Question about GE Refrigerators
Fridge wont stay cold in the bottom.
I have a frost free fridge and it wont stay cold in the bottom. the top is freezing and ice is building up in the top. i was wondering what would be the problem.
  • 828 Answers
Your frost free is not defrosting properly. There should be no ice buildup in the freezer section. Frost in the freezer section stops air circulation to the refrigerator section.
Posted on Jun 28, 2008
Why wont my fridge stay cool?
MAKE SURE THE FAN IN THE FREEZER IS RUNNING THATS THE ONLY WAY THE REFRIGERATOR STAYS COLD DO YOU HAVE AN ICEMAKER IF YOU DO IS IT WORKING OR A DEFROST PROBLEM ANY ICE OR FROST BUILD UP IN THE FREEZER
IF YOU SEE IT ON THE WALLS ITS FULL BEHIND THE WALLS OF THE FREEZER
Jul 11, 2014 | Frigidaire Refrigerators
The contents of the refrigerator freeze even on low settings
One of the most common problems with freezers is their tendency to build up a thick level of frost and ice that can disrupt performance. The ice can form on the hoses and cause the fan to freeze up. While you want the freezer to be cold, too much ice is not good for the freezer or the food inside it. There are multiple reasons a freezer could start to develop frost buildup.
Freezer Overstocked
Frost can build up in the freezer if there are too many items inside of it. Air cannot properly circulate around the freezer, so the areas with the sitting cold air can freeze the moisture. Frost continues to build up and accumulate, which then allows it to spread. If food is stocked up near the fan, cold air can't get past it, and the fan itself could develop frost to the point where it freezes and stops working entirely. This can be prevented by not overstocking the freezer and by evenly distributing food throughout.
Temperature Setting Too Low
The freezer should have a thermostat that regulates how cold it gets. If the temperature is set at too low of a setting, the freezer kicks into high gear, the air freezes outright and frost quickly builds up. Adjusting the thermostat to a higher temperature or level can counteract this problem, but you may need to de-thaw the freezer to eliminate the frost that has already built up inside.
Keeping the Fridge Door Open
Many people keep their fridge door open for extended periods of time while they examine the contents inside to see what they want to eat. This can contribute to frost buildup in the freezer, because the fridge is taking in a lot of warm air during this process and the fan pushes it up into the freezer. The moisture in that air is then quickly frozen, and ice can build up substantially as a result. The longer the fridge door is held open, the more likely this can occur, so the best solution is to only keep the fridge open for short intervals and then to not open the door again for a while.
Hope this tips will help you. : )
Aug 17, 2011 | Refrigerators
Not cold enough. freezer works but fridge wont stay cold. i can shut it off for a day and it will work for two more. after that it quits again.
It you have a frost free fridge, then what is happening is that either the defrost element or the thermostat is faulty, causing ice to build up and block off cold air circulation to the fridge. Sometimes the frost builds up around the circulation fan and ceases it up.
That is why when you turn the fridge off for a day, the frost melts and drains out the back of your fridge and so the fridge works ok for a few days until the frost build up again.
Another thing to watch out for is the defrost timer. Sometimes they fail and stick on one cycle and dont advance through. pull your fridge out. The timer is located in the back near the compressor. There is normally a small dial on it. With the fridge turned off, you can twist the dial clockwise and you will hear the timer mechanism click through the different cycles. Make small ink mark on the timer dial. Say at 12 oclock. Turn fridge on. Chech the fridge every couple of hours and see if the mark advances through and does not get stuck in one position for lengthy periods of time. The defrost cycle should normally be around 8 hours and it repeats again.
Let me know if you need more help with the defrost element or thermostat. But it is best to get an experienced repairer to change those.
Good luck
Ash
Oct 31, 2009 | Estate TT21AKXKQ / TT21AKXKT Top Freezer...
My fridge wont stay cold.
it is not frost free , there is no fan , this fridge for light office use , also make sure gasket is ok , good luck:)
Sep 12, 2009 | Haier (B000194UBA) Compact Refrigerator
Moisture/Ice build-up in Refrigerator
ok first of all. the refrige is in the basement. do you know what the relative humidity in the basement is?
you can check this with a humidity gauge.
May 26, 2009 | Maytag Admiral Top-Freezer Refrigerator
I have a Roper RT21LMXKQ00 Freezer wont freeze
The problem is a defrost problem. The freezer coil has frost on it and thus restricts the cold air from flowing. This affects the refrigerator as it gets its cold air from the freezer. The ice will not make if the temperature is above 12*F and this also is why ice cream is like mush.
Apr 23, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Top of refrigerator wont stay cold
The light should go off when you close the door. The fanmotor does not operate if the door is open. If it is a frost free unit, it is possible that your defrost system is not working and therefore building up ice in the freezer section and preventing the circulation of cold air to the fridge part.
Mar 08, 2009 | Refrigerators
My fridge is not cold enough and the freeze is colder and has ice
hi. thanks for the question. the drain tube that goes down to the drain tray is clogged. turn fridge off .pull fridge from wall. remove back panel clean all coils. let it thaw with doors open, it will thaw quiker. when thawed, clean the drain tube. this will solve the problem. thanks the appliance doc
Sep 28, 2008 | Refrigerators
Freezer not freezing enough and fridge not cold enough
Hello Scott, remove the food from the freezer side and remove the rear freezer panel. You will see a coil and it should be completely frosted over. If not then you have a sealed system issue. If it is froze solid in frost where you cannot even see the coil, then you have a defrost issue. You should have a little frost on all the coil, the defrost is what clears the frost so the evap fan motor can circulate the air thru out the unit. If frost is good, push the light door switch to start the fan. If it isn't running check for 120 volts. If it has voltage, but not running, replace the motor. Hope this helps.
Aug 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
I've got an electrolux frost free fridge freezer and it is not freezing. The fridge is cool and cold air is entering the freezer compartment but it is not cold enough to freeze the food. I've removed all...
remove the back panel inside the freezer and check for ice build up on the evaporator pipework. if ice build up, this prevents air flow and hence temp rises.
remove ice carefully with a hair dryer and it should work. if problem comes back, you have a problem with the defrost system and get back to me if you want
Aug 05, 2008 | Electrolux Refrigerators
Refrigerators Logo
372 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
