popped the freezer door open and the door wasn't heavy enough to close on its own. Since this is a beer fridge in my garage I fixed it by putting a stick on childproof latch from H-D on the freezer door. :-)
If this was our main fridge indoors, I would first check to see how much force it takes to open the freezer vs. the refrigerator section. It should be about the same. If not, check the freezer door gasket to be sure no food or ice is built up on it and that the mating surface is clean. Check that the door is closing parallel to the mating surface. A misalignment would make it hard for the gasket to seal or stay sealed. Adjust hinges if necessary. If all seems ok, check to see if the fridge is level or possibly needs to be adjusted so it tilts back just a bit to make the doors self closing and not fighting gravity to stay closed. If all else fails, inspect the door gasket to be sure it isn't broken or stiffened with age. Inspect the bottom of the door gasket with a mirror. I once had a side by side with what looked like a good gasket until I felt around the bottom of the door. Replace if necessary.
Dec 15, 2016 | Refrigerators
Liftmaster GDO goes up 1/2 way and stops,springs are fine.
The Liftmaster openers have 4 movement switches, a )opening and b) closing limit and c) opening and d) closing force. First check the door for smooth operation by opening the door by hand (disconnect from the opener with the release cord). Any binding should be felt this way. It is possible for a binding hinge, roller or torsion springs to add too much drag and cause the force switch to shut off the motor. Hinges, roller shafts and torsion springs should be lubricated at least annually with a non oily spray (silicone or teflon spray). Not WD-40 or 3-in-1! A light band of lube should be applied to the torsion spring coils. If the door can be operated smoothly by hand, then adjust the closing force switch 1/4 turn at a time. This is a safety device do not use it to overcome another problem!
Aug 15, 2014 | liftmaster Garage Door 1/2 Hp
What does the purple button light flashing on 1/2 horsepower craftsman garage door opener
I think the adjustment mode is on.
For example, that's from Craftsman manual:
Setting the Force
The force setting button is located on the left panel of the motor unit. The force setting measures the amount of force required to open and close the door.
1. Locate the purple button on the left panel of the motor unit (Figure 1).
2. Push the purple button twice to enter the opener into Force Adjustment Mode (Figure 2). The LED (Indicator Light) will flash quickly.
3. Push the remote control or control console (Figure 3). The door will travel to the DOWN (close) position.
Actually, you should just read carefully your garage door opener unit's manual.
Craftsman Garage Door Opener Remote
Jun 21, 2014 | Sears Craftsman LiftMaster Chamberlain...
Kitchen cabinet doors pop open
If the hinge is out of alignment, or simply worn out, replacement may be necessary. But, if the problem is the cabinet door (warped, or enlarged screw-mount holes) a new hinge will give you the same issue you have now. A small magnetic catch may resolve your issue with less expense and no alignment needed. It involves a small (1" square) metal plate with a single screw which you attach near the the lower corner that hangs open. The complimentary magnet attaches to the door frame of the cabinet housing (inside the cabinet). Available at even small hardware stores, the catches cost about a buck, install in a minute or 2, and will discretely solve the problem shown in your video.
May 05, 2013 | Hardware & Accessories
I have a craftsman garage door opener. Model number 4184315 7D When I close the garage door it will automaticly open by it's self. There is nothing obstructing the sensor that prevents the door from...
There are two sets of adjustments. Down position and down force, If the travel is set to far in the down position the max down force setting will trip and the door goes back up.
Adjust he down position until a slight gap is visible in the down position. Adjust slight steps until no gap is visible.
If return trips increase the down force slightly . Position adjustments are on the side, down force blue knobs on back. Note adjustment positions before beginning so if you get confused you can start over.
Hope this helps?
Jun 23, 2017 | Kitchen Ranges
My Chamberlain garage door wont stay closed. It
well the there are lots of possabilities but the most likly one is that there are shadows or pieces of debris that are on a laser detector or the chain that pulls the garage door is being heated while it is frozen which could change the signal on the closer. or you need a theremal cover on ur opperator system for the opening and closing on the door.... google always helps
Dec 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Lift-master 2000SDR remotes will open but not close garage door. Same problem with all clickers and even those programmed into the cars. What could this be and better yet, how do I fix it?
Lift-Master 2000SDR opener. Opener generally works fine from the remotes. However, first time in the morning in cooler weather, it will start to close and the reverse and the lights blink. I have checked the senors - appear to be aligned properly. I have lubed the gear and used garage door spray on the rollers and hinges at the proper places. To close the door when this happens, I have to hold the wall button.
Nov 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Oven door staying open about 1 inch
your going to have to replace both the door hinges, since they have been over extended past ninety degrees they are not able to close to ninety degrees. that is the only repair, i would also look closely at the inner door panel and make sure that is not "crowned" or bent from the force that might also need replacing
Nov 19, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Craftman garage door opener, will not go all the way up.
1.Check to see if the door is running correctly.
  A. Run the door down and pull the emergency release. See if the door will run easily by itself.
    1. If it runs hard by hand try lubricating the rollers and hinges with silicone spray or some form of               lubricant (not WD 40)
    2. If the door is heavy and falls back to the ground, you probably have a spring issue (either broken           or needs more tension) in this case call a professional door repair company in your area.
  B. If the door runs fine then check the up force on your operator (the box that hangs from the ceiling          and reads Craftsman). If the light(s) on your operator go from front and/or back, the force                      adjustment screw is on the back of the operator. If the lights are on the sides of the operator then          the force adjustment screw is on the right side (looking from the back of the operator and facing            the garage door). Turn the light blue adjustment screw with the up arrow to a higher number.
Nov 11, 2008 | Sears Craftsman LiftMaster Chamberlain...
Oven door no longer closes
sounds as if the hinges are no longer closing properly,its the only thing gonna stop door from closing, unless you can physically see something protruding from the door that would stop it. no t totally unheard of for the hinges to fail, especially after a self clean cycle
Mar 14, 2008 | GE Profile PFIC1N Bottom Freezer French...
Refrigerators Logo
1,954 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
