Question about Starbucks Saeco Italia Digital Barista Coffee Machine
Digital italia espresso machine
Steam wand broke off i think i have all the parts to fix but need digram to put back together
  • 40 Answers
Contact Saeco USA Inc. at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Posted on Jul 17, 2008
Flashing lights on my saeco italia espresso machine
I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Feb 22, 2010 | Starbucks Saeco Italia Digital Barista...
Can't get steam from the a Starbucks Saeco Italila Digital Auto
Hi If you can get water to flow from the wand, you can descale the machine. You might have a bad steam boiler. There is also a fuse on the boiler that might be bad. Set your water hardness to 4 to keep the machine working for a long time. Descale more often than not enough.
Jan 26, 2010 | Starbucks Saeco Italia Digital Barista...
Water leaking from steam hose on Saeco Italia
There is a part that the hose connects to and it is made of plastic. The plastic on mine had a tiny split in, which caused it to leak. I got a replacement one made of brass and that problem is fixed. Now my machine is broken in another way and I am hoping to get it fixed. What a piece of junk!!!
Aug 05, 2009 | Starbucks Saeco Italia Digital Barista...
Saeco Digital Italia steam knob
Take off the top and you will see the steam valve, try to mount the parts again.
Best regards
/Mirran
Sep 09, 2008 | Starbucks Saeco Italia Digital Barista...
Mobile connector for steam tube...
not sure if you got the part. I called Saeco USA and they sent me the little swivel joint which supposedly is a strong plastic component. check with them
May 21, 2008 | Starbucks Saeco Italia Digital Barista...
Saeco Digital Italia Fix
I had this same issue with my machine and unfortunately I had to send the machine back for repair. The steam knob should pop right back on, if positioned correctly. The people (Starbucks, Saeco) whom you spoke to were correct, that there is build up of steam (or back pressure) it will cause the knob to pop of in these conditions. The root cause of this problem is most likely (as in my case) that you steam wand is clogged. Even if you keep it cleaned externally, there may still be debris that builds up INSIDE the wand. To correct the problem, take some wire (we used decorating craft wire) that will fit into the end of steam wand. Push the wire as far up as you can and continue to move back and forth. Flush the wand either with steam or hot water and repeat several times. I do this every month or so to keep the debris from building up inside the wand. Good luck and I hope this works for you.
Mar 11, 2008 | Starbucks Saeco Italia Digital Barista...
Super espresso machine leaking
Hi
Your steam manifold needs to be replaced. I still have the original in mine but if you don't cool them down after steaming they will develop hair line cracks and leak after while. To cool it down after steaming push the steam button again, then open the knob and run it till you have a steady stream of water, then close the knob.
The replacement manifolds are black and have held up very well but they have a brass manifold re[placement but you will need new mounting hardware.
Feb 28, 2008 | Starbucks Saeco Italia Digital Barista...
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
172 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
