Question about Sony Mavica MVC-FD200 Digital Camera
It will not turn on// green light flashes then goes out.
Only way to repeat process is remove and replace battery. camera is useless// will not work. Surely Sony have the solution, but contact with them only produced uncaring comments. Does someone have an answer or do I need to dump it?? (It once worked ok)
    Sergeant:
  • 275 Answers
Can you elaborate the problem
Posted on Jun 28, 2008
    Guru:
  • 1,894 Answers
Did you try a different batery??
have you dropped your camera before anywhere?
  • dewan nafees ahmed Jun 28, 2008
    am not sure if you can fix this. but we can give a try to sort out the probelm
    you may have a serious problem with the power circuit of your camera.
    but if you have dropped it and if it has recieved a excess shock then it could have damaged the main circuits of the camera.
    so try a different battery and try your luck.
    if it does not solve the problem it can be some serious internal fault.
    if you have experience in repairing cameras then you can open it and investigate it.
    thank you
    hope this helps
    good luck
    have a great day
    hope it helps.
    thank you
    dont forget to accept MY solution if u go by it.
    feel free for asking any doubts u have.
    thank u for ur cooperation.
    good luck for getting fixed soon
    President:
  • 2,712 Answers
You have a problem with the CCD circuitry, and this will require a service, not something we can do on this forum, unfortunately..
  • Swilin Sampson
    Swilin Sampson Jun 28, 2008
    Look around, if your cam is not under warranty, and if the service cost is too high, I'd say junk it and buy a new cam..This repair is not one for a novice, and requires the attention of a skilled technician..
Tip
Pix shuts off, green light starts flashing, pix comes back and shuts off again
If you have an issue where your picture turns off and the green power light starts flashing, you are most likely looking at a weak or old lamp. Do not be confused with a pix loss and a RED light flashing, as this can be caused by many things. The normal sequence of events for this fix is this:
1) TV turns on normally, plays for 1 to 3 minutes (may be more or less time)
2) Picture goes out and green power light begins flashing. It may flash for up to 2 minutes
3) green light turns on solid (stops flashing) and picture returns.
4) Picture goes out again and process repeats.
You may have been told that "if the lamp light isn't on, it isn't a bad lamp".
FALSE!
A weak lamp will cause the process above to occur. Other signs of a weak lamp:
The reflector in the lamp is very cloudy
You may see a "growth" or "bubble" on the vertical glass tube which is the lamp
You haven't replaced the lamp in quite some time or it is the original lamp from when you purchased the TV.
In cases like these, try a new lamp. Stick with an original Sony lamp, as there are many stories (both personally witnessed by me and also documented on the web) about problems with after market replacement lamps. And remember, lamps DO NOT have a shelf life; you can store them in a good environment (not too hot or cold!) for an indefinite period with no ill effects.
on Nov 03, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Kodak easyshare M893 IS will not stay on. The battery has been charged and replaced, however, when the camera is turned on the green light comes on, the "Kodak EasyShare" screen appears for a second or...
Make sure that you are installing a fresh/ full charge battery
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 23, 2009 | Kodak EasyShare M853 Digital Camera
Camera turns on then off immediately
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Contact KODAK:
Nov 04, 2009 | Kodak Easyshare M893 Digital Camera
Battery light green, then flashes four times red, repeats
remove the battery
clean the connecting ends of ur laptop & battery,
plug it back in & then start it...
Aug 27, 2009 | Dell Latitude D600 Notebook
Camera won't turn on - makes strange sound
This is a very common issue with digital camera on either the lens gears have to be replaced or the lens barrel need replacing. I rebuild these lenses all the time for 75.00 plus shipping and the turn around is normally less then a week. if you still need help fell free to contact me at mike@digitalcamrepair.com
Feb 26, 2009 | Casio Exilim EX-S600 Digital Camera
With new batteries already put in--no power
Are you using rechargeable batteries, and have tried lots of different batteries? Also, sometimes rechargeable batteries fresh out of the package can be dead or have very little juice. Just a thought...Hard to say that's it though if you were having the same thing happen before...
Jan 16, 2009 | Apex Digital Digitrex DSC-3000 Digital...
Green light goes off, red light comes on and camera goes off.
I have fuji, finepix s700. DIGITAL CAMERA
What happens when the light blinks red and green repeatedly every time I want to turn the camera on? I know that this camera also uses batteries. Does this mean I should replace them?
Jun 03, 2008 | Cameras
D80 and SB-600 FV Lock doesn't work anymore
In whacky situations like this it is always best to re-set your camera and flash settings. Somewhere on your D80 you will find two function buttons with small green dots next to them. These are the resets. Push both in at the same time until the display LCD flashes.. The camera is now reset to default settings.You will now have to re-set your FV button to the custom setting you had it at before.
Also, reset you flash by turning on the power and removing the batteries and re-install them.
Apr 21, 2008 | Nikon Speedlight SB-600 TTL Flash
Flash won't power up
Try it with a NEW fully charged battery
Nov 17, 2007 | Pentax Optio S5i Digital Camera
Sony Mavica MVC-FD200 Digital Camera Logo
76 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
John Peabody
John Peabody
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
