Question about HP PSC 1315 All-In-One InkJet Printer
Windows freezes at startup unless hp 1350v printer is off - USB issue?
I have an HP 1350v all in one printer hooked up via USB port. I am encountering an interesting problem when I restart (or turn on from an off position) my Dell Dimension desktop. As the computer is starting up, it gets stuck in a position with a black screen and only a hyphen ( - ) symbol blinking in the upper left hand corner of the screen. It only does this is if the hp 1350 printer is on. When I hit the power button on the printer to turn it off, the computer resumes startup and the Windows XP loading screen appears. I tried between to different USB ports (there are 4 on the machine) but no luck in changing the problem. If any other device (Ipod, jump drive, etc) is hooked up via USB, it does not effect the startup - only the printer. Any thoughts? It gets kind of annoying to have to reach over and turn off the printer, then turn it on again every time I reboot the system.
  • Anonymous Mar 29, 2009
    I have the same problem but with a HP Officejet Pro L7680 All-In-One. Did you find a solution to this?
    Scholar:
  • 107 Answers
Hi.
u r facing realy interesting problem with u r printer.can u check u r printer wihht other system ? it can possible that u r win xp geting error to recognize u r printer ..please Check u r printer with anather Pc.
it should be problem with u r Printer or OS
if when replacing system problem get same please use below link for get update for u r printer
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=306895&lang=en
in this link please download all updates in updat colum install it on u r system .it should be resolve
If this Link useful for u please Rate me ......
It is Helpful for my Rating avg.
Posted on Jun 28, 2008
Win update software for HP PSC2210v printer
U get printer software, if available, from the HP web site.
Apr 08, 2017 | HP Office Equipment & Supplies
Setting up hp officejet j4540 printer
Is the printer driver compatible with the operating system that you are currently using? Did you check? Seems it worked at one time. Bet you "upgraded" the operating system! Upgrades, unless absolutely necessary, are fraught with issues and driver problems are very common. You have learned a painful lesson. If you go to HP, (their customer service sucks), they will tell you to get a new printer - HP of course!
Aug 25, 2017 | ASUS Computers & Internet
USB ports work sometimes and sometimes they don't.
Sounds like a drivers issue. www.driveragent.com is a reliable scanner and source of real drivers. There is a small cost involved.
Jan 19, 2014 | HP Pavilion p7-1298c Refurbished Desktop...
I bought a new HP computer and it didnt have a serial port included in it. I purchased a secondary PCI Express card that gave me two serial ports. They are programmed in as com port 1 &2. They show...
Serial connection eh? Any reason you went with serial instead of parallel? The cards likely sell for about the same price or you could just buy a USB to parallel cable that would allow you to hook up a USB port of your computer to the parallel port on the printer.
The reason that it looks like the job disappears is likely due to the fact that the serial bus is not supporting bidirectional printing so the printer cannot acknowledge that it has received the job.
Apr 19, 2011 | HP LaserJet 5 Printer
Problem is apparently HP solutions center. I have a 6940 printer and 4850 scanner. I finally got the printer to work, but it reinstalls the printer drivers at every startup. When I try to scan, the link...
Try uninstalling the drivers for the scanner and the printer. Restart the computer without either the scanner or printer pluged in. After restart install the drivers and only plug up the USB cable for each device when asked by the software.
Jan 21, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Usb ports not working
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Aug 28, 2009 | HP Pavilion dv6-1030us Notebook
Printer is not working with my new a6742p pc
Yes. It should work fine, but there are a few IFs:
IF the printer is still good...you said it's an older printer. Also, does the printer have a USB port, or is it so old, it only has a parallel port? Some newer computers do not have serial or parallel ports.
IF you don't have a parallel port on the PC, and you have no USB port on the printer, you can purchase a parallel to USB adapter.
You also may have to go the manufacturer's web site to download the drivers for the printer.
IF there are no printer drivers for your newer Operating System, you are up the proverbial ******* creek. I have a hunch you are concerned about how to hook it up because of the above mentioned parallel - USB port issue. The adapter will fix that.
Good Luck!
Apr 07, 2009 | HP PSC 1350v All-In-One InkJet Printer
Need help on printer startup problem
did you uninstall the driver?
when you hook your cable to USB port, you pC should detect your printer. Try to cycle power your PC and try to hook your cable to another USB port after you uninstall the driver
Mar 21, 2009 | HP PhotoSmart 7350 InkJet Printer
I'm receiving a door open error on an hp 2300
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 05, 2009 | HP PSC 1350v All-In-One InkJet Printer
Vista Shuts down with hp officejet j4580
Disable all the startup items and your security software and firewall. Then try installing the printer. If you still have the same problem try installing the printer by connecting to a different USB port. You can also uninstall all the USB port from device manager. restart the computer and then install the printer.
Thanks
Nov 14, 2008 | HP OfficeJet J4580 All-In-One Laser...
HP PSC 1315 All-In-One InkJet Printer Logo
121 people viewed this question
Ben Johnson
