Question about Dometic Rooftop RV Air Conditioner
Duo-therm quick cool
Unit turns on runs cool, when it reachs temp compresssor shuts off fan keeps running changes pitch and throws the breaker.
  • txtruckertx1 Jun 28, 2008
    may there have been a problem with the camp grounds power supply or the reseptical
  • 828 Answers
Your compressor is trying to restart after it shuts off which is causing a power draw down changing the sound of the fan speed change. Check voltage power supply and insure that the power supply cord is heavy enough to carry the necessary load.
Posted on Jun 28, 2008
  • James Helmer
    James Helmer Jun 28, 2008
    Glad we could be of some assistance.
Duo therm rv air conditioner repair
Sounds like thermostat is failing. There is a factory set resistor that helps the thermostat keep a 2 degree accuracy. Second possibility is that you have a fan or direct airflow from the cooling system, being devirted, that is allowing the cool air hit the thermostat on the wall.
Aug 17, 2013 | Heating & Cooling
Duo Therm A/C (2009 Sabre RV) won't shut off
bad compressor relay on control board. The relay is not opening the circuit, allowing the compressor to stay running when unit is turned off. This overheats the compressor and opens a thermal disk shutting the compressor off. When thermal disk cools down, the compressor restarts under load and trips breaker.
Jun 06, 2013 | Dometic Rooftop RV Air Conditioner
Duo Therm Fan Blows, No cool air. Worked yesterday, not today?
most likely compressor running could be capacitor, breaker,relay,or compressor it self start by checking power to unit
Aug 22, 2009 | Heating & Cooling
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Dometic a/c
Hi there
I would suggest that there is a setting on your a/c so hat when the a/c reached the rite temperature, it stops cooling and just circulates the air.
Refer to your manual to fix this problem.
Thank you for using FixYa. Have a nice day and please remember to vote this solution a FixYa, if it helps you.
Jun 28, 2008 | Dometic Rooftop RV Air Conditioner
Duo-therm 13500 btu
First I would check the size of the power supply cord to the coach. To small a line will cause a voltage drop which in turn will cause the amperage to increase. Check the supply voltage to the system.
Jun 16, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
881 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
