Machine wont spin or empty - Washing Machines
  • Dawn61 Jan 14, 2009
    Same machine. Same problem. Still have clothes in water in the washer and can't get them out. How do I get the clothes out without breaking anything? And how do I fix it so it will spin and empty?
More than likely the pump is blocked or broken. Pump needs cleaning out or replacing
Posted on Jun 28, 2008
Why has my machine not drained or Spun.
Cant be 100% but could be overloaded, turn off, set dial / program to spin and try again, may need several goes to empty.
Jan 13, 2016 | Washing Machines
Zanussi z918 washing machine wont empty or spin although the pump seems to work
if the pump seems to work, check outlet hose for blockage/check pump filter as well
Dec 09, 2011 | Zanussi Washing Machines
Zanussi zwf12070wi machine indicates cycle is
flashing red start/pause button, wont spin or drain
Jul 13, 2010 | Zanussi ZWF12070 Front Load Washer
Washing machine wont spin
If your washing machine wont spin it and wont empty the water it is a blocked drain pump. You may have a faulty lid switch or it could be going out of balance.
Feb 25, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Wont spin
Probably down to the water not emptying from the machine in the empty cycle and the machine won't spin because there's still water in the drum. If this is the case, the root of the problem is almost certainly a blocked filter, restricting the draining of the water and not allowing it all to pump out in time during the empty cycle. You probably need to find and clean your filter.
Feb 02, 2010 | Washing Machines
I have a Legacy SAV405DEWW machine wont run
I just had the same problem. The washer would stop about 2/3 through the spin cycle and not start again. Replaced the timer. That did NOT solve the problem.
Jul 20, 2009 | Maytag Legacy Series Top Load Washer
Smelly drain and wont spin properly
check filter may need pump then flush through on hot wash.
Jun 29, 2009 | Washing Machines
Matag top load washer wont spin or empty
Set the timer for manually for the spin cycle and trun it on.
If it does not spin replace the lid switch.
Mar 14, 2009 | Maytag Washing Machines
Washer wont empty and spin
BAD LIDSWITCH OR THE SCREWS ON THE LEFT SIDE HINGE ARE LOOSE CAUSING THE LID TO BOW UP APPLY PRESSURE ON THE LID TO GET IT TO START SPINNING IF IT DOES TIGHTEN THE SCREWS ON THE HINGE IF IT DOESN'T THE LIDSWITCH NEEDS TO BE REPLACED
May 30, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Fills washes rinses but wont spin properly or empty out washer, ends cycle half done, wont pump water out or spin out. i can hear the machine hum while trying to do so. Please any ideas. THanks
its likely the pump is blocked (hence the humming) with a coin or some foreign object. To check, lower the outlet hose to ground level to allow the water to empty. Tip machine back & lean against a wall, remove the pump & remove object if there is one! Reassemble & try machine again
Oct 19, 2007 | Hotpoint Aquarius WF215 Front Load Washer
Washing Machines Logo
129 people viewed this question
Top Washing Machines Experts
