Question about DeLonghi DE500 Dehumidifier
Internal pum hose connection?
My drain hose was clogged so I took it apart, cleaned the hose, cleaned the connector at the bottom of the machine. Now the pump does not pump so the tank fills. I pulled the tank and the upper end of the clear hose is not connected to anything and I can not see any fitting for it. Any assistance is most appreciated.
  • 30 Answers
I just fixed the same problem on my DE-500P. The pump filter was blocked and there was a layer of scummy lint-like stuff in the bottom of the pump reservoir (not the main - or overflow tank) also blocking flow down through the filter to the pump. Repair steps are as follows:
1. Remove the overflow water tank and the two side covers (five screws in each). Note that as you go through the removal of all the covers and other procedures, there are two lengths of screws; don't switch them. If you lose track, the rule of thumb is use the short screws for going through a single layer of plastic into metal.
2. Remove the rear cover (take out the screws along the bottom and on the sides). It will still be attached to the front top cover at the top with tab fasteners. Gently pull out the bottom of the cover while depressing the top of it on both sides with your thumbs (about an inch and a half inside the trim ridges) to clear the tabs. Ease the top part of the cover back and remove it (it will have to tilt to one side, don't forget this when putting it back on).
3. Remove the top cover, not forgetting the two screws on top by where the back cover attached (go gently, there's a wiring harness) and turn it to the side. There was enough slack to leave the wires connected; just be careful to not damage them.
4. The filter looks like a small transparent in-line gas filter. Remove the pump filter, leaving the short tube attached to the top of it. I quickly atttached a length of tubing to drain the reservoir into a bucket. I couldn't find a replacement filter, so I filed a slot in the side of the bottom half of it to remove the gunk using the wire from a twist tie (the upper half had some tabs inside that would have been in the way). Afterwards, I wrapped it tightly with stretchy electrical tape and put a wire tie over the tape at the slot to keep the tape from being able to creep loose over time. Don't use a fuel filter, the paper element is too fine (you need a screen) and the paper will fall apart in water.
4. Remove the float and bracket from the pump reservoir. The reservoir screws are not all apparent; there's also a screw way over on the left and one coming in from the right. I used a 12 inch #2 phillips screwdriver with a magnetized tip for most of this. Remove the pump reservoir and clean out the scummy stuff in the bottom and where the tubes attach. When removing the reservoir, you'll have to detach the vent line that goes through the bulkhead to where the big tank was and pull the tab above it down slightly while easing the tank out.
5. Clean out any dirty tubes, paying particular attention to the coupling for the drain hose and the long drain hose itself.
6. Put the reservoir back in and hook up all the tubes and filter. It does make a difference in which direction the filter goes back in. You want the water from the reservoir to go through the filter from the outside of the little screen; that leaves the maximum room for crud build-up before it plugs up the screen again.
7. Depending on your confidence level, at this point you may want to plug in the dehumidfier, put the overflow tank in, turn it on, turn on the pump, and fill the pump reservoir to check for functioning and leaks. If you do this, just remember that the circuits are hot and not all are insulated.
8. If all is OK, unplug the dehumidifier and put the covers back on. Total time was about an hour.
Posted on Aug 30, 2008
Water will not drain through connected drain hose
The problem you're experiencing can be caused bu 2 things: The drain hose is clogged or to long or the inner drain tubing to the hose connection is clogged.
The drain hose clog is is easy to solve. However, the inner tubing clog takes a little more effort.
First turn the unit OFF & unplug it. Disconnect the drain hose. Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hose connector hole and inner tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow.Reconnect the drain hose, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor the hose end for water flow. be patient as it may take 5 to 10 minutes to start flowing.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers
Hope this helps you to solve the problem. Thanks for choosing FixYa.
Sep 20, 2011 | LG LD50EL Dehumidifier
My M7DH65B2A model has suddenly started to leak from the bottom of the housing. I have a hose drain installed and that connection feels dry. Also, the bucket is dry, as it should be with the hose...
