SOURCE: Using windows 7. Have a Zebra LP2844 printer
I dont think this model has a Windows 7 driver. You can check the Microsoft hardware compatability list to see if your printer is listed.
SOURCE: I have Zebra tlp 2844
So you have Zebra LP2844 or TLP 2844?
try diferent driver and print test page
www.seagullscientific.com
SOURCE: I have Zebra LP2844 printer
To send text to printer in dos command you should first install a driver from
then in the properties you can use send file to printer.
To send the files from command :
Check if the program ssdal.exe has been correctly installed.
to have help use ssdel help send at dos prompt
to send the file
ssdal send filename printername should do the trick
hope it helps
