Question about Whirlpool Duet GHW9150P Front Load Washer
Water collects in tub
Water collects (machine is off - door open) overnight and spills out all over the floor
  • Anonymous Jun 28, 2008
    water collects in the tub when machine is off
Called for a under warranty repair on my Whirlpool GHW9400PW4
Posted on Jun 29, 2008
My frontloader washer wont shut off and the water wont go in. we cannot open the door. How do we fix this. It is only 2 days old
This is a warranty situation. Contact the seller. Otherwise you can take the panel off under the door. There are three screws on the bottom edge. You lift and pull the panel off. You can then see the drain plug and you unscrew that. If you do that though you will get ALL the water from the tub to spill out on the floor.
Jan 30, 2015 | Whirlpool duet Washing Machines
Uneven rotation of basket, bang noise, water spills
if you can open the door,grab the inner basket at 9 and 3 o'clock and see if you can move it sideways,then again at 6 and 12 o'clock and move it up and down,if you can do this,then the drum spider trunnion is broken in behind the tub and the tub is loose which will require a new tub and trunnion as they are not sold separately at about $400.00
Oct 22, 2012 | Whirlpool GHW9400 Duet Washer
I want to open the door mid cycle and restart it. Instead when I push pause the door remains locked and I can't insert another item without draining the water and starting over.
Yes that is how that style washer works since its very possible if opening the door when water is in the tub that it would spill out when opening the door when water in the tub..all front loaders work ina similar manner where when water is in the tub the door wont unlock
Aug 31, 2011 | Whirlpool Duet GHW9150P Front Load Washer
During the cycle, it has stopped and the screen is flashing F- 21, what does that mean? The door is locked and when I do get the door open, water spills out. What do I do?
The drain cycle only runs for 8 minutes. F-21 is a blocked drain tube. Open the panel in the front bottom and locate the drain tube (front right) Disconnect it and you will find a little collection area in the tube as it first comes out of the washers tub. Clean it out and try resetting it to drain then all should be fine. I always find coins and other stuff like tissues blocking the flow.
Jan 20, 2011 | Kenmore HE2 Plus Front Load Washer
Random filling of the tub, door open, leaks on floor.
The only thing that can admit water with the power off to the machine is a bad Fill valve. Replace
Aug 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water appears to collect in the tub when the machine is not in us
This is caused by a faulty inlet valve solenoid. It is allowing water to run into the tub. The solenoids can be tested using a multimeter for continuity. A lack of continuity indicates a faulty solenoid and the water inlet valve will need replaced. See the attached photo for reference. Hope this helped and best wishes.
Aug 03, 2009 | Washing Machines
Tank fills when not in use
So sorry to hear of your trouble. It sounds like your water-inlet valve is defective:
A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
May 21, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GWH9100LW1 Frontloader problem
Found the tip on another thread of this site. Remove the 3 star screws located below the access panel that's below the door and clean the trap/filter to the left of the pump. Don't do like me and try to empty as much water first or you'll have an inch of water in your laundry roon when you twist off the cap.
Sep 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
214 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
