Question about Dometic Rooftop RV Air Conditioner
Dometic a/c unit turns on and cools fine, when it reachs temp cmpressor shuts off and the fan keeps running changing pitch then throws the breaker
    President:
  • 357 Answers
Hi there
I would suggest that there is a setting on your a/c so hat when the a/c reached the rite temperature, it stops cooling and just circulates the air.
Refer to your manual to fix this problem.
Thank you for using FixYa. Have a nice day and please remember to vote this solution a FixYa, if it helps you.
Posted on Jun 29, 2008
Once my dometic av reaches temp Setpoint, it cuts off. Then immediately turns on again, then off again and continues until breaker trips. Is this a thermostat issue or a relay issue?
google it:
  1. Once my dometic av reaches temp Setpoint, it cuts off. Then ...
    www.fixya.com/.../t25789091-once_dometic_av_reaches_temp_setpoint
    1 hour ago - Whats the amp breaker? Is this for the inside unit or the outside condenser? If the inside and gas heat you have a bad fan motor, If its an electric ...
Jul 19, 2015 | Dometic Heating & Cooling
My Dometic Rooftop 15000 BTU Model 459516.701CO will come on and run and then shut off it continues to cycle within minutes of shutting off it is controlled by a Dometic Comfort Control Center 2...
THE OUTSIDE FAN MOTOR MIGHT NOT BE WORKING CAUSING THE COMPRESSOR TO GET HOT AND TRIP THE INTERNAL OVERLOAD IN THE COMPRESSOR - IF THE UNIT IS LOW IN FREON SAME RESULTS - WHEN UNIT IS FIRST TURNED ON DOES IT BLOW COLD AIR OR DOES THE AIR NOR FEEL COOL - JUST COOL AIR COULD BE LOW FREON - COLD THEN WARMS UP IS FAN PROBLEM
Jun 30, 2014 | Dometic Rooftop RV Air Conditioner
B 2200 - Fan still working - no cool air
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 08, 2011 | Dometic Rooftop RV Air Conditioner
My dometic fridge, (3 Way) for the past couple years takes quite a while to reach it's normal operating temp. I'm talking anywhere from 10 to 15 hours. Once it reaches it normal temp it stays cold until we...
Have you tried running it without the fan? I know it sounds funny but it has to get hot (outside the fridge) to get cold inside. Shut fan off and see what happens. Also, keep in mind the more items you put in it that are already cold, or frozen, the faster it will cool inside the fridge. Also take a look up the back of the fridge, with outside cover off to make sure no big wasp nests or similar up there. May need to remove cover at roof and look down if you can't see too good from back of fridge vent.
Jun 21, 2010 | Dometic RM2652 Refrigerator
Emerson quiet cool cycles every 6 mins
YOU ARE HAVEING A SHORT CLCLE PROBLEM COMPRESSOR SHOULD NOT SHUT OFF UNLESS THEMOSTAT SAY OK AT TEMP OR UNIT FREEZES UP AND FREEZE STAT SHUT COMPESSOR OFF USUALLY REALLY SHORT CYCLING LIKE YOU ARE EXPERANCING IS CAUSE BY COMPRESSOR OVERHEATING OR FAULTY THEMO SHUT OFF ON CMPRESSOR REPAIR SHOULD BE DONE BY LICENCED TECH
Jul 29, 2009 | Dometic Rooftop RV Air Conditioner
Carrier A/C in RV won't run
check your breakers make sure when running unit this is the only thing on the breaker 15 to 20 amp be sure to keep a window cracked as well unit does freeze over so don't have all the way on cold
Jun 23, 2009 | Dometic Rooftop RV Air Conditioner
RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Jun 06, 2009 | Dometic Rooftop RV Air Conditioner
A/c won't shut off have to use breaker
sounds like your run capacitor has failed you can find it if you remove the top cover there is a side acess were there is a lot of wires coming out remove that acess there should be 3 capacitors 1 fan 1 start 1 run make sure to turn the braker off before checking the capicitors remove the run capicitor & check for shorts
Jun 04, 2009 | Dometic Rooftop RV Air Conditioner
Duo-therm quick cool
Your compressor is trying to restart after it shuts off which is causing a power draw down changing the sound of the fan speed change. Check voltage power supply and insure that the power supply cord is heavy enough to carry the necessary load.
Jun 28, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
76 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
