Question about Sony Ericsson Cell Phones
Phone shut off & when I tried to switch it on again a red flashing light appears below the on/off button
    Guru:
  • 1,894 Answers
When You try to start your phone the red light blinks and phone refuses to start.
if Your computer also does not identify your phone.
And its seems to be completely Dead..am i right???
Redlight blinking is a Sign of Low Battery or a Dead EROM.
  • his happens Some time during flashing the EROM goes dead or corrupt due to errors.
  • If phone has a bad EROM it shuts down and does not start even if battery is charged to full.
  • Double Check that battery is not the problem before you proceed to flash the EROM.
  • preoblem in EROM will lead to problem of the firmware or GDFS is corrupt
  • In that case we have to repair the EROM. And now here we will discuss the easiest way to fix it.
Note: Before you use SeTool 2 lite you will need to have USB flash drivers installed.
Please follow the USB flash driver installation tutorial (the given blue link) in tutorials section to install them. And kindly borrow your friend’s Sony Ericsson Phone to install usb drivers because your phone is dead.
Using SeTool2 lite 1.11 we can fix this problem by this way.
  1. Start SeTool 2 lite
  2. Press Unlock\Repair Button, The first button.
  3. Reinsert Battery
  4. Connect phone holding 2+5
  5. Wait, SeTool 2 lite will repair the EROM, it will flash it back.
  6. Done
Now you can start your phone.
Posted on Jun 28, 2008
  • dewan nafees ahmed Jun 28, 2008
    hope it helps.
    thank you
    dont forget to accept MY solution if u go by it.
    feel free for asking any doubts u have.
    thank u for ur cooperation.
    good luck for getting fixed soon
    Guru:
  • 1,342 Answers
Flashing red light means the battery is low. Allow it to fully charge.
    Brigadier General:
  • 3,614 Answers
Is the battery was fully charged...?
if yes..
kindly remove the battery on the unit and put it back on after 3hours..
let me know here again..
  • micromaster
    micromaster Jun 28, 2008
    hi there,
    BTW... i want to know the phone model & maker..
    Thank you
    Master:
  • 848 Answers
Just remove the battery and reinsert it once again ..........
  • gopinath pasupathy Jun 28, 2008
    if this doesnot work then there might be some software problem .....just provide me the model number
Red light goes on and off
Needs the button put back into place. Look under the cabinet to see if there is an access panel below the switch, would go for all external controls. There would be a chassis with all the controls mounted to it.
Pull the plug before doing any repairs.
Look to see what it would look like in it's normal position. Something has moved out of place that holds the switch to the panel. Very tedious if you have to remove the whole housing.
Mar 14, 2013 | Toshiba 36A43 36" TV
How to link my blue tooth
Pairing the Plantronics Explorer 220:
For most phones, select Settings/Tools, Connections, Bluetooth, On. See your phone's user guide for more information.
With the 220 headset powered off, turn on the headset by pressing and holding the call control button for approximately 5 seconds until the LED flashes red & blue. The Explorer 220 headset is now in pairing mode. If you don't see the red/blue flash, press and hold the power button to turn your headset off, and then press and hold the power button again and hold for 5-6 seconds until you see the red & blue flash.
From your phone, go to the Bluetooth menu and select "Search" or "Add Device". Your phone should find the headset which will appear as "2xxPlantronics" in your list of devices.
If prompted for the Passkey (PIN code), enter 0000. If your phone asks for a PIN/passkey, enter 0000 (4 zeros). Pairing is successful when the LED on your headset flashes blue. Your headset is now connected and ready to use.
Here is the link below for step by step instructions.
http://www.headsetsdirect.com/plantronics-explorer-220-bluetooth-pairing-instructions
Good luck from Headset Direct - 800-914-7996.
Aug 11, 2011 | Plantronics Explorer 220 Bluetooth Headset...
PS3 switched off during use, Red light flashing at front,can't get game out.Tried switching on while holding disc removal button,that did not work,left unit overnight to cool down,tried it again and it...
Sounds like a heat problem. You can either send it to sony and get it fixed for about $50. Or check out this youtube video below which has help many people through this problem.
Hope this helps, Nathan Taylor
Jul 18, 2011 | Sony Playstation 3 (PS3) Console
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
I HAVE THE MERLIN PHONE SYSTEM 820D2 I WOULD LIKE TO SILENCE CERTAIN NUMBERS FROM RINGING. HOW DO I DO THAT?
Now that's an oldie :-) I have the instructions squirreled away right here
Here's how to program line ringing:
• go to the voice terminal whose line ringing you want to program
• slide T/P switch toward you
• touch a line button (note red lights)
• touch the button again until correct code appears:
RED ON = Ring
RED FLASH = Delayed Ring
RED OFF = No Ring
• repeat this procedure for each line
• return T/P switch to center position.
Carl
Oct 19, 2010 | AT&T Merlin Plus 820D2 KSU Phone
How do you turn the flash on? (with the vivitar vivicam 8018)
Your camera has a built in flash function which enables you to take photos when the light condition is not good.
1. Press the Up button. (for reference of buttons, please see the below figure mentioned)
2. Press the Up button once until you see the icon appear on the LCD screen. This indicates that the flash is forced on.
3. Press the Up button again to change to the auto flash function.
4. The icon will appear at the top of the LCD indicating that the auto flash is turned on and ready to use.
5. Press the Up button again to change from the auto flash to the red eye function.
6. The icon will appear on the LCD indicating that the red eye reduction function has been activated.
7. To turn off the flash function, press the Up button again until the icon is displayed on the LCD.
Note: A “Low Power” message will appear on the LCD screen, if you select the flash function when the battery power is insufficient. To continue using the camera with the flash, please change new batteries
Feb 13, 2010 | Vivitar ViviCam 8018 Digital Camera
Sony Ericsson K700i
thank you for your assistance, the solution your expert suggested was correct & phone now works
Jun 28, 2008 | Sony Ericsson K700i Cellular Phone
While charging my O2 atom exec, the LED (Flash light) does not glow red ?
I have the same problem. What I did several time is to actually shut down the phone, remove the battery and leave it like that for several hours (3 to 4 hours). Then, I put the battery back in the phone, and it would charge again. However, due to the long time with no battery, the phone's clock would be reset to January 2007.
I found no other work around right now. However, I have to do this more and more often, almost once a week ...
Mar 21, 2008 | O2 Xda Atom Exec Smartphone
Cell Phones Logo
202 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
