Question about RCA Televison & Video
Rcaflat screen m134c chassis
Channels continuelly change by themselves
  • 1 more comment
  • charlescates Jun 28, 2008
    that is not the problem, The set also turns on
    and off by itself and when it finally stays on
    the channesls flip one to another and so on.
    I am a technician and have been for many years.. This set has a problem that I
    haven't seen out of these newer sets. Sometimes you can hold volume down
    button on the set and make it hold on channel 3 which I am using for sat.
    Other times the will just click on then off several times a minute. or until it decides to
    stay on.
  • charlescates Jun 30, 2008
    on the rca 134c that I asked you guys about. I found a micro chip and it fixed my set.
    Thanks for trying to help.
    charles cates
  • 63 Answers
It might be worth trying a mains conditioner (RFI suppressed anti surge power lead) on the set.
How often does it change, a few times a minute, or a few times an hour?
Posted on Jun 28, 2008
  • 1,879 Answers
Turn the TV OFF
Remove the batteries from the remote
Turn ON the TV
If the issue still persists, check the channel-changer buttons on the TV
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Vrtical problem
What is the problem you faces with this TV? Vertical rolling? Vertical jitter? Provide more details please.
Jan 04, 2013 | RCA Televison & Video
Where is the fuse for my 46"RCAflat screen tv?
It should be located on the power supply board, just follow the power cord, it should lead you to the power supply board. You will have to take the back of the set off to access the fuse.
Jul 24, 2012 | RCA Televison & Video
RCA TV changes channel and volume, and shuts off by itself.
ok its not a cap problem.. memory ic problem...u have to replace memory ic the nos are i think 24c16 or24c08
u have to buy the memory by giving ur model no of the tv
Mar 06, 2010 | RCA 27V520T 27" TV
TV turns on and off while watching.
re solder the Electronic semiconductor , IC Specialy in power supply side. cold solder might the cause.
Jun 07, 2009 | RCA 27V520T 27" TV
Rca rear projection broke?
This may help with yours since it was built in 99
Product Safety Information Product Safety information is contained in the appropriate TCE Service Data covering models/chassis referenced herein. All specified Product Safety requirements and testing shall be complied with prior to returning equipment to the customer. Servicers who defeat safety features or fail to perform safety checks may be liable for any resulting damages and may expose themselves and others to possible injury. First Edition ¾ First Printing Copyright 2000 ¾ Thomson Consumer Electronics, Inc. Printed in U.S.A. ¾ Trademark(s) ® Registered ¾ Marca(s) Registrada(s) Symptom: Shutdown during channel change, shutdown during autoprogram, dead set or unexplained random shutdown. Cause: Incorrect F2PIP Power on Reset (POR) timing Cure: Product Support · Mail Stop INH 900 P.O. Box 1976 · Indianapolis, IN 46206 -1976 TV 00-003 Television TTI TV 00-003 MODELS: CTC195/197, MM10x, CTC203 Chassis with F2PIP DATE: July 14, 2000 TOPIC: F2PIP The following modifications are required to change FPIP POR timing for added reliability. NOTE: All chassis manufactured after 950XXXXXX have the modification installed. Follow these steps in order. All CTC195/7 – All CTC203 1. Insert a 2.2K ohm 0805 size SMD resistor from pin 21 of U18100 to ground (192096). Note: This may require “piggybacking” the resistor on top of C18114. MM101 Chassis 1. Insert a 2.2K ohm 0805 size SMD resistor from pin 21 of U18100 to ground (192096). Note: This may require “piggybacking” the resistor on top of C18119. The next steps are dependent upon the chassis under repair. CTC195F, F2, F3 chassis 2. Replace R18111 with a 100K resistor (192084) 3. Replace C18118 with a 330nf cap (220132) 4. This concludes the modifications for these chassis. CTC195/7 (except CTC195F,F2,F3) and all CTC203 2. Replace R18116 with a 100K resistor (192084). Both are off pin 23 of U18100 3. Replace C18121 with a 330 nanofarad cap (220132) 4. This concludes modifications for these chassis. MM101 Chassis No further modifications are necessary.
Apr 02, 2009 | RCA P52921 52" Rear Projection Television
That is a M134C chassis - one of the most inexpensive (throw-away) chassis ever built and the so-called v-chip is actaully a function of the micro, short for micro controller Ic. It would be less expensive to replace the entire board, RCA p/n# 268733 which is around $70.00 bucks plus shipping, than to replace just the micro.
You can find them available at Vance Baldwin... Just login as guest and enter thr RCA part number above and order it there.
Putting in an entire chassis is a plug-n-play repair...
Hope this helps.
Feb 11, 2008 | RCA TruFlat 27F520T 27" TV
RCA M134C 27V412T
hi there, you can try the front panel switch to unlock it or to turn it on. if still same problem you do have an electronic parts trouble with your unit. check the power supply section of your tv and test some electronic parts. ty
Dec 24, 2007 | JVC AV-27D302 27" TV
RCA color tv,model 27F520T,Chassis M134C
On the tv panel push and hold volume down until volume is all the way down and keep holding, then push the info button on the remote.
Dec 21, 2007 | RCA TruFlat 27F520T 27" TV
Vehicle icon tracking on route
Under settings, Navigation, verify that Vehicle is set to Car/Motorcycle.
Sep 03, 2007 | Garmin Nuvi 660 GPS Receiver
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