No need to take the unit apart. The "gunk" or clog is he inner tubing of the hose connection.
To solve the problem, do the following:
Turn the unit OFF, unplug it and disconnect the hose.
Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hose connector & tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reconnect the hose, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor it for any leakage.
I hope this helps you solve the problem and thanks for choosing FixYa.
Aug 25, 2011 | Maytag Dehumidifiers
Hose hooked up but bucket fills anyway. Hose is attached to internal nozzle. Is that right?
The problem you're having is generally cause by the drain hose or drain hose connection being clogged. When that happens water is diverted to the bucket. To solve this problem do the following:
First disconnect the drain hose for clogs to check for a clog.. Also, the hose should be no longer than 5 feet. If the hose is clear, the clog is in the hose connection or tubing.
Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow. Reinstall the bucket, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor ithe hose for drainage.
I hope this helps you & thanks for choosing FixYa.
Aug 06, 2011 | Soleus CFM-40 Dehumidifier
I have a hose hooked up in the back to continually drain water but it isn't working. I have to keep emptying the water. How do I get it to work? And if I take out the plug water leaks everywhere.
The problem you're facing is either a clog in the drain hose or a clog in the hose connector's tubing.
The drain hose is an easy one to insect and clean, if necessary. For the hose connector tubing, you need to do the following.
Turn the unit OFF & Unplug it.
Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hole or tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow.Reconnect the drain hose, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor it for drainage thru the hose.
Hope this helped you solve the problem. P;ease let me know. Thanks.
Jul 14, 2011 | Danby DDR2509EE Dehumidifier
I have a new Frigadaire dehumidifier , 50 pint, which I have connected to a garden hose to be emptied into a drain in our basement. So far, after, two weeks, it fills up with water and we have to...
I'm really surprised that Frigidaire didn't know what the problem was. The drain tubing at the hose connection is clogged or the hose itself is clogged. When this happens, water is diverted to the bucket.
First, turn the unit OFF & unplug it.
The hose clog is easy to solve. Simply remove the hose and either look thru it for light at the other end or blow through it. Make sure the hose is no longer than 5 feet.
To clear a clog in the drain hose connector, you will need an 18" long plastic Zip Tie or something similar (NO wire coat hangers, though) that is appropriately sized to fit in the hose connector tubing.
Carefully insert the Zip Tie and continue to insert it, until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until the Zip Tie bottoms out or you run out of usable Zip Tie. Slowly remove the Zip Tie while rotating (twisting) it. This will dislodge any clogs. As you each the inserted end of the Zip Tie, be prepared for some water to follow.
Completing the above, should solve the problem. Then call Frigidaire and tell them how to solve the problem.
Hope this helped you. Please let me know. Thanks.
Jul 06, 2011 | Dehumidifiers
Our new unit will not drain through the garden hose into the drain it just keeps filling up the bucket
Despite it being new, it sounds like either the hose is clogged or to long (no more than 5 feet in length) or is kinked. The other may be, that the hose connection on the dehumidifier is clogged.
After checking the hose for clogs and length and finding nothing. The clog is in the hose connection tubing. To remove the clog do the following.
Turn the unit OFF and unplug it. Using an 18" long plastic Zip Tie or something similar (NO wire coat hangers, though, carefully insert the Zip Tie into the hose connector tubing, Continue to push it in, until you reach a bend in the tubing. You will gingerly have to work the Zip Tie past this bend, until the Zip Tie either bottoms out or you run out of usable Zip Tie. Then pull the Zip Tie out slowly, while rotating (twisting) it. This will dislodge any clogs. As you reach the inserted end, be prepared for some water to follow.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jul 01, 2011 | Whirlpool Dehumidifiers
We have a Frigidaire 70 pint dehumidifier (model LAD704DUL). We hooked up the hose so we could use the continuous drain feature but the unit just keeps draining into the bucket. We followed the...
