Question about Compaq Presario Notebook
Audio problem sound coming out from speakers even though headphone is connected.
  • Anonymous Jul 08, 2008
    I HAVE PRESSARIO C772TU NOTEBOOK
    SOUND IS NOT COMING FROM HEADFONE
  • Maggie Villegas Nov 12, 2008
    I have the same problem. I have a Compaq Presario R3240US. I've already re-installed the sound driver but it did not fix the problem. Please advise....
I format my laptop with xp sp2 and installed the sound driver and my laptop dectect it but not voicing out please help me
Posted on Jul 09, 2008
I have no sound driver pls sir give me the driver model is compaq 786 tu
Posted on Jul 05, 2008
No Speaker Sound, Thinks Headphones are Plugged in
If you don't plan on using the headphones - take the cover off and there may be a cable to the headphone jack board that can be unplugged. This will disable the headphone jack from sending a bad signal to the micro. If you want to be able to use the headphone, then the jack is going to have to be replaced.
Jun 16, 2013 | Pioneer VSX1020K Receiver
I can't get my speakers to work, I do get notification sounds though
have you tried your speakers on a different equipment to ensure they are working correctly?
Jul 26, 2012 | Vizio Tablet VTAB1008
Why does the audio cut out on acer z5700 speakers when you connect to a source at the audio output in the back.(expect this only when you connect headphones to headphone input)
When you connect headphones to your computer the computer will only send sound through the headphones and not allow sound to come out of the speakers. this is the way almost all audio drivers are setup, it detects the speakers and the headphones as 2 different devices and will only play sound through one (headphones first and if there are no headphones then speakers).
The only way I know to resolve this (and I hate this suggestion) is to purchase a headphone splitter. Connect the speakers and the headphones through the splitter, the quality of the splitter will determine the quality of the sound.
You could try going to the audio driver options (if there is any program installed by the audio driver) to see if you can get it to play through both but with both my Acer laptops I have been unsuccessful.
Hope this helps.
Mar 23, 2011 | Acer Aspire Z5700 PC Desktop
My sony vaio has no sound coming from the speakers i have tried to uninstall and install the drivers but nothing is working the sound appears to be on as media player has no problem playing anything. my...
attempt to connect external speakers or headphones. if thet work, your internal speakers are the problem and needs replacing. you may also at least check the sound properties and under playback section, make sure the correct playback device is selected. Normally, it should be the speaker/headphone audio device unless you use digital playvack device.
Dec 31, 2010 | Audio Players & Recorders
It turns on,everything works normal and sound even comes out of the headphone jack.but there is no signal coming out of the speaker jacks.no sound or test tone
Hi depending on the design some receivers , when you plug in headphones, speaker sound is disconnected by the headphone socket so it could be faulty, or there may be a separate switch to switch of the speakers, (while using headphones) if so that switch could be suspect. I dont think the amplifier part of the receiver is at fault as you say you can hear sound at the headphones. It is not impossible though that a fuse has blown inside the amp, If you unplug from mains and look inside you may spot a blown fuse , (only replace with one of the same rating).
Hope this helps
pete
Nov 14, 2010 | Teac AG-V8060 Receiver
How to connect headphones to this tv.
The only way to accomplish this will require an external amplifier.
Connect the program out to the input of the external amp and use the headphones from there. Disconnect the speakers or turn them off in the audio menu.
Hope this helps,
Dan
Jul 11, 2010 | Panasonic TH-42PX60U Television
Compaq CQ60 104TU
Kind of confused with the question.
I would suggest you look at the line out and make sure that is not muted withing the sound settings.
Sometimes that happens.
If you are using the headphone part and you plug in the headphones it should turn off the computer speakers and goto the headphones.
If not then there is a different issue.
Happy Holidays
Dec 19, 2008 | Compaq Presario Notebook
How to avoid sounds heard in speaker even after connecting headphone in compaq presario c700
Asalam u alikum,
Dear friend yours broblem have been solved if you do this steps.
1. first go to the start menu.
2. then select a control panel.
3. In control panel select option (sound,speech,audio devices) then select change the speaker setting, the sound and audio properties is opened, go to the speaker setting select advanced option in advanced option change the speaker setup and select stereo headphone and apply it.
I hope its solved yours problem.
Thanks
Oct 14, 2008 | Compaq Presario 700 470024-192 Notebook
No sound from speakers
Believe it or not, not all speaker plugs, even if they are of the same size are NOT made the same.Some times the "male" PLUG pushes into the "female" socket in such a way that it makes NO connection or does not make the right connection causing the headphones not to work.
TEST: play music that u can hear through the internal laptop speakers, and while the music is playing, plug in the headphones.
The internal speakers SHOULD cut out, and under normal conditions the music should pass through the headphones.
If the speakers cut out and the headphones don't work, your plug is damaged.
If the speakers DON'T cut out after u plug in the headphones, your plug is open.
Depending on the audio circuit, your audio amp. inside the laptop is going to get damaged.
It depends on the WAY the audio circuit was made.
May 15, 2008 | Audio Players & Recorders
No audio
Hi
Pls check if the audio settings on the monitor are correct. Along with the monitor menu button, there will be another button for audio for some models. For other models the audio option will be available in the menu button itself.
Pls check with another set of powered speakers and not headphones.
Also check for the drivers and any driver updates for your sound card.
Hope this helps fix your problem.
Jan 28, 2008 | Acer AL1717 17" LCD Monitor
Compaq Presario Notebook Logo
196 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
