Question about Dyson DC07 All Floors Bagless Upright Cyclonic Vacuum
Dyson hi my dyson sounds as if something is catching when the brush goes round, it's very loud, it still has good suction. I have taken the plate of can't see anything or fell if there is anything obstructing the brush, could it be the belt?
  • 372 Answers
Hi.
If the brush turns freely then you will need A new clutch unit fitted to your machine.
There are loads of them on Ebay very reasonabley priced only buy new not second hand.
Manuals are available to show you how to strip down the machine from here http://dysonmanuals.llc.nu/
Posted on Jun 29, 2008
Why does the brush on my dyson 39 not work
Hi Anne, it's Jack at Dyson.
If your DC39's brush bar won't rotate, but you're confident your vacuum has strong suction, we'd be keen to take you through some further troubleshooting checks when you have your machine to hand. If we can determine that there's an issue with the Triggerhead floor tool itself, we can confirm if we can replace this for you under the free Dyson parts and labour guarantee.
When you have a moment, please give us a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU) so we can provide further assistance.
Dec 01, 2014 | Dyson Vacuums
Hi my dyson is not sucking up very well when i put it on its side and switch it on the brushes are not going round when i put the white dail to on at the bottom the brushes go round but it makes a terrible...
Sorry to hear you're experiencing a problem with your cleaner. Please get in touch with us, free, on 08002980298 (UK), or 1866MYDYSON (US). We can run through some checks over the phone and provide you with the assistance you need.
Kind regards,
Jack
Dyson Customer Service
May 17, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
My Dyson Animal has good suction and works fine for actually picking up dirt, but when I use the vacuum with the roller, I hear a grinding/rumbling noise. Its only when I use the vacuum with the brush...
Trace the path of the suction into the tank and see if there is anything loose or ingested. Also, remove the brush and clean as best you can. Perhaps there is something caught in it. Lubricate where it makes sense with some WD40.
Oct 04, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson makes loud noise
Could be damage to Fan within motor or shaft on motor..Remove brush roll and run with nothing connected to motor ,if noise still appparent then sounds like one or the other if ok then check for damage to the brush roller.../Housing..good luck
Mar 31, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My dyson vacuum motor is sounding very high pitched... The tubes are all clear and there is suction with the tubes not not real good suction on the beater brush area....
Your dirt path is clogged, probably not far from the brush area. This is the reason you noticed the hi-pitch sound coming from the motor.
You may have to remove the hose to clear it.
Jan 19, 2010 | Vacuums
When I turn on mt dyson is sounds normal. once I
With the DC14 in its upright position, and looking from the back, there is an access hatch just to the right and bottom of the dust canister. Remove this and check for any obstruction. With the hatch still removed, tilt the handle back (as if vacuuming a floor), and you should spot that the mechanism in to which the access hatch fits changes over from one hole to another. This is how suction is transfreered from the telescopic arm to the brush bar when the unit is taken out of the upright position.
With the handle tilted back, the hole you can see is one end of a flexible pipe that leads to the brush bar. Check for any blockage and/or foriegn objects. If there is no obvious problem, you'll need to check the other end of the pipe. You can do this by removing the toe plate on the bottom of the brush bar area. The plate is held by 3 or 4 half turn fasterners - a 5 pence piece is ideal for undoing these.
If still no joy, the only other thing it might be is that the brush bar isnt spinning - this isnt actually lack of suction, but without brush rotation any upright hoover is far less effieicnt at picking up bits from the floor. Brushes not spinning on a DC14 is quiet a difficult thing to fix on a DC14 as there are two separate rubber belts, one of which is hidden under a plastic cover. There is also a clutch mechanism between the belts that can cause problems some times.
Oct 09, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Very loud click/catching noise - Dyson DC07Allergy
Take the sole plate off the brush bar (with a coin or a screw driver)compartment and check for blockages near the brush bar and make sure the brush bar spins round freely.
Its sounds like the clutch is slipping (it does this to protect it self from burning out when something is stopping the brush bar from turning)
A quick test is when in upright position turn the brush bar knob to off
(usally in drive postion) then try the user position again - the brush bar should not be turning and they should be no noise
Aug 23, 2009 | Dyson DC07 Allergy Blue/Turquoise Bagless...
No suction - Dyson vacuum
Hi If the Dyson is throwing out dirt at the back, it could be three possibilities:
1) The main floor head suction channel is blocked. Check the sole plate where the beater bar is, or if you have a cylinder/pull along model check the floor heads and main extension pipes.
2) Check all the inspection tubes especially the bottom part where the main handle hose is. Also check the filters are clean as well as the Cyclone shroud honeycombs are completely unclogged. Use of the upholstery brush is ideal for dust removal on the cyclones.
3) Check the main inspection areas on the Dyson as sometimes a back log of clogged dirt can get stuck. Also check the dust channel points when then bin is taken out.
Hope all this helps!
Jun 19, 2009 | Dyson Vacuums
My dyson is making a loud horrible noise
Hi.
Check the brush roller can be moved by hand & that it is not snagging on something.
If it is difficult to rotate remove sole plate by turning the 3 plastic screws to unlock position lift plate off & clean brush roller & check you can turn it after this.
If brush roller is free to rotate the chances are the clutch is faulty & will need to be replaced.
Go to this site http://dysonmanuals.llc.nu/
It has manuals that cover clutch replacing on all Dyson models.
Sep 01, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 All Floors Bagless Upright Cyclonic Vacuum Logo
79 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
