Question about iLO (2 GB) MP3 Player
Ilo mp player
Just keeps flashing and i've tried plugging into pc and doesn't help, i've changed battery.
  • rondae Jun 28, 2008
    my ilo mp3 just keeps flashing, i've changed battery and plugged into pc but still the same
  • Anonymous Jul 03, 2008
    The mp3 player flashes and will not shut down. It will recognize that it is connected to the computer but will not do anything.
It would help if the telephone number they give was still available.Also an address to send the product back to get a replacement or fixed would be helpful.
Posted on Jul 03, 2008
  • 3 Answers
Hi Rondae,
Try leaving the battery out of the player for about a couple of hours. This might give it time to reboot the system. If you contact the manufacture this is what they will tell you unless your player is less than 90 days old they might replace it with the receipt. Take care.
Posted on Jul 02, 2008
HOW TO DOWNLOAD MP 3 PLAYER
YOU CAN'T DOWNLOAD MP3 PLAYER CAUSE IT'S A DEVICE..
YOU CAN BUY IT TO STORE..IF YOU MEAN DOWNLOAD MUSIC,SIMPLY PLUG IN YOUR DEVICE TO PC,THEN COPY AND PASTE MUSIC FILES TO YOUR DEVICE..
THANKS FOR VISITING FIXYA,MAY THIS HELPS YOU..GOODLUCK
Feb 25, 2011 | iLO (2 GB) MP3 Player
Ilo Mp3 player
Remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted. On the iLO, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the iLO will remain off during this time, making the screen appear to be blank. An hourglass should appear on you computer and Windows should say, "Found new Hardware 'SMTP3500". Launch the Rave-MP firmware update program (Start>Programs>Rave-MP> Firmware) Click "Get Firmware". Select "iLO256" and let it download new firmware. Click "OK" when prompted. Click "Update Firmware". It will now search for the iLO. This may take a while depending on how corrupted the firmware is, so be patient. After it has found the iLO, it will say, "A device has been detected in recovery mode and is being initialized. Please wait." The iLO should come back to life and start showing it's glorious "USB Connected" screen. The "Firmware Update" window should appear. Select "Format Data Area" to rid the player of corrupted firmware data. And click "Start". It can take anywhere from 2 to 4 minutes to re-flash the iLO and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the iLO! Why are you still reading this? Great, did something happen? Well, If the program fails to find the iLO and gives you an error like, "Device Timeout" or something similar, you need to reinstall the iLO drivers. This can be done by inserting the iLO cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again). Plugging it into a new USB port is the fastest and easiest option though. Also check the following link for there FAQ: http://www.uiss.6x.to/ Good Luck
Sep 18, 2007 | iLO MP3 Player
ILO MP-556 MP3/WMA player
Revised iLo instructions for Windows Media Player 11:
Connect the iLo to the computer
In Windows Media Player 11, Run the mouse over the Sync tab
Click the little black arrow that appears underneath the Sync tab
Select More Options
Click the Devices Tab
Highlight the iLo
Click Properties
Uncheck box, "Create Folder Hierarchy on Device"
Download the firmware file at: https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip
then proceed with the rest of the directions
-Tha Mp3 Doctor
iLO Mp3 Player
"Flash Error"
1. Connect the player to the PC using the USB cable. 2. Open Windows Media Player. 3. Go to the Sync or Devices tab and delete all content from the player. 4. Go to the Tools menu and select Options. 5. Select the Devices tab, highlight the ILO or Siren player and click on Properties. 6. Uncheck the box "Create Folder Hierarchy on Device" ---- "Firmware Upgrade" (provided by jwmgotee):
I just repaired/reformatted my 1.0 GB Ilo following the instructions below with no problems:
Please connect the player to a rear USB port on the computer. The display should show “USB Connectedâ€
. (If not, please press the power button.) Please make sure that all unused programs and applications are closed. You can close the applications by closing as many of the icons in the lower right hand corner (by the clock) as possible. Download the correct Firmware Click here (https://system.netsuite.com/core/media/media.nl?id=16076&c=432868&h=b25618a8ea7ead5c9573&_xt=.zip) to download the ILO 116 Firmware Click Open to initiate the download Double click on the ILO or Siren folder icon. There will be 14 icons. There will be a Setup icon that looks like a box with a blue line on it; please double click on this. Then click Run - this will open the Install Wizard. The Install Wizard has the instructions on the screen as you go through it. Once the firmware has installed, please click the Start menu, then Programs. Look for the icon that says ILO or Siren, and then double click the Firmware Update to install to the player. Depending on how severe the corruption to the firmware on the player is, you might have to do this step 2 or 3 times in order for it to completely repair the firmware. It will now search for the ilo. This may take a while depending on how corrupted the firmware is, so be patient.
After it has found the ilo, it will say, "A device has been detected in recovery mode and is being initialized. Please wait."
The ilo should come back to life and start showing it's glorious "USB Connected" screen.
It can take anywhere from 2 to 4 minutes to re-flash the ilo and the program might appear to have locked up, but it hasn't. So don't close the program or disconnect the ilo!
If the program fails to find the ilo and gives you an error like, "Device Timeout" or something similar, you need to reinstall the ilo drivers. This can be done by inserting the ilo cable into a USB port it has never been plugged into before. Or you can reinstall the drivers by reinstalling the Rave-MP program. (Remove it, restart the computer, and then install it again).
Although, plugging it into a new USB port is the fastest and easiest option.
If your player won't even turn on, follow these instructions first and then those above:
First, remove the battery. While this isn't necessary to get the player into recovery mode, it insures the unit will not power on before the cable is inserted.
On the ilo, hold the "Power" button down while inserting the USB cable. Continue holding the power button down for 5 seconds more after the cable is inserted. The backlight on the ilo will remain off during this time, making the screen appear to be blank.
An hourglass should appear on your computer and Windows should say,
Jan 10, 2009 | iLO MP3 Player
It doesn't work
plug it up to the computer go to my computer right click the drive for the mp3 player and reformat the drive you also might want to remove the music before reformating it or you will lose the music
Jul 12, 2008 | iLO (2 GB) MP3 Player
Can't sync music onto MP3
Hi Jollie17,
Try downloading the free version of real player and use this to sync your music files. It helped me. Take care.
Jun 29, 2008 | iLO (2 GB) MP3 Player
ILO NOT WORKING
My ilo model number mp-556 suddenly stopped working so I put in a new battery and all I could get out of it was a loading screen. I did some researching online and came up with this post <a herf="http://www.fixya.com/support/t202851-ilo_turn">http://www.fixya.com/support/t202851-ilo_turn</a> I followed what he said and it worked.
Feb 25, 2008 | iLO (2 GB) MP3 Player
Won't turn on correctly-flashes on and off
My ilo will not turn on! I've tried changing the battery - but no luck.
Feb 20, 2008 | iLO (2 GB) MP3 Player
Flashing ilo.
I found that connecting the MP3 player to the computer with the patch cord causes the player to reset and eliminates the problem. It only takes a few moments,just disconnect when the pc tells you it is safe to remove the device.
Jan 19, 2008 | iLO (2 GB) MP3 Player
Doesn't power up replaced batteries
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Sep 23, 2007 | iLO (2 GB) MP3 Player
Ilo won't turn on.....
Sep 18, 2007 | iLO (2 GB) MP3 Player
iLO (2 GB) MP3 Player Logo
51 people viewed this question
Top iLO Audio Players & Recorders Experts
laikexpert
laikexpert
Sanath Kumar V
Are you an iLO Audio Player and Recorder Expert? Answer questions, earn points and help others
