Question about Panasonic Lumix DMC-LZ3 Digital Camera
Panasonic DMC-L75 just got this camera. I am not able to transfer the pictures from my camera to my pc. The pc does not detect a new hardware. Could the cable be faulty.
May want to try to plug usb cable into differnt usb port. I have had this problem with one of mu usb ports on computer.
Hope that helps.
Posted on Jul 07, 2008
Dmc ls80 transfer
Most cameras don't have enough internal memory to take more than 1 or 2 pictures internally. Picture transfer is normally accomplished via usb cord. The process begins when you plug in your usb and power on the camera. You have to navigate between internal memory and SD card in windows explorer.
Jul 22, 2014 | Panasonic Lumix DMC-LS80 Digital Camera
Get photos off my panasonic lumix
Photo transfer from the camera to a computer is usually done with a USB cable. For detailed instructions on how to transfer the pictures, check out the user manual:
Panasonic DMC FX8 manual
Nov 21, 2013 | Panasonic Lumix DMC-FX8 Digital Camera
I have a Panasonic Lumix DMC-FS15 when I switch on it says "built in memory card full" even though I have a 4GB memory card in the camera which is not full. The camera doesn't seem to detect...
Hi, Move the internal pictures to your card and then switch it to record to the card...
Here is a tip that may help you with your problem.... I found out that with my cameraI needed to transfer the pictures within the camera to the card and them fromthe card to the computer...
The process for your camera may not be exactly the same, but should be similar.
How toTransfer Internal Camera Memory Pictures heatman101
Aug 26, 2011 | Panasonic Lumix DMC-FS15 Digital Camera
I need exact instructions on how to get some pictures I took on the internal memory downloaded or to a card. I have no manual or cord. I have a panasonic lumix DMC LZ 7. thank you for any assistance
you can directly insert your card to a card reader and transfer the pictures that way. autoplay will popup giving you options to either view or import your pictures to the computer if it detects it or you can manually open the drive representing your card in my computer folder (if using windows operating system) and manually copy and paste it to your desired folder.
Jun 02, 2011 | Panasonic Lumix DMC-LZ7 Digital Camera
When I acquire pictures from SD card, it acquires
You shouldn't be leaving the old pictures on the card. That's a guaranteed way to get into trouble. After downloading your pictures, format the card in the camera.
If you want to transfer just the new pictures, you'll have to select those pictures for transfer. Since you declined to specify what software you're using, I can't tell you precisely how to do that.
May 15, 2010 | Panasonic Lumix DMC-LZ5 Digital Camera
I have a Panasonic Lumix DMC-ZS1. Once I transfer the media cards pictures onto the computer and then re-insert the card into the camera, all pictures seem to have been deleted. However, when I take the...
When you remove the card from the computer, do you use the "safely remove hardware" function? If you don't, the card can become corrupted enough that your camera no longer recognizes it.
Apr 26, 2010 | Panasonic DMC-ZS1 Digital Camera
Vista will not detect my Panasonic DMC-LS80 digital camera
I reinstalled the software that came with the camera. I restarted the computer and this time the pictures were transferred from the camera onto the computer.
Thank you for your interest and quick response.
Mar 06, 2009 | Panasonic Cameras
Not uploading pictures
I think I know what the problem is, first off the computer must be able to communicate with the
camera/device irregardless of the drivers. The camera is plug and play and so is the computer
unless you are using an older version of windows like 98 or 98 second edition. If you are 98 etc load
the old drivers. But if you are 2000, millineum, or xp then the drivers are automatic for the usb ports.
The panasonic dmc-fz7 is kind of a freak in that it is not a true plug and play device. Sometimes
you have to declare the new hardware. It may have once worked but for what ever reason the hardware may not jive with what the pc thinks it sees if anything at all.
Solution: Go into the Control panel , add hardware wizard, with the camera hooked up to the usb
port and the camera turned on. In the device manager you should get the appropriate message, "new hardware detected" actually it should say dmc-fz7 etc. From there it should be apparent that things are working normally....Good luck. Probably a power glitch or who knows. Mostly its a problem with panasonic plug and play software which they corrected a year or so later with the newer cameras...
Dec 22, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Help Please!!! Cannot view some pictures in my Panasonic Lumix DMC-TZ1
some of your picture was currapt ,during the transfer from camera to PC the current was unstable or some connot read by your computer.
Nov 12, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
Panasonic Lumix DMC-LZ3 Digital Camera Logo
214 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
