Question about Refrigerators
My refrigirator is not giving the temperature that it should. I hear a relay clicking when it shoul start but it clicks secounds after the first click. It is not giving the cold expected
  • sfprintman Jun 28, 2008
    Brand: Kelvinator
    Model #: CRT17WRWO
  • 828 Answers
From your description it sounds like you have a compressor failure problem. If the unit is beyond its warranty I recommend that you purchase a new refrigerator rather than repairing the old one.
Posted on Jun 28, 2008
Moter seems hot,freezer also makes a loud clicking sound every 30 secound
The clicking noise is the overload and relay trying to start the compressor. If you continue to let it click it will eventually break your compressor. Replace the over load and relay.
Dec 28, 2011 | Freezers
Frig warm compressor clicks on for about 20 secounds then goes off
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 26, 2011 | Frigidaire Refrigerators
It doesn't cool, and in freezer side its collecting water, and also water dripping in the refrigirator .
If this is happening while compressor is running normally , first check temperature of condenser coils (black tubing)while running. If hot to touch,compressor is ok.(Good news)If not hot ,it's shot,or your defrost heater stuck on.(not likely)
If compessor not coming on at all it could be a control problem.eg thermostat ,or stuck defrost timer.
If compessor wants to come on or you hear clicking ,suspect start relay or start capacitor.
hope this helps
Aug 15, 2011 | Whirlpool ET8WTKXK Top Freezer...
The refrigirator is not getting cold
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Dec 13, 2010 | LG Refrigerators
GE refrigirator constantly changes temprature
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Oct 25, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
My refrigirator has not working properly, the colling system does not working properly. where do i complain????
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Call the manufacturer directly at there customer service number..
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 11, 2010 | Refrigerators
1991 gmc jimmy over fueling at start up, it wont start unless you push the gas pedal then it runs rough if you let off it stalls. It is getting way to much fuel...
Sounds like the relay is not shutting off fuel pump. Turn the key to on position ( not start ), pump should only run for a few secounds and you will hear a click and pump should shut off, if it keeps running relay is bad. If it works like it should than fuel regulator (if there is one) would be the next posability.
Apr 08, 2009 | 1991 GMC S-15 Jimmy
The fryer was working normal. Then the temperature light went out and the fyer is not coming on whe I flip the off an on switch
The first thing you need to check for is a high temperature limit cutout switch. It will be located near the gas valve but on the right side it wil have a cover that will snap open. it is about the size of 4" X 1 1/2". Once you get it open puch the button in you shoul dhere a click. When you hear the click you are reset. Once you turn the fryer back on use a temp probe or a type K thermocouple w/ a meter to check temp. if it starts over riding temp shut the unit off and replace the t-stat and the t/l cutout switch.
Thanks
Jul 20, 2008 | Garland AF-5025 Deep Fryer
Freezer has quit working and now refrigerator not cooling like it should.
If you hear the start relay clicking after the compressor tries to start then you know that there is power to the compressor.
This tells you it is ether a bad start relay or a bad compressor.
At this point I use a meter to see if the compressor is shorted to ground.
If the compressor is not shorted then replace the start relay and give it a try.
You should hear the compressor start right away with a new start relay if that was the problem.
If the compressor is shorted to ground you will need to have the compressor replaced.
Given the history on whirlpool refrigerators in the 5 year old age range It may be good chance that a new start relay will fix your refrigerator.
If the start relay is bad you will hear it try to start the compressor and then click off.
If the relay is bad you will hear the clicking sound seconds after plugging it in and then again every minute or two as it keeps trying to start the compressor.
Jun 02, 2008 | Whirlpool Refrigerators
Freezer and Refrigirator not cooling
You didn't say if the compressor is running or not. If it is and all other things you stated are running then it has a sealed system problem. The sealed system comes with a 5 yr warranty in most cases (check owners manual). If the compressor is not running then listen for a click at the compressor. If you hear the click then I would replace the relay on the compressor. If you need further help I will need the complete model # off the sticker inside the fridge section.
Nov 09, 2007 | Refrigerators
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
