Do you have the gas range?
Figure below shows the probe clipped under the grille. You remove the grates and grate supports, then lift the grille a few inches to access the probe. Before removing, note the position and orientation and make sure to put it back the same way.
If this is not the right oven, please reply with or enter a new request with oven model number.
You can see how to reach the temperature probe in the following video which is very clear
I have a viking 48 inch Professional model range and oven. I need to replace the thermostat under the griddle. How do I access the tempurature probe that is under the griddle. I have to replace the whole assembly because of a broked stem on the knob.
This appears to be the information I needed. I believe it will help me immensely. Once I have attempted repair I will respond again. Thank you for your advise.
