Question about Maxtor Hard Drive
Maxtor 90845D5 EIDE HDD jumper settings
I can't find the correct jumper settings for a Maxtor 90845D5 EIDE HDD;
I want to use it as the master for a master-slave setup with a Samsung WN321620A EIDE drive as the slave.
  • 63 Answers
Connected the 2 pins furthest away from the power connector.
Pin 1
J1 IDE Connector | J2 Power
| .................... || @ * * * || X X X X |
| .......... ......... || @ * * * * || X X X X |
J50 Master/Slave -----+ | | | | | | | +-+12V
J48 Cable Select -------+ | | | | | +---+12V Return
J46 4092 Cyl Limitation---+ | | | +----- +5V Return
J44 Factory Reserved -------+ | +------- +5V
J42 Factory Reserved ---------+
Hope this helps.
Andy
Posted on Jun 28, 2008
Maxtor 8175002 jumper settings
If you use one id cable with tow devices at that time you need hdd jumper master & second device slave mode of jumper.
http://itexpertinbd.blogspot.com/
May 10, 2012 | Maxtor Hard Drive
How do i set the jumper when installing diamond max plus 9 80gb as a 2nd disk what does cs enabled mean thank you
CS means Cable Select .Parallel data cable have two conectors.If you set jumper set on CS ,in this way ,example,you have two HDD when you plug parallel data cable in middle connector ,1 Hard drive working like Master ,2 HDD work like slave,if you plug in last connector First HDD working like slave,second HDD Master.
http://www.tacktech.com/display.cfm?ttid=379
Aug 04, 2010 | Maxtor Hard Drive
I want to add another hard drive and need to know how to set the jumpers on my maxtor 90645d3 please help.ty
if you want to boot from this drive, please set the jumper to the master position.
if this drive is for additional storage, please set the jumper to slave. and make sure 1st hard drive is set to master.
if this is the only drive in the system, please set the jumper to single or remove the jumper.
there will be a chart telling you which pins are for which setting in the jumper area, which is between the data plug and the power plug on the back of your HDD.
main thing that will cause drives to not work is 2 jumpers on the same cable and they both are set to the same thng.. i.e. master/master or slave/slave. also, if one is set to single drive it will likely bypass the slave drive.
Jan 25, 2010 | Maxtor Hard Drive
Jumper settings for a maxtor N256 master with slave
Select the maxtor HDD as master by setting the Jumper to the extreme left of the hdd; i.e. next to the data cable.
Remove all jumpers from the other HDD which you want to put as slave.
Sep 02, 2009 | Maxtor DiamondMax 80 (96147H6) 61.4 GB...
Slave pin settings
hi frined
remove your hard disk jumper & u r hard will be slave
Apr 12, 2008 | Maxtor 20.4GB 7200rpm ATA-100 HDD p/n...
Maxtor diamondmax plus 9 6y080l0
If you have you primary HDD set on Cable select, and the secondary HDD is set on anything other then Cable select (with the jumper settings on the back of the HDD) then there will be an error.. Also, if you primary is set to master/slave and the same for the secondary, it will cause problems.
Another thought, if one of your drives is SATA and the other IDE, if the IDE is set to master, there may be an issue as SATA HDD's will try to post as the master drive
Mar 24, 2008 | Maxtor Hard Drive
Sata as boot and install eide drive as d:or e:
You can slave the EIDE hard drive off of the CD Drive, as long has it is also EIDE. There should be a flat grey ribbon cable plugged into the back of your CD Drive. That IDE ribbon cable should have 2 connectors on it, one of them should be plugged into the CD Drive.
If it does not have 2 connectors, then go buy a new IDE ribbon cable that has 2 connectors, they are cheap. Or ask a friend, he/she might have extra, I always do.
Make sure you have the jumper settings correct on both drives. One will be the master, the other should be the slave. Or set both to "select select" and let the computer decide. The jumper is a little black jumper that connects 2 pins together on back of the drive. This tells the drive if it is a master, slave or cable select.
There should be a sticker diagram on each drive denoting the correct pin-jumper setting.
One other thing, when you hook up 2 drives to 1 IDE cable, both drives share the bandwidth. If you are using one of the drives, don't try to use the other, major performance slow-down.
Also, you don't need to slave the drive. You can get a Hard drive enclosure and make the drive an external drive connected by USB. They are also cheap, but make sure the hard drive has a partition and is formatted before installing it in the enclosure.
http://www.geeks.com/details.asp?invtid=COSMOS-525U2-SIL&cat=HDD
Nov 13, 2007 | Computers & Internet
New Install
replace your data cables and retry. else check your jumper settings to set as slave on the cdrw and master on the hdd.
Sep 17, 2007 | Asrock K8 Combo-Z Motherboard
Maxtor 40gb hard drive
i think it's a conflict with the two hard drives maxtor (ata) and westen dig(eide) ,.....could be wrong....maxtor 40gb....west,260gb let me know
Sep 16, 2007 | Computers & Internet
Maxtor Hard Drive Logo
485 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