This happens quite frequently. It''s due to a clog in the hose or the a clog in the hose connection tubing. If you unit has a float valve in the top of the bucket, be sure that it's not stuck in the UP position. To resolve clogging problem, do the following:
1. Turn the Master ON/OFF Switch to OFF and unplug the unit. Disconnect the hose from the unit
and check for clogs and remove them if necessary.
2. If no clogs were found in the hose, the clog is in the hose connection tubing. Use and 18"
long, plastic ZIP Tie, appropriately sized to fit in the hose connector tubing. Carefully insert the
Zip Tie or something similar (NO Wire coat hangers, though) into the hole and continue to push
it in until you reach a bend in the tubing. You will need to gingerly work it past this bend, until
the ZIP Tie either bottoms out or you run out of usable ZIP Tie. Then while rotating (Twisting) the
ZIP Tie slowly pull it out. As you reach the inserted end of the ZIP Tie, be prepared for some
water to follow.
That should solve the problem. Be sure the hose is no longer than 5 feet and that it slopes downward from the unit, with no kinks in it.
Hope this helped you solve the problem. Please let me know, Thanks.
Jun 27, 2011 | Frigidaire FDL25P1 Dehumidifier
I own a Whirlpool Dehumidifer Model Number AD 70USS1. I have a drain hose connected to the unit, however, recently the unit's internal collection bucket fills with water to the point that the...
superstee - You're having to empty it because either the drain hose you have connected to the unit is clogged or the drain hole a the hose connection is clogged. Therefor, the water is drained into the tank, rather than the drain hose. Also, the drain hose would not be any longer than 5' and must drain down, as the dehumidifier does not have a pump. It relies totally on gravity.
Remove the hose and check it for clogs. If clear check the drain hose connection, using an 18" long appropriately sized Zip Tie. Carefully insert the Zip Tie and continue to push it in until you reach the bend in the tubing. Gingerly work past this bend, until the Zip Tie bottoms out or you run out of usable Zip Tie. The while slowly pulling it out, rotate the Zip Tie. This will dislodge the clog. As you reach the end of the Zip Tie removal, be prepared for some water to follow. CAUTION: BEFORE DOING ANY OF THE ABOVE TURN THE MASTER ON/OFF SWITCH TO OFF AND UNPLUG THE UNIT.
The above should solve the problem for you. Please let me know. Thanks.
Jun 08, 2011 | Whirlpool Gold AD70USS 70 Pint Per Day...
Hose connected to drain, but still leaks water on floor
Had the same problem. Make sure you tighten the house a little with pliers. Also, make sure the dehumidifier is up a lot higher than where you're draining it into. Mine drains into a utility sink. But I have the dehumidifier propped up onto a dresser. I cut a small piece of hose to run into the sink. Seems to be working now.
It will take 5 min or so to establish a water flow, so be patient after you hook everything up. Good luck.
Jul 12, 2009 | Maytag M7DH65B2A Dehumidifier
Drain hose not working
Hi, had the same problem. Not a glogging one. I have the model DDR503H. If it is insisting on filling the reservoir, it is because you haven't put the cap you removed from de back of the unit to plug the hose on the tank water exit. You have to first remove the tank and on the roof of this space, you will see the water tank exit where you can screw the cap removed from the back. You place back the tank into the unit and now the water won't have other choice then leak thru the hose. Also. to clean up the filter, I don't need to unscrew the top cover. I just remove the tank and on the roof of the space, there is a grey handle with arrows on it and I just pulled down, it comes out and you can then clean it up.
Hope this help,
Steeve
Jan 05, 2008 | Danby DDR401 Dehumidifier
DeLonghi DE500 Dehumidifier Logo
293 people viewed this question
Top DeLonghi Dehumidifiers Experts
Mike Kolbay
Level 1 Expert
Are you a DeLonghi Dehumidifier Expert? Answer questions, earn points and help others
